    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree369Likes
Old 05-06-2016, 06:01 PM   #391
Cridd's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Pinkz View Post
will there be a rear motor option for this buggy? just wondering, thinking the B5 will be dropped?
Everybody thinking B5R will be around and possibly become the RTR car and discontinue the B4.2 RTR. That will keep a 1/10 rear motor car in their line up.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 05-06-2016, 11:11 PM   #392
Parts have been added! No photos yet:
https://www.teamassociated.com/cars_...s_accessories/
To finish first, you must first finish.
B6
I get my rug burns at Northwest Hobbies.
_danimal_ is offline   Reply With Quote
Old 05-07-2016, 07:28 AM   #393
Laydown gearbox for the D is $27. Nice.
boucher is offline   Reply With Quote
Old 05-07-2016, 10:12 AM   #394
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Eagerly waiting on pic of the adhesive hook and loop!
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 05-07-2016, 11:27 AM   #395
3srcracing's Avatar
Trader Rating: 25 (100%+)
So the turnbuckle size is 3x48, anyone know what cars currently use those?
A Main Hobbies | Protek R/C | Team Powers R/C | Cheater Racing
3srcracing is offline   Reply With Quote
Old 05-07-2016, 02:21 PM   #396
Is 702 a spike tire (Pin Points) or slick tire (Primes) carpet track? Track appears to be an Ozite on-road style carpet?
The reason I ask is because our local indoor on-road club added a 2wd off-road class by putting some jumps on their Ozite track. Originally the rules allowed spiked carpet tires, but the club felt the spikes were harming the Ozite carpet so they've switched to a sauced slick tire rule.
Will a sauced slick tire on an Ozite track generate B6 super high grip?
702 runs spiked rear/wedged front tires for offroad... but it's not ozite. Its high traffic short pile office type carpet. it's only been a few months, but so far the offroad cars havent frayed or torn it up.
I assume sauced slicks would work too; on-road uses sxt 3.0 and it hooks up great.
shdwboxn is offline   Reply With Quote
Old 05-07-2016, 02:42 PM   #397
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
48mm = 1.88976 inch. I think the current b5m is 2.06in.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-07-2016, 04:09 PM   #398
Originally Posted by _danimal_ View Post
Oh Associated. Now they're not there lol... You can still view a parts list using Excel Data Export.
B6
Old 05-07-2016, 04:58 PM   #399
I copied down parts numbers and prices for the things I need lol
91708 Laydown gearbox
91715 Laydown motor plate
91716 Idler gear
Old 05-07-2016, 05:01 PM   #400
Trader Rating: 90 (100%+)
You are missing front arms and front shock tower, and the body.
dan-o is offline   Reply With Quote
Old 05-07-2016, 05:09 PM   #401
RCBuddha's Avatar
Trader Rating: 35 (100%+)
91716 Idler gear
I'll start the list on the first page...
RCBuddha is offline   Reply With Quote
Old 05-07-2016, 05:47 PM   #402
RCBuddha, thanks for all your work! One thing to note on the first page....Q & A on X-rings is great for B5M and B5 but the B6 & B6D come with x-rings (don't want to confuse people).
I am curious if the shock shafts will hold the piston on with a screw or E-clip??? I've never had a problem with the e-clips, but it seems like having the piston screwed on tight would improve smoothness and consistency.
dsms4ever is offline   Reply With Quote
Old 05-07-2016, 05:59 PM   #403
RC*PHREAK's Avatar
Trader Rating: 120 (100%+)
i believe they will use V2 shafts (screw in piston).
RC*PHREAK is offline   Reply With Quote
Old 05-07-2016, 07:59 PM   #404
RCBuddha's Avatar
fixed!
Old 05-08-2016, 06:17 AM   #405
I would have taken a screen shot of the whole page if I'd known it was coming down. I only wrote down the items I was interested in -I'm getting the B6D, so I didn't worry about the arms/towers.
I did get a few FT options down though:
91755 Ti Screw Kit
91669 Aluminum Steering Rack
91668 Aluminum Steering Bellcrank
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
Raulote, _AMA_
