    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree369Likes
Old 09-27-2016, 11:46 AM   #3436
mellow's Avatar
Trader Rating: 20 (100%+)
Couple questions on rear track width and ackermann angles...Noticed a lot of setup sheets people are running 1mm shims on the bellcrank and 6mm rear hexes.
For the ackermann will that just make the car react to steering input quicker?
In regards to the 6mm hexes; Is a narrower track width going to make the rear end of the car rotate easier or will it have the opposite effect?
"It'd be a lot cooler if you did."
mellow is offline   Reply With Quote
Old 09-27-2016, 01:01 PM   #3437
sport10's Avatar
Traction looks to be pretty good there and saw someone traction roll too. I have also compared my jconcepts pin downs to losi ifmar pins and thought that would be an good alternative and might not require sauceing. Try cleaning the slicks with brake cleaner before sauceing. That was the hot setup at a local track here that ran ozite a little while back. Maybe try the jconcepts swaggers in the front if allowed.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 09-27-2016, 01:15 PM   #3438
Going to be building my first car (come from drone racing) and decided on picing up the B6 (same as a friend). He swears up and down it only runs shorty batteries but on Amazon, Hobby Town, AMain, etc., the specs pages say they can run shorty, saddle, and square. He says they will fit the B6D but not the B6. My understanding is the B6D frame is essentially the same with a different powertrain config and front/rear, doesn't make sense to me.
I checked the manual and it lists "LiPo 50C 5200mAh 7.4V SQ" as being compatible and dimension-wise the square pack and saddle packs look almost identical if you double up one.
LVNeptune is offline   Reply With Quote
Old 09-27-2016, 01:23 PM   #3439
Trader Rating: 24 (100%+)
The B6 has the Laydown gearbox. The motor takes up part of the Battery area, thats why you can only run shorty packs in a B6
Scott R is offline   Reply With Quote
Old 09-27-2016, 01:24 PM   #3440
Wow, so he was right about that. That's a bit disappointing because that means all resellers have bad specs listed including the B6 manual =/
Am I the only person to notice this/bring this up?
Also there are separate manuals for both the B6 and B6D and specifically the B6 says it can run that Reedy 5200 square pack.
Old 09-27-2016, 01:35 PM   #3441
Just run shorty batteries and you'll never have to worry about anything.
Team Associated / Reedy / JConcepts / BoomRC
boucher is offline   Reply With Quote
Old 09-27-2016, 01:38 PM   #3442
I get that but if it's being incorrectly advertised as supporting something that it can't run that's an issue in itself.
Old 09-27-2016, 01:44 PM   #3443
Technically "both cars" (because it's the same car in different configurations) can run a square battery. You'll just need to run the stand up transmissions in order to do so.
Old 09-27-2016, 01:45 PM   #3444
mellow's Avatar
They're the same chassis. Technically you can run it on a B6..just have to change the tranny.
Old 09-27-2016, 01:47 PM   #3445
I kind of figured that since they were the same. It's not a huge deal but the marketing/manuals definitely need to be updated to reflect that.
Old 09-27-2016, 01:48 PM   #3446
Derry's Avatar
Trader Rating: 27 (100%+)
You could also remove the waterfall and probably run a square pack with the lay down tranny. Never tried but probably would fit.
Associated B64D
Associated B6D
Derry is offline   Reply With Quote
Old 09-27-2016, 01:49 PM   #3447
You can move a shorty further aft, but I don't think it gives enough room for a full square pack. I could be wrong. But seriously, just run shorty batteries. Who uses square packs?
Old 09-27-2016, 02:13 PM   #3448
Why are guy insisting on using laydown trans on dirt and not stand up ?
Futaba - Nitro king -
Rc is fun
Rcfun96 is offline   Reply With Quote
Old 09-27-2016, 03:02 PM   #3449
If anyone cares, I just got the official response from Team Associated:
"The B6 and B6d uses the shorty pack as the primary. If you want to use either Saddle or Square packs, then you will need to remove/not use the battery strap #91731 and keep the batteries in by using a good brand of 2-side tape. Like 3M!"
Old 09-27-2016, 03:20 PM   #3450
MikeR's Avatar
Trader Rating: 15 (100%+)
They used to say the same thing when guys ran mid motor instead of rear motor on dirt tracks...
Part of racing is pushing the envelope...
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
05PSD, EonNeon
