    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree372Likes
Old 10-03-2016, 06:29 PM   #3541
AZJP's Avatar
Trader Rating: 20 (100%+)
A light mod car is a handful to drive, and the setups wont be exactly the same..most notably the shock package.
AZJP is offline   Reply With Quote
Old 10-03-2016, 07:08 PM   #3542
So the stock car should have a lighter shock package?
hyperdive08 is offline   Reply With Quote
Old 10-03-2016, 07:40 PM   #3543
AZJP's Avatar
A lighter car will have a softer shock package, as it has less weight to suspend.
Old 10-03-2016, 09:29 PM   #3544
Originally Posted by mushroomed View Post
Hi Lunchie,..
I found Tony Phalen's build guide helpful for building my B6D. I found this similar guide for the B6D by Joe Navarro.
many thanks for those links! theyll come in handy for sure.
Lunchie is offline   Reply With Quote
Old 10-04-2016, 03:00 AM   #3545
Would it also be wise to lower shock oil as well in a 17.5 car,vs a mod car?
Old 10-04-2016, 04:36 AM   #3546
i REEEAAAALLLYYY want team bluegroove to make a B6 body just like this TLR22 one. i love this body on my 22...
Old 10-04-2016, 06:31 AM   #3547
Trader Rating: 24 (100%+)
What size Front Wheels are they? The Schumacher tires look to fit them really well
Associated B6 x2
Associated B64D
Associated B64
Associated T5M
Scott R is offline   Reply With Quote
Old 10-04-2016, 12:36 PM   #3548
Theyre just jconcepts mono cut down one groove on the inside edge
Old 10-04-2016, 12:53 PM   #3549
Are they 2.2" They look Taller for some reason
Associated B6 x2
Associated B64D
Associated B64
Associated T5M
Old 10-04-2016, 02:22 PM   #3550
awtwac's Avatar
Anybody running the gear diff / B6 with any success on indoor mid/high bite clay? Was hoping to make this work since I enjoy the low maintenance that comes with a gear vs ball diff.
awtwac is offline   Reply With Quote
Old 10-04-2016, 03:50 PM   #3551
yes 2.2 just the perspective on the phone camera
Old 10-04-2016, 05:24 PM   #3552
RCBuddha's Avatar
Trader Rating: 35 (100%+)
via facebook:
http://www.liverc.com/news/new_produ...or_the_RC10B6/
http://www.redrc.net/2016/10/rdrp-b6...s/#more-120259
RCBuddha is offline   Reply With Quote
Old 10-04-2016, 06:28 PM   #3553
Eli
Eli's Avatar
whens the 6.1 coming out?
Eli Westrup - SDRC Raceway
Eli is offline   Reply With Quote
Old 10-04-2016, 06:56 PM   #3554
Phillip F's Avatar
Trader Rating: 17 (100%+)
Google Jake Mayo setup for scvrc track
Phillip F is offline   Reply With Quote
Old 10-04-2016, 11:04 PM   #3555
This has been shipping for <90 days you think they are going to release upgraded hardware already?
LVNeptune is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Karma2190
