    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree363Likes
Old 09-16-2016, 12:47 PM   #3256
onefast8's Avatar
Trader Rating: 41 (100%+)
Originally Posted by mellow View Post
Here's the snippet from the wiki for other fitments depending on what tower you're using. Fronts are the same.
Q: What Kashima shock bodies do I need for the B6/B6D?
A: For the front, you will need #ASC91576 12x23mm Buggy V2 Front Shock Body
For the rear, you will need #ASC91577 12x27.5mm Truck V2 Front Shock Body
For the rear, you can also buy #91666 B6 Rear Shock Tower (Long)
and #ASC91578 Buggy V2 Rear Shock Body
So basically, B5M fronts and Truck Rears if you want to be same as kit form. Or, 31mm rears if you want to use the long tower.
..also the Schelle rear tower that uses the long bodies and short eyelets that gives a lower tower than the other options for long shock bodies, if I'm understanding correctly.
Jake R.
onefast8 is offline   Reply With Quote
Old 09-16-2016, 12:49 PM   #3257
mellow's Avatar
Trader Rating: 20 (100%+)
So many options!
"It'd be a lot cooler if you did."
mellow is offline   Reply With Quote
Old 09-16-2016, 12:55 PM   #3258
aeRayls's Avatar
Truck fronts NOT rears
aeRayls is offline   Reply With Quote
Old 09-16-2016, 12:57 PM   #3259
mellow's Avatar
Thanks for catching that. Fixed.
Old 09-16-2016, 01:10 PM   #3260
onefast8's Avatar
Whats everyone using for battery brace hold down nuts other than the kit stuff?
I was considering these: https://www.amainhobbies.com/exotek-...191blk/p469202
Jake R.
Old 09-16-2016, 01:14 PM   #3261
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Those may be too thick/tall and would rub the body. I use either the stock nuts or a thin m3 locknut.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 09-16-2016, 01:16 PM   #3262
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
yeah, might rub the body. not really a big deal to use a 7mm driver...we always have one out anyway for tires
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 09-16-2016, 01:16 PM   #3263
I honestly would not mind a body clip version of the mount. just not as sexy
Old 09-16-2016, 01:17 PM   #3264
onefast8's Avatar
Oh good point, haven't even cut my body out yet to check fitment. Thanks for the heads up!
Jake R.
Old 09-16-2016, 01:21 PM   #3265
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
Originally Posted by Wildcat1971 View Post
I am not a fan of the VRP products. And I have no plans to put an aluminum tower on my cars. But if you like their stuff go for it. Raw speed and factory RC look to have good tower upgrades for the b6
Any opinion on diggity designs? used there stuff in the past so curious they are any good still.
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 09-16-2016, 01:24 PM   #3266
I have not tried them. Does not look like an more material added. Could be a better CF. If you have liked them before, I say stick with what you like
I made an aluminum brace for my AE tower.....but no need to talk about that again, lol
Old 09-16-2016, 01:32 PM   #3267
Trader Rating: 15 (100%+)
With the long tower, do we use the long eyelits?
motoman811 is offline   Reply With Quote
Old 09-16-2016, 01:35 PM   #3268
Super Moderator
With the AE tower you build it exactly as you would with the short tower. Shock on the back = long eyelets. Shocks on the front = short eyelets.
The Schelle in between tower you would use short eyelets.
Old 09-16-2016, 01:38 PM   #3269
onefast8's Avatar
I ordered the xfactory towers from amain as backups. They look pretty nice and have a little more material in some areas. I have yet to run them so I cant comment on any improvement over stock. I would have preferred to get the factory rc towers but who knows when they will actually have them is stock.
Jake R.
Old 09-16-2016, 01:48 PM   #3270
Trader Rating: 138 (100%+)
Not as sexy, but definitely easier to deal with.
TLR 22T 3.0, 2X Yokomo YZ-2 DTM, YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
