    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree360Likes
Old 10-20-2016, 07:29 PM   #3901
Razathorn's Avatar
Originally Posted by Lunchie View Post
why do people run a heavier C mount when theres enough room by it to just stick some weights in there for free?
Same reason they run the laydown—to be cooler than the amount of traction their track has.
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 10-20-2016, 07:44 PM   #3902
Thrifty's Avatar
B6D showing up next week and I want y'all to know I actually read this entire thread...
Just waiting to get my hands dirty figuring out all these lil adjustments...
been running a Tekno SL for the last few months. 2wd, slipper clutch, weight difference?.. all new territory..
Thrifty is offline   Reply With Quote
Old 10-20-2016, 09:24 PM   #3903
Trader Rating: 18 (100%+)
Originally Posted by RookieRacer00 View Post
I just started my build this afternoon. My bellcrank ballstud is hitting the top plate when the steering rack moves to the left, and I don't even have the link ball cup on it yet. Do I have something assembled wrong?
Did you install the 2mm washer under the ball stud like the manual says? If you did just remove it.
Chris Brown is offline   Reply With Quote
Old 10-20-2016, 09:31 PM   #3904
First, I've built the laydown and stand up three gear tranny and ran them back to back and worked on set ups for both. The laydown, if you have the traction, keeps the rear end flatter and let's you drive through the turns better. The stand up tranny does have more overall traction but it feels more like the pendulum effect you had when you compared the old rear motor to the first generation of mid motor cars. Even adding the brass c mount in the landown tranny felt better than the standup. So it's a tuning thing, not necessarily a fad. Yes you can just add weight right in front of the aluminum mount to achieve nearly the same effect. I like the brass mount for having the weight in a consistent location. It's splitting hairs but it makes me feel better when testing that I can duplicate setups more consistently
Old 10-20-2016, 09:35 PM   #3905
Johnn27's Avatar
Trader Rating: 72 (100%+)
Thumbs up
you should watch the review by ShortCourseWorld, Jason on youtube , It was very helpful and informative
Johnn27 is offline   Reply With Quote
Old 10-20-2016, 09:51 PM   #3906
Originally Posted by racer1812 View Post
You plan to mount these on a B5 or B6? You asked in both threads.
As an AE "purist"...keep your K parts off my AE
LOL. I have both cars and they have different rears so that's why I asked in both places.
I've only ever owned AE and TLR...never going back to TLR after this car, it's awesome. Best car I've ever owned.
That being said, both companies shocks always have to have a slight rebound, always to have some "suction" back into the shock, and after being run a few minutes have a squeaky or squishy noise and feel to them. I've been told it doesn't matter but my OCD won't let me believe it. Saw a build video for the RB6 shocks and they seem to be totally "dead" after bleeding from the bottom cartridge. The K shocks are expensive but after buying the kashimas and chrome shafts it's not a big difference.
MrLean is offline   Reply With Quote
Old 10-21-2016, 03:37 AM   #3907
blown sv's Avatar
Originally Posted by Lt hopkins View Post
Can anyone confirm or deny that the b5m puck system will fit b6d
Yes it does fit, the newer packets say B5 B6 , you use these little alloy shims with the B6
blown sv is offline   Reply With Quote
Old 10-21-2016, 05:26 AM   #3908
The manual doesn't call for a washer on the stock plastic parts.
RookieRacer00 is offline   Reply With Quote
Old 10-21-2016, 05:28 AM   #3909
Not under the ballistud that I am referring to anyway...
Old 10-21-2016, 06:24 AM   #3910
This may have been asked before, and if so sorry.
What is the weight of the stock plastic bulkhead?
I'm looking for a little more bite in the front, and I'm thinking the brass bulkhead might be too heavy (17.5) and wondering what the weight difference is btwn the stock bulkhead and the Al one.
Thanks in advance.
Consistent is used in the RC industry as much as Rowdy is used in the mountain bike industry. Truthfully, the only consistent thing is change.
BigChris in PA is offline   Reply With Quote
Old 10-21-2016, 07:12 AM   #3911
SMcD's Avatar
Trader Rating: 61 (100%+)
Overall total shock length is the same for both sets of eyelets. I measured them guys... The difference in length is in the top threaded part of the eyelet. That 5mm ball sits right at the bottom of the shock shaft when fully tightened down with both eyelets. The lower spring retainer moves relatively.
Much ado about nothing.
We Shall See
The Track Raceway, RCRNV, JMR
Team Jacobs Racing
YouTube: looking for turtles entertainment
B6D, X-1 2016, T4 2014 VTA, SCX-10 II
SMcD is offline   Reply With Quote
Old 10-21-2016, 07:26 AM   #3912
jmcelroy42's Avatar
That's because you are not supposed to tighten the eyelet all the way on the shaft. You are supposed to screw them in until you get the stroke it shows in the manual. If you are using the long eyelets and screwing them all the way in until they bottom out you are effectively adding downtravel limiters.
EB48.4 - TEKIN RX8 & SMC 2100
EB410 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 10-21-2016, 07:45 AM   #3913
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Thanks in advance.
Just pickup a set of stick on weights and give each cube a try. If I remember correctly, there is plenty of room under the steering rack to place it.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 10-21-2016, 07:53 AM   #3914
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Your best bet would be to post a picture. Or go through the manual again double checking it again.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 10-21-2016, 08:52 AM   #3915
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
Thinking about picking up another one of these for my daughters to use. I saw someone post about the RPM wide front bumper fitting, how durable are the front arms turning out to be compared to say a b4? (that would be my point of reference)
Just trying to see what I would need to up armor for them.
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Currently Active Users Viewing This Thread: 11 (5 members and 6 guests)
2dialed, Aaron P, jct108, nesbot
