    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree366Likes
Old 09-02-2016, 12:32 PM   #2986
Originally Posted by mellow View Post
From their facebook page, it seems like they run slicks, but I don't know for sure. It's a track I'd like to go to, so I'm curious well.
Yup, Primes or Smoothies, clay compound.
How about wheels, any go to's or are they all pretty much the same?
microjam is offline   Reply With Quote
Old 09-02-2016, 12:34 PM   #2987
mellow's Avatar
Trader Rating: 20 (100%+)
I've always used Associated wheels since they're cheap and do what they're supposed to, also got some Raw Speeds to try.
"It'd be a lot cooler if you did."
mellow is offline   Reply With Quote
Old 09-02-2016, 12:37 PM   #2988
Jmuck69's Avatar
Trader Rating: 14 (100%+)
AE wheels are the best IMO and a great price.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 09-02-2016, 12:50 PM   #2989
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Are you serious? Of the wheels I have tested, AE/proline are the worst. AKA seems to have the best 2.4 wheel and avid the best 2.2 wheel. My criteria is "durability", hex engagement and fit/finish.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 09-02-2016, 01:03 PM   #2990
Don't say that about your sponsors, LOL
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 09-02-2016, 01:42 PM   #2991
suby723's Avatar
Trader Rating: 21 (100%+)
That's only for the tires and not the wheels.
suby723 is offline   Reply With Quote
Old 09-02-2016, 01:52 PM   #2992
abailey21's Avatar
Trader Rating: 36 (100%+)
B6D laydown - any tire recommendations for SCVRC track? (high bite clay if I'm not mistaken..)
everyone is running primes
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 09-02-2016, 02:10 PM   #2993
mellow's Avatar
^^ Thanks!
Old 09-02-2016, 03:35 PM   #2994
Trader Rating: 488 (100%+)
Out of all the wheels I gotta say, tires seem to glue up really easy on the AKA wheels. The XRay wheels are actually good too but they charge by the ounce for those and they're just a touch cheaper than gold.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 09-02-2016, 04:28 PM   #2995
3n90t's Avatar
+1 AKA wheels seem to fit most brands of tires better for me. they glue up better and I don't get out of shape tires. The outer rim edge is thick so it last a long time especially recycling them multiple times. If they are rough, I just sand them down then re use them.
AE wheels are ok, but seem to be too flexible.
I hate the proline recess for the nut. Make tire changes a pain.
AE: B5, B5M, B44.3, B6D, B64D
Tamiya: MF-01X Suzuki Jimny JB23
3n90t is offline   Reply With Quote
Old 09-02-2016, 04:34 PM   #2996
Just need a few more parts and I will finally be ready to put this new unit together!
NCOHOG is offline   Reply With Quote
Old 09-02-2016, 04:41 PM   #2997
mellow's Avatar
Did you send out all those parts to get anodized yourself? I thought about doing that after seeing the blacked out version Wallie Builds is offering.
Old 09-02-2016, 04:54 PM   #2998
I did send them out to my anodize guy. I have no idea who this Wallie Builds guy is but I'd like to see his stuff
Old 09-02-2016, 04:57 PM   #2999
mellow's Avatar
I wish I would have done the same, especially since I wont be able to drive this thing for a couple weeks. All black with the gold turnbuckles looks great.
Wallie Builds does a kit build service for people who don't want to do it themselves, and they will also do rebuilds and the like.
https://www.instagram.com/wallie_builds/
https://www.facebook.com/WallieBuilds/
Old 09-02-2016, 05:05 PM   #3000
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
Wallie Builds= Nick Wautlet , he's on FB
He works for AE and is sponsored. Does really clean wiring jobs.
XRAY T4 17' //CRC Gen X SE- 17.5 GT//Xray X12-17' GT12//Xray X12-18' 17.5
check out the new 12th scale GT class!
https://www.facebook.com/groups/148391312353349/
JEFFs SC10 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 8 (1 members and 7 guests)
ErikJan
