    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree323Likes
Old 09-29-2016, 10:13 AM   #3481
Eli
Eli's Avatar
Originally Posted by jabroni racing View Post
I got it now everyone, Thanks, I totally didnt even consider if it would fit... Guess i will try it & see..
A dremel could do wonders in the right hands.
freezeframe007 likes this.
Eli Westrup - SDRC Raceway
Eli is offline   Reply With Quote
Old 09-29-2016, 10:21 AM   #3482
It does actually prevent delamination in crashes. I usually seal the edges with CA to prevent on my racing drones otherwise on 60mph+ crashes it will delaminate, and those frames are straight CF.
LVNeptune is offline   Reply With Quote
Old 09-29-2016, 10:49 AM   #3483
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
I had issues trying to run certain gearing combos with my B5 (17.5). Motor plate slots weren't the issue, motor hitting the gear box was. Mr. Dremel wasn't fixing that.
Maybe the B6d is different? IDK
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 09-29-2016, 10:56 AM   #3484
Super Moderator
racer1812's Avatar
Originally Posted by mellow View Post
I agree, regardless if it does anything or not; I do think it looks better when you glue and sand the edges. Of course it's all about looks right
I sand/smooth/round the edges.. "color" the edge with a black Sharpie, then CA.
Result, crazy sexy black shiny CF edges...I get more chicks since AE went to CF towers
(my wife reads this, rollers her eyes and sarcastically says "you're an idiot").... shes right, as always
Old 09-29-2016, 11:00 AM   #3485
mellow's Avatar
Trader Rating: 19 (100%+)
Hahahaha. They are much sexier after a good color, glue and sand though
"It'd be a lot cooler if you did."
mellow is offline   Reply With Quote
Old 09-29-2016, 11:43 AM   #3486
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Did we marry sisters?
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 09-29-2016, 11:51 AM   #3487
Super Moderator
racer1812's Avatar
For your sake..I hope to God not because my sister in-law is an absolute......well lets not say.
Old 09-29-2016, 11:56 AM   #3488
Let's try to stay on topic .........
Sorry - couldn't resist
belewis01 is offline   Reply With Quote
Old 09-29-2016, 12:00 PM   #3489
Super Moderator
racer1812's Avatar
Well most certainly. What B6/B6d topic should we find most relevant to discuss my fine Sir?
All in good fun my friend
Old 09-29-2016, 12:05 PM   #3490
Tech Legend
Cain's Avatar
Trader Rating: 235 (100%+)
Looking to do a teardown and rebuild this weekend to prep for upcoming races.
For you "long time" owners, are there any areas I should keep an eye on when doing rebuild that you see specific to the B6/B6D?
Also, for the chassis protector sheets are you guys running the screws through them so you can still get access to remove things or pulling them when needed?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL | Yokomo YZ-2 DTM x 2>
Old 09-29-2016, 12:08 PM   #3491
Worn outdrives.
Old 09-29-2016, 12:08 PM   #3492
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Ball cups to tight?
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 09-29-2016, 12:15 PM   #3493
Tech Legend
Cain's Avatar
spoke with rep from amain they are looking to carry the rest of the VRP towers soon.
Maybe someone can laymen terms explain what you gain with the VRP towers with the outer hole removed and what conditions is it best for?
Old 09-29-2016, 12:16 PM   #3494
Trader Rating: 49 (100%+)
Can someone post their radio settings for the b6d. Specifically talking about the airtronics/sanwa m12s
Thanks to my sponsors:
My Credit Card
Speedychris22 is online now   Reply With Quote
Old 09-29-2016, 12:46 PM   #3495
Super Moderator
racer1812's Avatar
Originally Posted by Kraig View Post
Ball cups to tight?
No, seemingly every ball cup issue was alleviated when Wild Cherry left.
Crazy huh
Currently Active Users Viewing This Thread: 10 (4 members and 6 guests)
Dragon01826, jmcelroy42, Still Bill, TruggyStyle
