    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree366Likes
Old 09-07-2016, 10:38 PM   #3091
JsK
JsK's Avatar
Whatever happened to him? I kinda miss his perpetually snarky remarks. LOL
A certain Mod made it there mission to get rid of him, the same one who used
a suspended account as an avatar for like a year.
JsK is offline   Reply With Quote
Old 09-07-2016, 10:51 PM   #3092
Phillip F's Avatar
Trader Rating: 17 (100%+)
Anybody knows where we can get the updated shock towers ? aluminum... thicker graphite?
Phillip F is offline   Reply With Quote
Old 09-07-2016, 11:30 PM   #3093
mellow's Avatar
Trader Rating: 20 (100%+)
Originally Posted by ANDRXW View Post
I must say, after watching these buggies race this past weekend I'm getting the itch to get back into things.
I was just looking at your website. Nice photos of the LRH Race. Go get yourself a B6! I just built up one after being out of it for the past few years.
"It'd be a lot cooler if you did."
mellow is offline   Reply With Quote
Old 09-08-2016, 12:26 AM   #3094
ANDRXW's Avatar
Thanks so much Mellow. Raced for about ~8 years and sold everything to pickup camera gear...but hearing chassis' slap and tires screeching has got me hooked again. Good to hear you got back into things too!
/ / ANDRXW.com
ANDRXW is offline   Reply With Quote
Old 09-08-2016, 01:11 AM   #3095
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
There was no "mission". And you're either wrong about the avatar, or you're wrong about which mod you're referring to.
He's gone, end of story.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 09-08-2016, 01:21 AM   #3096
Cridd's Avatar
Trader Rating: 16 (100%+)
B6D with laydown set up box stock, has great steering all around, but to get s little less off power steering and a little more on power what are some good things to start playing with on B6.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 09-08-2016, 01:24 AM   #3097
JsK
JsK's Avatar
Thicker front oil / more caster / more front toe in, do one at a time
Old 09-08-2016, 01:27 AM   #3098
Cridd's Avatar
Originally Posted by tylem28 View Post
Just out of curiosity how long did it take each of you to fully assembly the couple kit including motor, esc, servo, receiver, etc. Also for reference was this your first time putting a kit together or did you have experience from in the past builds. Just trying to get an idea as a newbie how long it takes to assembly the entire buggy?
Im not new to RC cars just new to Buggy's. I have a couple of Traxxas Slash and have taken one completely apart to put a LCG chassis on and rebuild the transmission. thanks for all your help!
you could get done in 4 hours but I usually piddle around and remove stuff off old cars and break it up, I'm usually around 8 with it ready to roll, body on ready to rock.
Chris
B6D / T5M / SC5M
Old 09-08-2016, 01:28 AM   #3099
Cridd's Avatar
Gracias.
Chris
B6D / T5M / SC5M
Old 09-08-2016, 07:43 AM   #3100
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
You do know the mod in question and socket are real life friends and have known each other since they were 14 years old? But it goes like this. Let us say I have a friend working for me. I like him most of the time, but he is causing unrest with the other employees. So I let him go, for the good of the group. Not much of a difference here. Also, those 2 chat all the time on FB. Just because you are friends with someone does not mean everyone should have to listen to your "troubled" friend. My understanding is this "mod" stood up for Socket as long as he could. But eventually, defending him became harder and harder.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 09-08-2016, 08:32 AM   #3101
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
I know you're talking about me and you couldn't be more wrong. If you have a problem with me or something I did you are free to pm me and we can talk it out.
You all are incredibly wrong about the situation that led him to no longer be here. Stop spreading the rumors like you have first hand knowledge....because I guarantee you don't.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 09-08-2016, 09:34 AM   #3102
Gigasipke's Avatar
Loving my B6D in stock class on dirt. It was so cool, we had so many different buggies racing, five RB6's, three B5's, one 22 3.0 (mid), one 22 2.0. one Durango, one B5M and my B6D.
The top 5 of us all had different buggies. Although on target to take the TQ, I screwed up twice and ended up qualifying 3rd.
The previous race I had a turn-in push issue. It was mostly fixed with moving the front shock to the inside hole on the top and dropping front spring from White to Green. I was going to try Black next but somehow I only had one of them. I may go to brown or up one spring rate in the rear.
My motor (Fantom Apex V2) is also 3 seasons old so may be time to update. I won't ask for a motor recommendation, since I know the answer is a no real answer. Honestly I barely have run buggy and only when I had no option to run my Truck, really more of a truck guy but dang it this buggy is converting me.
-T5M (13.5), - B6D (17.5)
-Mad Dogz Hobby Team Driver
https://youtu.be/Rg4Jlid5dFo
Steve Aldous
Gigasipke is offline   Reply With Quote
Old 09-08-2016, 10:04 AM   #3103
Phillip F's Avatar
what camera gear do you use?
Old 09-08-2016, 10:10 AM   #3104
Super Moderator
racer1812's Avatar
What does that have to do with a B6 Send the guy a PM...sheesh
Old 09-08-2016, 10:18 AM   #3105
Trader Rating: 29 (100%+)
Or rephrase "what camera gear do you use to take pics of your B6".
DustinEich is offline   Reply With Quote
Currently Active Users Viewing This Thread: 10 (3 members and 7 guests)
2dialed, Evoking1230, Screech
