    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree366Likes
Old 10-21-2016, 09:02 AM   #3916
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Originally Posted by Cain View Post
Thinking about picking up another one of these for my daughters to use. I saw someone post about the RPM wide front bumper fitting, how durable are the front arms turning out to be compared to say a b4? (that would be my point of reference)
Just trying to see what I would need to up armor for them.
You should be fine. Plastic quality is much better than the B4.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 10-21-2016, 09:29 AM   #3917
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
way better than the b4.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-21-2016, 09:43 AM   #3918
Originally Posted by Matt Trimmings View Post
Your best bet would be to post a picture. Or go through the manual again double checking it again.
I plan on double checking how I assembled it. If it looks ok I will post a pic. Thanx.
RookieRacer00 is offline   Reply With Quote
Old 10-21-2016, 09:48 AM   #3919
TBone has bumpers for the B5's, not sure about the 6. Check it out: www.tboneracing.net
Old 10-21-2016, 10:20 AM   #3920
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
cool thanks!
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 10-21-2016, 10:33 AM   #3921
tsair's Avatar
Originally Posted by RookieRacer00 View Post
I just started my build this afternoon. My bellcrank ballstud is hitting the top plate when the steering rack moves to the left, and I don't even have the link ball cup on it yet. Do I have something assembled wrong?
Are you using a Savox servo? Some servos need to have the spacers removed, but then the servo mount screws are too long and you need to use a M3x6 instead of M3x8.
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 10-21-2016, 12:42 PM   #3922
I am using Savox but the servo isn't even installed yet. It's the empty ball stud that's hitting.
Old 10-21-2016, 12:57 PM   #3923
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Take a picture. It should not be doing that at all.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 10-21-2016, 02:49 PM   #3924
Double checked w manual and everything looks like it's put together correctly. I'm wondering if because I don't have the servo mounted yet, the rack won't even travel as far as in the picture where it's making contact.
Old 10-21-2016, 03:12 PM   #3925
Trader Rating: 29 (100%+)
Is the rack upside-down?
DustinEich is offline   Reply With Quote
Old 10-21-2016, 03:25 PM   #3926
No its correct. I put the steering and camber turnbuckles on and it somehow corrected itself. 😳
Old 10-21-2016, 05:11 PM   #3927
Originally Posted by Kraig View Post
Just pickup a set of stick on weights and give each cube a try. If I remember correctly, there is plenty of room under the steering rack to place it.
FYI - you can get these from your local tire shop for pennies practically
Old 10-21-2016, 05:23 PM   #3928
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Originally Posted by BigChris in PA View Post
This may have been asked before, and if so sorry.
What is the weight of the stock plastic bulkhead?
I'm looking for a little more bite in the front, and I'm thinking the brass bulkhead might be too heavy (17.5) and wondering what the weight difference is btwn the stock bulkhead and the Al one.
Thanks in advance.
https://www.teamassociated.com/parts...is_weight_24g/
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 10-21-2016, 05:39 PM   #3929
Eli
Eli's Avatar
FYI - you can these from your local tire shop for pennies practically
You shouldn't be able to if you live in California. Those look like the old lead ones I am assuming that's why they are dubbed that name. Luckily I still have some but not as readily available as they once were.
Eli Westrup - SDRC Raceway
Eli is offline   Reply With Quote
Old 10-21-2016, 06:39 PM   #3930
Jmuck69's Avatar
once the turnbuckles are installed and servo mounted up, it will not throw that far. mine just barely touches the top plate with servo link and everything setup. continue the build and see what happens.
B6D | B64D
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
