    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree360Likes
Old 10-09-2016, 09:13 PM   #3661
Phillip F's Avatar
Trader Rating: 17 (100%+)
So the race today was good. I finally broke a front shock tower. It snapped right at the inner hole. kA few weeks ago... I broke the rear shock tower when an SC truck decided to plow behind me during practice. Looks like I'm getting the aluminum shocks now as spares.
Phillip F is offline   Reply With Quote
Old 10-09-2016, 09:45 PM   #3662
Eli
Eli's Avatar
Originally Posted by raved007 View Post
OK guys my B6D is on the way with lay down transmission order too our local track is mid/high grip my question which one to be run 3 gear stand up or 3 gear lay down. any input kindly appreciated. RJ
What are other people running at your track? Pretty much everyone went to laydown at my local track (SDRC) and went faster.
Eli is offline   Reply With Quote
Old 10-10-2016, 09:06 AM   #3663
sport10's Avatar
Originally Posted by bmag5000 View Post
I actually thought it would handle terrible with a stick pack.
Now if I got the laydown transmission I'd have to run a shorty.
Now granted I raced it on dirt oval and not offroad.
I think if you ran the laydown shorty combo you would change you mind. That stick pack makes your buggy heavy in comparison. You can also mount your shocks in front of the tower to keep more weight forward for better steering with the laydown tranny. Plus, I would not mount my electronics on top of my pack either unless you built a shelf to elevate them. What are you going to do if you have to dispose of the battery quickly. It can happen and I would not temp murphy IMO.
Also noticed that the custom works you are competing with use an offset battery. You going to have a hard time competing with that on a oval. I remember using tc3 chassis with offset battery mod in late model and they were scalding fast on the hardpack oval we ran. Might have to upgrade to compete is all I am saying.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 10-10-2016, 09:35 AM   #3664
If it doesn't work out for me and we get offroad back here(not getting my hopes up), i'll paint the body it came with and use it for offroad like it was intended.
I think your right and I'm wasting my time using an offroad car for oval racing.
But if a slim chance I do end up getting a few wins with this ill be happy.
Associated B6 "Dirt Version" latemodel, Team Losi Racing 22T 2.0 Bomber Truck.
Team Losi Racing 22 2.0 2wd Short Course Truck,Duratrax 835e Brushless 8th scale Buggy,
Stock Slash, B4.1 latemodel(retired), T4.2 Factory Team BOMBER CAR
Castle Creations( Since April 2016)
bmag5000 is offline   Reply With Quote
Old 10-10-2016, 10:43 AM   #3665
Trader Rating: 138 (100%+)
Cheap CF or design flaw?
TLR 22T 3.0, 2X Yokomo YZ-2 DTM, B64D (Temporary 4 wheel) YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is online now   Reply With Quote
Old 10-10-2016, 10:48 AM   #3666
Hah...same thing yesterday. Front shock tower broke <2 hours of use. I 100% believe it's a design flaw. X Factory makes one with the exact suggestions I was planning on designing and cutting myself. https://www.amainhobbies.com/x-facto...fci120/p525765 or https://www.amainhobbies.com/x-facto...fci121/p525766
LVNeptune is offline   Reply With Quote
Old 10-10-2016, 11:41 AM   #3667
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
so of the aftermarket shock towers out now in the gullwing design, which appear to be the most durable outside of the VRP ones?
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 10-10-2016, 11:43 AM   #3668
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
I have had zero issues with the Schelle towers....I had zero issues with the stock towers too though...
freezeframe007 likes this.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 10-10-2016, 12:23 PM   #3669
Just spray your carbon fiber with Flex Seal Clear!
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 10-10-2016, 03:22 PM   #3670
Phillip F's Avatar
you must be a really good driver.
Old 10-10-2016, 03:43 PM   #3671
Tech Legend
Cain's Avatar
lol I actually have that stuff sitting here.
Old 10-10-2016, 05:58 PM   #3672
Super Moderator
I have also seen zero issues with the stock towers. Club days have 40-50 buggies with a good portion of those being b6's. You must need some practice instead of spending money on hop ups....
Old 10-10-2016, 06:01 PM   #3673
Really the main complaints with this are just the towers....Everything else is peachy. Mine snapped during practice with less than 2 hours on it on a less than spectacular crash =/
Old 10-10-2016, 06:13 PM   #3674
buckeye dan's Avatar
anyone try VRP aluminum towers?
Buckeye Dan
buckeye dan is offline   Reply With Quote
Old 10-10-2016, 06:28 PM   #3675
I'm a crappy driver and have yet to break my shock towers.
Scargoes is offline   Reply With Quote
Currently Active Users Viewing This Thread: 9 (3 members and 6 guests)
Jwilliams5, Mason, rp180sx
