    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree366Likes
Old 10-06-2016, 11:18 AM   #3586
nodrog's Avatar
hey guys, I'm mid build and I may or may not bomb you guys with more questions
but for now until I can figure out what electronics I want I'm going to try a VXL 3S to get moving, can someone recommend what spur/pinion? Specs say it's a 10T 3500Kv. I was thinking a 19/78
nodrog is offline   Reply With Quote
Old 10-06-2016, 11:52 AM   #3587
SMcD's Avatar
Trader Rating: 61 (100%+)
Originally Posted by Cain View Post
I actually recall a discussion years ago with someone at AE (called in for a charger issue, yeah that long ago) and they mentioned something about if you put the screw on the wrong side the diff could potentially "spin open". It mainly came up towards the end as I was curious why I was tightening down my diff more than I thought I should have been. I flipped it to the correct "side" and no issues afterwards.
however, on the truck version I didn't have the issue, so it could have just been that nut and bolt. So who knows, maybe its more so when things are worn to watch for.
Right now debating getting the gear diff. I have the pucks based on what came with my vehicle, but ball diff installed from what I can tell. Is there any place that has the MIP outdrives specific for the gear diff in stock?
3 gear-same side. 4 gear-opposite side. Makes a difference, and diffs will loosen themselves not only on this car. But, whatever
We Shall See
The Track Raceway, RCRNV, JMR
Team Jacobs Racing
YouTube: looking for turtles entertainment
B6D, X-1 2016, T4 2014 VTA, SCX-10 II
SMcD is offline   Reply With Quote
Old 10-06-2016, 12:23 PM   #3588
Jmuck69's Avatar
Trader Rating: 14 (100%+)
For the diff screw issue. Set to what you want and then put a small amount of JB Weld on the diff screw head. It will lock it in.
...JK
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 10-06-2016, 12:25 PM   #3589
mdwaeracer's Avatar
Trader Rating: 19 (100%+)
doesnt make sense. Rb5 vs b4.1 both rear motors both ball diffs. screw on opposite sides. doesnt matter in my opinion
TEAM ASSOCIATED Rc10, rc10B6D ,FUTABA , TEAM ORION, KYOSHO RB6.
mdwaeracer is offline   Reply With Quote
Old 10-06-2016, 12:26 PM   #3590
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
This argument could last pages and pages...Do whatever you want and call it good.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 10-06-2016, 01:19 PM   #3591
tsair's Avatar
Open up your toilet and see which way it flushes. If it's clockwise, you have to put it on motor side. Counter-clockwise, slipper side.
I used up all my JB Weld on my DIY "slipper eliminator". Will shoe goo work?
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 10-06-2016, 01:45 PM   #3592
Jmuck69's Avatar
yes, it will "give" a little more and reduce torque steer.
B6D | B64D
Old 10-06-2016, 01:46 PM   #3593
Not sure that Northern Hemisphere vs. Southern Hemisphere really makes any differences for mounting a screw O_o
LVNeptune is offline   Reply With Quote
Old 10-06-2016, 02:07 PM   #3594
tsair's Avatar
Razor RC blog:
Old 10-06-2016, 02:18 PM   #3595
Yanks213x's Avatar
I just dabbed the JB weld in there. Can't wait to see how that works.. Thanks for the advice!!!
B6D (more like a b6) - Reedy 17.5 SS Mach 3, SC5M
Island Raceway and Hobby - Long Island
Support your local hobby shop!!
Yanks213x is offline   Reply With Quote
Old 10-06-2016, 03:52 PM   #3596
awtwac's Avatar
Originally Posted by Phillip F View Post
Google Jake Mayo setup for scvrc track
Tried that, both w/ Google and on here. Nada. Only gear diff setup I see from him is for carpet, from the AE website. Any chance someone could point me in the right direction? Thanks in advance.
awtwac is offline   Reply With Quote
Old 10-06-2016, 03:56 PM   #3597
Super Moderator
There are quite a few setups listed here: http://site.petitrc.com/setup/associ...tedRC10B6.html
But not many use a gear diff on dirt.
Old 10-06-2016, 05:34 PM   #3598
thecman26's Avatar
Trader Rating: 99 (100%+)
Originally Posted by racer1812 View Post
Because people need them to hold their hand and tell them what to do. Previous AE manuals didn't specify which way to put the diff in, because it doesn't matter. A million people then asked "which way does my diff go in?" Now, they just tell you which way to put it in so people stop asking.
B5,B5M, & B4.2 manual says which side to put it on. I am pretty sure they were designed to be places on a specific side, too bad there's no AE design team support on here. I am sure every other AE manual I have seen also says which side it should be on. But neither here nor there... I haven't decided to go rogue and test out what would happen if I was a rebel and put it on the other side...
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 10-06-2016, 05:41 PM   #3599
Originally Posted by bru00z View Post
Make sure you used the correct length screws for the transmission through the chassis. Think its meant to be 8mm. I had 1 10mm by accident and it hit the diff!
Same here, 1 of the screws in the bag that bolt the tranny down was 2 mm longer than it was suppose to be and it went thru the tranny case and hit the diff gear.
roysays is offline   Reply With Quote
Old 10-06-2016, 05:52 PM   #3600
awtwac's Avatar
Thanks, but I did come across that page already. Looks like none of them tried to make the gear diff work on dirt/clay. Messaged received loud and clear...
Currently Active Users Viewing This Thread: 10 (1 members and 9 guests)
Serzoni
