    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree369Likes
Old 09-02-2016, 10:08 AM   #2971
Originally Posted by mellow View Post
Long or short eyelets on the rear?
Long eyelets in the rear, but just realized I put short eyelets in the front - the manual calls for long in front too..
microjam is offline   Reply With Quote
Old 09-02-2016, 10:13 AM   #2972
mellow's Avatar
Trader Rating: 20 (100%+)
Front should be short if you have the shock on the inside or middle hole of the arm, and long if the shock is in the outside hole.
Rears are short if shocks are mounted on the front of arm, and long if mounted on the rear of arm.
Wiki has a good diagram that Kody posted.
http://www.rctech.net/forum/attachme...ead-manual.jpg
"It'd be a lot cooler if you did."
mellow is offline   Reply With Quote
Old 09-02-2016, 10:17 AM   #2973
"Smiley"'s Avatar
Trader Rating: 166 (98%+)
This is a sneak peak at the Standard Front Tower. We anodize them in house. Three color options, polished silver, blue and black. The blue and black have chrome edges. These stock towers are only 1.4 grams heavier than a stock tower ae tower. Not sure how these would make anyone's car look like a tyco car lol
Vision Racing Products | Team Associated | AKA | Tekin | Sanwa | VP Powermaster Fuel | RC Concepts Engines | MIP | Avid | Boom RC Graphics | Paint By: "Smiley"
Vision Racing Products (VRP)- www.visionracingproducts.com
"Smiley" is offline   Reply With Quote
Old 09-02-2016, 10:20 AM   #2974
mellow's Avatar
I think they look pretty good. Someone else mentioned this, but a hard anodizing option similar to the B6 chassis, would look pretty slick.
Old 09-02-2016, 10:39 AM   #2975
Phillip F's Avatar
Trader Rating: 17 (100%+)
Love it.... Let me order it right now.
Phillip F is offline   Reply With Quote
Old 09-02-2016, 10:51 AM   #2976
Phillip F's Avatar
Can you show us how each color looks installed in the B6.... I'm leaning towards black.
Old 09-02-2016, 10:55 AM   #2977
Originally Posted by RCBuddha View Post
Question, what is the easiest way to get the existing balls out? i have not been able to do it and just boughta new set to tune faster.
40yoCaliRacer is offline   Reply With Quote
Old 09-02-2016, 10:57 AM   #2978
mellow's Avatar
Protek shock shaft pliers are the bees knees.
Old 09-02-2016, 11:24 AM   #2979
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
+1 I love the protek shock pliers.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 09-02-2016, 11:31 AM   #2980
Thank you! Yeah since I have the laydown in, I put the rear shocks in front of the arms, but had the long eyelets in. Changed to the long ones and now the ride height is about 23. All good.
Old 09-02-2016, 11:33 AM   #2981
I just used these to remove pivot balls from the eyelets (and to hold the shock shafts). Totally worth the money.
Old 09-02-2016, 11:39 AM   #2982
mellow's Avatar
Glad you got it figured out.
Yeah, those pliers are the best tool I've bought in awhile. Right next to my MIP hex drivers and Hitatchi cordless screwdriver.
Old 09-02-2016, 11:53 AM   #2983
"Smiley"'s Avatar
Yep, Next week I'll take some pictures of them installed.
Old 09-02-2016, 12:26 PM   #2984
B6D laydown - any tire recommendations for SCVRC track? (high bite clay if I'm not mistaken..)
Old 09-02-2016, 12:30 PM   #2985
mellow's Avatar
From their facebook page, it seems like they run slicks, but I don't know for sure. It's a track I'd like to go to, so I'm curious well.
