    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree369Likes
Old 09-21-2016, 12:51 AM   #3316
Woulvesbaine's Avatar
Originally Posted by Allen Drebi View Post
Try this. Very smooth reliable and faster. I have it in two of my cars and no issues
https://www.amainhobbies.com/protek-...-160ss/p273487
Thanks!
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
Old 09-21-2016, 12:52 AM   #3317
Originally Posted by Wildcat1971 View Post
I have one. It developed the shakes.
Eek. That's no good.
Old 09-21-2016, 07:03 AM   #3318
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
my protek 130ss has been really solid for a few years. I would try the 160T if I were to get another one.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 09-21-2016, 07:35 AM   #3319
Brad S.'s Avatar
Trader Rating: 39 (100%+)
Originally Posted by M2126 View Post
Anyone know the weight difference from the regular stock body and the light weight version from team associated?
14 grams
~Brad Shearer~
Team Associated ~ Motiv ~ JConcepts ~ Team Gravity RC ~ MIP ~ 92zerodesigns.com ~ Shearer-It Paint Designs ~ LiveTime Scoring ~ LiveRC.com
Brad S. is offline   Reply With Quote
Old 09-21-2016, 07:40 AM   #3320
abailey21's Avatar
Trader Rating: 36 (100%+)
One of the best servo's I've used, I plan on picking more up for other projects
K.C.C.O.
abailey21 is online now   Reply With Quote
Old 09-21-2016, 07:46 AM   #3321
Originally Posted by QDRHRSE View Post
I'm not sure the laydown is your best bet for medium grip. I. myself, like the b6d better when there's not a lot of traction. Since that doesn't answer your question I'll tell you what others at our track have done. (1) you can swap to the flat arm front, run softer springs, and add droop or (2) one guy runs the B6 close to box stock but with white/white springs and that seems to work for him. I'm not sure what minor changes he made but he did something with the rear link height.
I do have the D, but was hoping to find a setup to make the laydown tranny work on medium grip. Goal being to carry as much corner speed as possible while still having enough grip. I know people are doing it, just wondered if anyone had come up with a setup that works well in this situation
Sean B. is offline   Reply With Quote
Old 09-21-2016, 09:13 AM   #3322
Trader Rating: 18 (100%+)
If you're looking for more grip with the laydown tranny, try 3x1.4 pistons in the rear, mount the rear shocks on the back of the arm, and use the 25 gram c block. That should help out quite a bit.
Chris Brown is offline   Reply With Quote
Old 09-21-2016, 09:51 AM   #3323
tsair's Avatar
Originally Posted by Brian Bosley View Post
I just measured this on Sunday, 3.2mm is correct for the b6d.
Thanks!
tsair is offline   Reply With Quote
Old 09-21-2016, 12:18 PM   #3324
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Ericc View Post
Why do I see so many b6s and b6ds with titanium screws. Do they make that much of a difference?
Top reason to run Ti screws..
1) You're prepping for the Stock Nationals and can actually make the A main.
2) You're prepping for the Stock Nationals and think you can benefit from Ti screws.
3) You're like most people and like shiny bling parts that don't make you faster but look cool.
Most people fall under #2 and #3. Those who fall under #1 are immortal, get them for FREE, and are likely PAID to run them.......
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 09-21-2016, 12:41 PM   #3325
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
I can verify that I have titanium screws on my car for reason number 3....and I got them at a great price.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 09-21-2016, 12:55 PM   #3326
Super Moderator
racer1812's Avatar
And there's nothing wrong with #3. It's a hobby, it's for fun, shinny stuff is cool, we all like cool shinny stuff.....But some will still claim to fall under #1 and post like a Pro......you ain't foolin' anyone Bro
Old 09-21-2016, 12:59 PM   #3327
Super Moderator
It saves a little bit of weight....it also resists rusting if you race in high humidity environments....it looks cool.
Are they needed? No.
Will they make you faster? Doubtful.
Old 09-21-2016, 01:09 PM   #3328
mellow's Avatar
Trader Rating: 20 (100%+)
I think the rust resistance is the best part. What ti screw kit are most people going with? You've got ZZ racing at the lowest price point, then the next step up is FT Associated and Protek followed by Lunsford and Schelle.
"It'd be a lot cooler if you did."
mellow is offline   Reply With Quote
Old 09-21-2016, 01:11 PM   #3329
Super Moderator
racer1812's Avatar
The posting like a Pro part wasn't directed at you bud
Fact is, the B6 cars are light enough out of the box with standard electronics that most are under legal weight as it is. There's little to no need to run Ti screws for the sole purpose of saving a couple grams on the scale.
If you run Mod and are looking at Ti screws..save the money and buy some tires.
Running Stock and looking at Ti screws..I would say the same, buy tires instead. But I could also rattle off a long list of other items to spend money on that would be better bang for the buck...
IMO
Old 09-21-2016, 01:14 PM   #3330
Super Moderator
I had the associated and protek kits on some of my 5 series cars...price was decent but the quality could have been better. I am using the Schelle now and have had zero issues with them. I think we would all like to have Lunsford but I also like to eat and have a roof over me.
G the Menace likes this.
Currently Active Users Viewing This Thread: 4 (3 members and 1 guests)
05PSD, EonNeon
