    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree323Likes
Old 10-23-2016, 06:15 PM   #3946
Razathorn's Avatar
Just built my b6d. Gotta say the build quality is phenomenal. Only issues I had was I needed to use shorter screws with a savox servo and shorter screws on the gear cover since it wanted to hit my motor. My only complaint is the new Pistons are even looser than the older ones, virtually demanding the machined ones. Built with long shocks and tower.
Can't wait to hit the track
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 10-23-2016, 07:37 PM   #3947
tsair's Avatar
Originally Posted by 190mph View Post
I use this servo horn for Futaba/Savox 25T spline:
https://www.amainhobbies.com/team-as...sc1366/p507395
There is other good ones if you search B6 Servo Horn on AMain.
The AE B6 aluminum servo horn pushes the ballstud a little far forward than ideal for the Savox -- the steering link isn't perfectly perpendicular to the chassis, and is at a slight angle to the bellcranks ballstud. This adds mechanical expo to the steering.
B5 aluminum servo horn with no washers would probably be ideal -- like the B5/B6 plastic horn.
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 10-23-2016, 08:08 PM   #3948
Trader Rating: 23 (100%+)
[QUOTE=Logi Maker;14711797]
Originally Posted by ozerdam View Post
Just finished putting together my B6D and the front wheels rub against the steering ball cup. I'm assuming this is not normal, I put the kit together according to kit set up. Any
Pics
Gary Madrazo
ozerdam is offline   Reply With Quote
Old 10-23-2016, 08:41 PM   #3949
Rubiconmike's Avatar
Originally Posted by bmag5000 View Post
I'm running a 4600kv castle in my B6D, people have told me not to go to the 5700kv
just because the motor gets hotter and its not as reliable as the 4600kv.
Plus id have to run a cooling fan on the esc and I don't wanna deal with fans.
The track I race on is small anyway and I wouldn't be able to open up a 5700kv.
Hey man. Is you're 4600 a 2pole? I'm building a B6 for carpet.
I'm going to run a CC 4600 2pole with a CC sidewinder gen1 I already have to get going. What gears are you running?
Rubiconmike is offline   Reply With Quote
Old 10-23-2016, 09:35 PM   #3950
aeRayls's Avatar
[QUOTE=ozerdam;14712491]What wheels are you using?
aeRayls is offline   Reply With Quote
Old 10-23-2016, 10:17 PM   #3951
JAE
Trader Rating: 28 (100%+)
Anyone notice these shocks get super squeeky? I had someone rebuild my shocks for me, as he was taking all the blue anodizing off my car for a fee.... Wondering if taking the anodizing of the bottom caps on the shocks may have lefty some room for air to get in? It's odd all the shocks get squeeky even after changing oil and re-bleeding. This normal? Anyone else remove anodizing from shocks? Thx
JAE is offline   Reply With Quote
Old 10-24-2016, 12:17 AM   #3952
i used a losi 22 alum horn with a 2mm spacer under the ballstud.
RC10 B6
LC Racing truggy,
Tamiya lunchbox, Blackfoot 3
"where am I going, and why am I in this hand basket?"
Lunchie is offline   Reply With Quote
Old 10-24-2016, 05:39 AM   #3953
Logi Maker's Avatar
Trader Rating: 49 (100%+)
[QUOTE=ozerdam;14712491]Looks legit.. what wheels?
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 10-24-2016, 06:43 AM   #3954
AccessRacer's Avatar
Trader Rating: 20 (100%+)
What pill changes can I make to give me more rear grip on medium clay? I have stock pill setup in a laydown car with brass 12g c block aluminum d block with shocks in front of arms.
AE B5M
AE RC10T5M
AE SC5M
AE B44.3
AE RC8B3E TEKNO SCT410.3 JRC JET EDM & LATEMODEL
AccessRacer is offline   Reply With Quote
Old 10-24-2016, 07:00 AM   #3955
timannnn6's Avatar
Trader Rating: 124 (100%+)
Are you sure it's not the lower ball end squeaking? The ball may just be binding. Squeeze the rod end with pliers to free it up.
timannnn6 is offline   Reply With Quote
Old 10-24-2016, 08:09 AM   #3956
aeRayls's Avatar
Try using the .5 or 1 pills move them middle/inside
Old 10-24-2016, 08:44 AM   #3957
Jmuck69's Avatar
Try moving the shocks to the rear, should give more grip than the front.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 10-24-2016, 09:23 AM   #3958
Do I need to move the axle height up with this change?
AE B5M
AE RC10T5M
AE SC5M
AE B44.3
Old 10-24-2016, 10:07 AM   #3959
[QUOTE=aeRayls;14712535]
The ones that came with the kit. Maybe I got the wrong wheels also... the chassis brace isn't even the right one.
Gary Madrazo
Old 10-24-2016, 10:13 AM   #3960
Jmuck69's Avatar
[QUOTE=ozerdam;14713029]
The ones that came with the kit. Maybe I got the wrong wheels also... the motor brace isn't even the right one.
Wheels didn't come with the kit.
B6D | B64D
