    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree327Likes
Old 10-25-2016, 05:46 AM   #3976
mxnickj's Avatar
Trader Rating: 51 (100%+)
Hey guys, looking for advice for which car to pick (B6 vs B6D) for a medium size indoor clay track running stock 17.5 class. It has pretty good grip but can get a little dust outside of the good line but the rest is good grip. Bumps and Jumps RC in PA if anyone is familiar.
Nick Johnson
AE SC5M - AE B6D
Bumps & Jumps RC - LCRC
mxnickj is offline   Reply With Quote
Old 10-25-2016, 06:37 AM   #3977
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Originally Posted by raved007 View Post
Question guys first run my B6D and the rear hub by the ball stud was broken. I order rear hub from schelle aluminum rear hub part#SCH1093 and there only 2 location of ball stud how can i get the stock ball stud location? I was thinking the geometry of the rear truck it change.
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 10-25-2016, 06:38 AM   #3978
Logi Maker's Avatar
Get the D.
Kyle Predmore
Old 10-25-2016, 07:06 AM   #3979
Anyone running the new Schumacher yellow compound mini dart tires on astroturf? How do you like them compared to Proline Pinpoint rear and Wedge front and what Schumacher foams are you running with them, medium blue or hard black?
roysays is offline   Reply With Quote
Old 10-25-2016, 07:08 AM   #3980
I'm pretty sure it's the inner hole w/ a 2mm washer under the ballstud
RookieRacer00 is offline   Reply With Quote
Old 10-25-2016, 07:26 AM   #3981
Originally Posted by kavee View Post
Hi guys
maybe it was discussed in here so i am sorry.
our local track is going to be turf soon.
i would like to start driving 2wd.
which kit is the best for turf:
B5M?
B6?
B6D?
thanks
B6, astroturf is high grip
Old 10-25-2016, 10:00 AM   #3982
goehm's Avatar
Trader Rating: 44 (100%+)
People are starting to run the laydown transmission with good success at Mimis, which is less grip than Bumps. I'd suggest the D and buy the laydown trans.
--GO!
Come visit G's RC Raceway / Shippensburg, PA / www.GSRC.us
goehm is offline   Reply With Quote
Old 10-25-2016, 10:16 AM   #3983
mxnickj's Avatar
So the B6D with laydown and the normal flat arms and tower? I have been looking at a lot of the setups online and that seems to be a pretty common setup.
Nick Johnson
AE SC5M - AE B6D
Old 10-25-2016, 10:46 AM   #3984
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I like that setup for indoors. I never cared for the feel of gulwings. And with flat arms, the L/R arms are the same. With gulwings, I ended up with a pile of extra right arms. I also didnt like the way they felt on the track.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-25-2016, 11:12 AM   #3985
mxnickj's Avatar
Ok awesome, thanks!! So the laydown gearbox with the ball diff? Or gear diff?
Also, since I'm ordering, what else is needed for this car right away? I'm guessing the kit doesn't come with wheels?
Nick Johnson
AE SC5M - AE B6D
Old 10-25-2016, 11:14 AM   #3986
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
If you are running on dirt I would recommend the ball diff. Kit does not come with wheels/tires. I would also recommend the aluminum D mount for tuning purposes.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 10-25-2016, 11:19 AM   #3987
Mason's Avatar
Pop Survey: I'm still debating about picking up a B6/D somewhere around the New Year. I am curious about actual numbers and not about "this other guy at the track". So if you have had to personally replace the items below due to breakage, let me know how many times.
How many have you replaced:
Front Tower:
Rear Tower:
Chassis:
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 10-25-2016, 11:23 AM   #3988
I prefer the ball diff. If I raced on carpet, I would probably run a gear diff.
Old 10-25-2016, 11:24 AM   #3989
Front Tower:
Rear Tower:
Chassis:
Front Tower: 3
Rear Tower: 1
Chassis: 0
Front Plastic Bulkhead: 1
nothing else.
Old 10-25-2016, 11:27 AM   #3990
Super Moderator
Front Tower:
Rear Tower:
Chassis:
I haven't replaced anything. People break things....sometimes they deserve to break. I have yet to see a B6 break at the local track that probably has 20-25 B6's on any given club day between Sportsman/Expert 17.5 and a 13.5 class. And if this turns the forum into 38 posts about how many broken parts people have had they will get deleted.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Fanatic01
