    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree323Likes
Old 09-28-2016, 04:00 PM   #3466
I want to get a car for dirt and commercial carpet. considering getting a 6d then converting to b6. What is needed ? 2 cars is not a option. I figured arms and towers and diff housing and parts.
Team Associated, JConcepts, M2C Racing, Big Pimpin Paints
Chris Reilly is offline   Reply With Quote
Old 09-28-2016, 06:12 PM   #3467
Trader Rating: 18 (100%+)
It's front arms, front tower, motor plate, gearbox, idler gear, and chassis brace. And differential of course.
Chris Brown is offline   Reply With Quote
Old 09-28-2016, 09:26 PM   #3468
Front arms and tower are not mandatory, the real difference is ball diff and standup tranny
MatthieuL is offline   Reply With Quote
Old 09-29-2016, 06:40 AM   #3469
jabroni racing's Avatar
Trader Rating: 37 (100%+)
Send a message via Yahoo to jabroni racing
I have a General tranny question.3gear trans, I plan on racing both 17.5t class and mod class, probably a 7.5t for example purposes. If i leave the 69 spur for the 17.5 setting per manual gear chart, can i just use a lower pinion for the 7.5 and if so, is there a difference is how the car will feel with the smaller pinion & spur for the mod?? formula i used was tranny 2.60x69(spur) divided by pinion(18) i came up with 9.96 any insight would be greatly appreciated..
www.facebook.com/jay3638
jabroni racing is offline   Reply With Quote
Old 09-29-2016, 06:51 AM   #3470
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I have always used spur/pinion * 2.6.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 09-29-2016, 06:55 AM   #3471
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
I'm not sure you'll get a small enough pinion to fit/work for a 7.5/8.5 motor running a 69t spur gear.
Normal 7.5 gearing (for me) is ROUGHLY..81/20 = 4.05
To get that same ratio with a 69t spur you would have to run a 17t pinion..
69/17 = 4.058
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 09-29-2016, 06:58 AM   #3472
Super Moderator
racer1812's Avatar
Only time I take the time to factor in the tranny ratio is if I'm talking to an "outsider"...you know, those TLR and Kyosho guys.
*cough cough, Kraig *
Old 09-29-2016, 06:59 AM   #3473
the book says 21/78 for 7.5t = 9.65, so if im running 18/69 & get 9.96 its just a hair higher
Old 09-29-2016, 07:01 AM   #3474
69/17 = 4.058
I get it, you mean actually fit due to motor clearance and small pinion.. Got cha..
Old 09-29-2016, 07:05 AM   #3475
Super Moderator
racer1812's Avatar
My point was, and the real question is, while that combination physically fit? I'm not sure you can get the motor close enough. All you can do is try it and see.
If it fits, run it. If you're mortal like the rest of us, you'll never feel the difference between 78/21 and 69/18 on the track.
But it will move the motor farther back and maybe you'll notice that in terms of handling.
Old 09-29-2016, 07:08 AM   #3476
Super Moderator
Kraig's Avatar
Kyosho 2wd cars have the same internal ratio but I do appreciate making it easier for me.
Old 09-29-2016, 07:22 AM   #3477
mdwaeracer's Avatar
Trader Rating: 19 (100%+)
Sometimes the motor wont slide far enough to get the proper gear mesh with the 69 spur and the smaller pinion.
TEAM ASSOCIATED Rc10, rc10B6D ,FUTABA , TEAM ORION, KYOSHO RB6.
mdwaeracer is offline   Reply With Quote
Old 09-29-2016, 07:33 AM   #3478
Super Moderator
racer1812's Avatar
Originally Posted by liljohn1064 View Post
Shock towers breaking: to reiterate, near razor sharp edges cut carpet, dig into dirt and clay and will snap when your buggy comes to a dead stop. I have a horizontal crack in my tower from just such a crash.
Solution: Mildly take down the sharp edges with emery cloth, cover with a Lexan shock tower cover or shock tower protectors, use wide washers and/or countersunk washers for strain relief on the shock mounting hole. You can seal with CA if you like, but not needed once the edges are smooth.
I agree. Sealing the edges on todays CF is basically cosmetic..But for the love of God people that crap is sharp! I sand ALL the edges on all of my CF parts, not just the outside edges. I do all the internal holes/cutouts. I just makes handling the car easier, you don't feel like you're picking up a knife by the blade...so to speak
Old 09-29-2016, 08:20 AM   #3479
I got it now everyone, Thanks, I totally didnt even consider if it would fit... Guess i will try it & see..
Old 09-29-2016, 09:18 AM   #3480
mellow's Avatar
I agree, regardless if it does anything or not; I do think it looks better when you glue and sand the edges. Of course it's all about looks right
"It'd be a lot cooler if you did."
mellow is offline   Reply With Quote
Currently Active Users Viewing This Thread: 9 (2 members and 7 guests)
Dragon01826, jmcelroy42
