    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree361Likes
Old 04-29-2016, 07:48 AM   #16
-Ryan-
TLR 22 4.0SR | HW Just Stock Club Spec ESC| Trackstar V2 17.5 | Savox 1257 | RawSpeed Tires
Tamiya TRF201 | HW Just Stock Club Spec ESC | Trackstar V2 17.5 Outlaw | Savox 1258
Fastlane Raceway, Blue Springs, MO
CTRJ is offline   Reply With Quote
Old 04-29-2016, 07:50 AM   #17
I kinda want to buy one even though I only go racing like 2-3 times per year. B5 rear motor always left me slower than I would have liked, and now I'm going to be really outclassed.
Myt3rocks is offline   Reply With Quote
Old 04-29-2016, 07:54 AM   #18
Flip boy's Avatar
Does anyone else see two different chassis's?
Flip boy is offline   Reply With Quote
Old 04-29-2016, 07:58 AM   #19
Cridd's Avatar
Trader Rating: 16 (100%+)
I think I do, dirt looks like narrower in rear but could be playing tricks on me. Maybe the same chassis.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 04-29-2016, 07:58 AM   #20
I don't think they are. The bottom shot of the B6 has the holes for the stand up transmission's waterfall. That side by side photo isn't perfectly to scale, the B6D looks smaller in every direction. I first noticed it looking at the size of the servo.
Old 04-29-2016, 07:58 AM   #21
gokarter64's Avatar
If i was looking for a new brand this might convince me to give ae a second look but im lovin my losi cars currently
This is by far my favorite kit body that i have seen for an ae car so far
gokarter64 is offline   Reply With Quote
Old 04-29-2016, 08:00 AM   #22
I took both pictures from the AE website and stitched them together. I agree that the B6D picture seems to be a bit smaller than the B6.
-Ryan-
Old 04-29-2016, 08:07 AM   #23
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Same car, pictures taken at different times and placed side by side to make one picture.
The distance between the car and the camera are different which would explain the size dimension differences.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 04-29-2016, 08:17 AM   #24
Jmuck69's Avatar
Trader Rating: 14 (100%+)
I like the battery hold down. Seems to have a clamping post that you set to your battery height then the nut (same 7mm hex as the wheel nuts) is tighten down. No more servo taping your lipos down.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 04-29-2016, 08:21 AM   #25
Suspended
Trader Rating: 61 (100%+)
I like it.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 04-29-2016, 08:52 AM   #26
Subscribed!
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 04-29-2016, 08:56 AM   #27
neallewis's Avatar
Debut running video
https://youtu.be/jsoXMyFoj9w
neallewis is offline   Reply With Quote
Old 04-29-2016, 09:27 AM   #28
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
The car looks great. The pretty much addressed every issue I had with the b5m. even the little clamping stops on the battery strap screws is a nice touch. no more battery foams. one piece front hubs. 1 piece alum chassis. And it looks like going from laydown to stand will be easy and cheap for most tracks.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 04-29-2016, 09:31 AM   #29
Originally Posted by JC8390 View Post
So far I don't see much reason for upgrading if youre a dirt guy. I could be wrong though.
Having the same impression. WE drive on loose clay and there is no reason to abandon the B5R...even the B5M has to be highly tuned to be as fast as a B5R. So no money wasted here
man1ac is offline   Reply With Quote
Old 04-29-2016, 09:32 AM   #30
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Chassis Focus - Spencer Rivkin - EOS
http://eos.redrc.net/2016/04/chassis...pencer-rivkin/
Looks like AE might have some Factory Team goodies ready to go as well....
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Currently Active Users Viewing This Thread: 15 (2 members and 13 guests)
DJH, RC10Nick
