    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree326Likes
Old 05-04-2016, 10:21 AM   #286
jmcelroy42's Avatar
Originally Posted by racer1812 View Post
They're just trying to figure out how NOT make it look like an Xray
Why? They didn't bother with making the RC8B3 not look like a Mugen
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 05-04-2016, 10:33 AM   #287
Jmuck69's Avatar
Nobody knows what an Xray looks like, wasn't on the Podium at the EOS race.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 05-04-2016, 12:21 PM   #288
VegasHB's Avatar
Originally Posted by Wildcat1971 View Post
I kind of wish it was a carpet track like the 702. I think bringing in the onroad guys will only increase business. That being said, I have no idea long term if the offroad guys will destroy the carpet for the onroad guys.
I really like the change from clay to carpet here. The thing running offroad and onroad is with the jumps there's a good 5 feet past the landing ramps of extra carpet to not eat up the base "onroad" carpet. The lowes carpet is cheap, durable and once some rubber is laid down during onroad the grip is impressive with a little SXT 3.0 on the tires.
Honestly with how difficult maintaining tracks and the costs to rebuild layouts can be, carpet is the only way to go to keep things profitable. Plus car maintenance is a breeze.
Don't worry about saving pennies, worry about making dollars.
702rcraceway.com, sponsored by my wallet
VegasHB is offline   Reply With Quote
Old 05-04-2016, 12:51 PM   #289
Next step for the XRay? A 3 gear laydown just like a B6... Unless they release a XB4 / XB2 hybrid. I bet their star driver has suggested this.
AntH3000 is offline   Reply With Quote
Old 05-04-2016, 01:16 PM   #290
BRSracing's Avatar
Trader Rating: 55 (100%+)
xray released their laydown transmission last year
BRSracing is offline   Reply With Quote
Old 05-04-2016, 01:18 PM   #291
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I dont disagree. But racing offroad carpet seems wrong. but i would run indoor carpet and have a profitable indoor facility, than bash in the back yard because my tracks closed.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-04-2016, 01:20 PM   #292
Jordan Anderson's Avatar
Originally Posted by Kegman21 View Post
Ordered the B6. 702 is my home track and with carpet I can not wait. Buggies or anything on carpet is all about the low cg.
Is 702 a spike tire (Pin Points) or slick tire (Primes) carpet track? Track appears to be an Ozite on-road style carpet?
The reason I ask is because our local indoor on-road club added a 2wd off-road class by putting some jumps on their Ozite track. Originally the rules allowed spiked carpet tires, but the club felt the spikes were harming the Ozite carpet so they've switched to a sauced slick tire rule.
Will a sauced slick tire on an Ozite track generate B6 super high grip?
JORDAN // EVAN
R/C GEARS , TRUKZ/KARZ , VRC PRO
Jordan Anderson is offline   Reply With Quote
Old 05-04-2016, 01:23 PM   #293
BRSracing's Avatar
Agree with that, but the thing that appeals to me with carpet is having new tracks more frequent. Our indoor track changes about three or four times a year which burns people out. The first few weeks of new layouts driver participation spike then drops off once people get bored it seems. I am thankful to have anything though, local track is 10 minutes from my house with a fully stocked hobby shop.
(also would not hurt my feelings not cleaning dirty tires)
Old 05-04-2016, 01:44 PM   #294
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
you all missed my point.
Carry on
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 05-04-2016, 01:49 PM   #295
Super Moderator
racer1812's Avatar
I don't want to be "Debby downer" but there are plenty of carpet/turf vs. dirt threads we could dig up to discuss that topic. And feel free to do so! At this point it's a worthy discussion. BUT I don't think we need to clutter this thread with it.
Old 05-04-2016, 02:13 PM   #296
Europeans need the Carpet and Astro Turf version regular B6.
The B6D is the dirt version for americans.
I am an American. I do browse oople.com occasionally to see what those Europeans are doing with thier cars. Im freinds with alot of those oople.com people on facebook.
Graham North is one of them. I find those guys entertaining..
Even those guys know who I am. Even thou ive never met them in person or anything.
Associated B6 "Dirt Version" latemodel, Team Losi Racing 22T 2.0 Bomber Truck.
Team Losi Racing 22 2.0 2wd Short Course Truck,Duratrax 835e Brushless 8th scale Buggy,
Stock Slash, B4.1 latemodel(retired), T4.2 Factory Team BOMBER CAR
Castle Creations( Since April 2016)
bmag5000 is offline   Reply With Quote
Old 05-04-2016, 02:29 PM   #297
EricW's Avatar
Except for the fact that Coelho won 4wd at the EOS Race, driving an Xray, great point.
Stickas are for straight up suckas......
**** "Luxury" ****
EricW is offline   Reply With Quote
Old 05-04-2016, 03:05 PM   #298
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
But this is a 2wd thread, hence his point.
Coelho is very talented and congratulations to him on his win and overall championship.
Now back to the B6 line of cars.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 05-04-2016, 03:10 PM   #299
1/4milecrazy's Avatar
Carry on
I caught it.
He says that because TLRs SCT sucks.
Apparently "equal" and "partners" means different things to different people.
1/4milecrazy is online now   Reply With Quote
Old 05-04-2016, 04:26 PM   #300
Trader Rating: 44 (100%+)
And Yokomo released the B6 2 years prior. But called it the YZ2.
Aaron Moore
Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
shdwboxn
