    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree360Likes
Old 10-18-2016, 01:28 PM   #3856
BRSracing's Avatar
Trader Rating: 55 (100%+)
Originally Posted by Wildcat1971 View Post
they are getting harder to find, as AE discontinued them
why would they discontinue the long shock bodies?
BRSracing is offline   Reply With Quote
Old 10-18-2016, 01:33 PM   #3857
mellow's Avatar
Trader Rating: 20 (100%+)
I don't think they've discontinued the Kashima variant
"It'd be a lot cooler if you did."
mellow is offline   Reply With Quote
Old 10-18-2016, 02:42 PM   #3858
JAE
Trader Rating: 28 (100%+)
Does anyone know the effect of having longer or shorter steering plates on the spindles? EX: Steering block turnbuckle is either has a shortened or lengthened distance from the steering plate. There are aftermarket ones for sale from numerous brands. it would change ackerman. I have another buggy where if the blocks are shortened (smaller lengthening the turnbuckle length) steering gets much more aggressive. However there are ones sold for the b6 that purport steering gets more aggressive with longer carbon steering blocks where the turnbuckle is effectively shorter (ballstud hole closer to servo)?
JAE
JAE is offline   Reply With Quote
Old 10-18-2016, 02:48 PM   #3859
Regional Moderator
RobsRacin's Avatar
Im not sure about the ones for the B6, but on the XB2 the steering blocks get shorter and allow the spindle to turn more before hitting on the inside and being at full lock. The B6 looks different in that it doesn't have the same design of a stop, but on the XB2, essentially a longer link(achieved by having a shorter steering block) makes for more steering and make it more aggressive.
YMMV
RobsRacin is offline   Reply With Quote
Old 10-18-2016, 03:15 PM   #3860
Trader Rating: 8 (90%+)
YMMV
From Schelle: The increased Ackermann makes the inside wheel turn in quicker, giving more front end grip through tight turns.
Johnny Carey is offline   Reply With Quote
Old 10-18-2016, 04:58 PM   #3861
Trader Rating: 15 (100%+)
with the J concepts axles, what will be the difference if I put the included 1mm spacers on the inside vs. outside of the steering block?
motoman811 is offline   Reply With Quote
Old 10-18-2016, 05:50 PM   #3862
Trader Rating: 32 (100%+)
I installed carbon steering arm TYPE-1 from schelle seems I got more aggressive steering in corner than stock.
raved007 is offline   Reply With Quote
Old 10-18-2016, 06:20 PM   #3863
Will the tires from my rb6 fit on a new b6d kit?
pabstman06 is offline   Reply With Quote
Old 10-18-2016, 07:50 PM   #3864
The B6D kit doesn't come with wheels, but both the rb6 front and rear wheels will fit and take the same size tires.
mushroomed is offline   Reply With Quote
Old 10-18-2016, 08:15 PM   #3865
Thank you.
Old 10-18-2016, 08:45 PM   #3866
My B6D kit almost done to build any good set up for blue grove low to medium traction? Thanks.
Old 10-18-2016, 08:47 PM   #3867
JAE
My car pushes with kit setup and that's the only difference I can see. Will try without them. To robsracin's point they have the opposite orientation of what the X-ray type steering arms have for increased steering ... Guess you would know if you've tried both
Old 10-18-2016, 08:54 PM   #3868
sport10's Avatar
Originally Posted by SMcD View Post
I have gone laydown trans on dirt kit. Got the Trifecta wing and just don't want to cut/shape it around the rear rear mounted shocks, so flipped them to the front of the tower/arm.
Did one at a time (left one behind the tower and moved one to the front). Noticed no difference in the rear geometry from one side to the other under compression and droop. Why do we change the eyelets (I just left them the same for now until I get an answer)? I can see the difference if I make a large change in anti-squat, but that isn't the case for now... Thanks
Front what I understand it has something to do with keeping the roll center the same. The difference between the two eyelets is 2mm.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 10-18-2016, 09:22 PM   #3869
Balony's Avatar
Send a message via ICQ to Balony Send a message via AIM to Balony Send a message via Yahoo to Balony
Using the short eyelet on the front keeps the droop the same as a long eyelet on the rear due to the front is raised due to the anti squat that is built in to the rear mount.
Balony is offline   Reply With Quote
Old 10-19-2016, 02:33 AM   #3870
I have a B5m thats fully tricked up, not really worth anything here in UK, I know that the schelle rear hubs will fit but I lose axle height adjustment
also looking at it I have ally rear wing mounts, but they would move the wing 10mm forwards,
is this likely to be an issue?
just trying to save parts from waste on the B5m and upgrade the B6 without spending a fortune again LOL
TonyCooperUK is offline   Reply With Quote
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
