    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree369Likes
Old 10-24-2016, 11:29 AM   #3961
Logi Maker's Avatar
Trader Rating: 49 (100%+)
FACT
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 10-24-2016, 12:05 PM   #3962
Trader Rating: 23 (100%+)
[QUOTE=Jmuck69;14713037]
Originally Posted by ozerdam View Post
Wheels didn't come with the kit.
Doh....
Gary Madrazo
ozerdam is offline   Reply With Quote
Old 10-24-2016, 12:26 PM   #3963
aeRayls's Avatar
Originally Posted by AccessRacer View Post
Do I need to move the axle height up with this change?
No, you're just moving them in further not up or down.
aeRayls is offline   Reply With Quote
Old 10-24-2016, 01:15 PM   #3964
Thumbs up B6 or B6D or B5M?
Hi guys
maybe it was discussed in here so i am sorry.
our local track is going to be turf soon.
i would like to start driving 2wd.
which kit is the best for turf:
B5M?
B6?
B6D?
thanks
Yokomo bmax4 iii, RC8B3e, AE b4.1
Orion 6.5T, Orion 1950 KV, HK 8.5T, LRP/Orion ESC, futaba 4pl, Savox
kavee is offline   Reply With Quote
Old 10-24-2016, 02:00 PM   #3965
JAE
Trader Rating: 28 (100%+)
Shocks are squeeky. Sounds like air. Even after bleeding.
Originally Posted by timannnn6 View Post
Are you sure it's not the lower ball end squeaking? The ball may just be binding. Squeeze the rod end with pliers to free it up.
JAE is offline   Reply With Quote
Old 10-24-2016, 02:06 PM   #3966
Those clay setups using the Yokomo Green rear spring. Is it YOKYS-A1200? I've also heard people using the Yatabe Arena YAS-1050 which is also a green as well. The Yatabe is shorter by just a tad.
daveb is offline   Reply With Quote
Old 10-24-2016, 02:08 PM   #3967
mdwaeracer's Avatar
Trader Rating: 19 (100%+)
Originally Posted by kavee View Post
Hi guys
B5M?
B6?
B6D?
thanks
The b6 will be your best in my opinion
TEAM ASSOCIATED Rc10, rc10B6D ,FUTABA , TEAM ORION, KYOSHO RB6.
mdwaeracer is offline   Reply With Quote
Old 10-24-2016, 02:11 PM   #3968
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
The 1200 is the spring used on the dirt setups.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 10-24-2016, 02:12 PM   #3969
thanks
is it fit saddle pack with no modification?
Old 10-24-2016, 02:18 PM   #3970
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
thanks
no. shorty only
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-24-2016, 02:20 PM   #3971
lbckevin's Avatar
Trader Rating: 91 (99%+)
no saddle pack, just use a shorty
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 10-24-2016, 05:37 PM   #3972
Trader Rating: 32 (100%+)
Question guys first run my B6D and the rear hub by the ball stud was broken. I order rear hub from schelle aluminum rear hub part#SCH1093 and there only 2 location of ball stud how can i get the stock ball stud location? I was thinking the geometry of the rear truck it change.
raved007 is offline   Reply With Quote
Old 10-24-2016, 05:43 PM   #3973
Super Moderator
Read the insert that comes with the hubs. It's all stated there.
Old 10-24-2016, 08:09 PM   #3974
JAE
VRP Pistons: Anyone use them on the B6?
JAE
Old 10-24-2016, 11:36 PM   #3975
Phillip F's Avatar
Trader Rating: 17 (100%+)
that's like my Xray XB2 CE.
Phillip F is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Steve_tkachuk
