    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree366Likes
Old 09-02-2016, 07:25 AM   #2956
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by "Smiley" View Post
We are working to get our towers finished asap. I will post in the VRP thread and on here when they are available.
no offence, but aluminum towers is just too traxxas for me. Maybe they we be the end all down the road. But, I think a tower brace would be better. Preferably one made from an old bent chassis, to make it look like a smiley face....those of you on b5 nation might get that reference, lol.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 09-02-2016, 08:04 AM   #2957
RCBuddha's Avatar
Trader Rating: 35 (100%+)
http://www.redrc.net/2016/09/t-works...y-pivot-balls/
RCBuddha is offline   Reply With Quote
Old 09-02-2016, 08:11 AM   #2958
RCBuddha's Avatar
nicely sanded and sealed front and rear towers (from B6 Nation on facebook)
Old 09-02-2016, 08:16 AM   #2959
RCBuddha's Avatar
Plan B Racing will be coming out with some carbon towers:
Old 09-02-2016, 08:25 AM   #2960
RCBuddha's Avatar
http://www.redrc.net/2016/09/jconcep...h/#more-118435
Old 09-02-2016, 08:26 AM   #2961
RCBuddha's Avatar
as posted earlier:
http://www.redrc.net/2016/09/exotek-...s-wheel-hexes/
Old 09-02-2016, 08:41 AM   #2962
RCBuddha's Avatar
cool tool:
http://www.teamgravityrc.com/store1/...egory=15430101
Old 09-02-2016, 09:04 AM   #2963
Phillip F's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Wildcat1971 View Post
I will give you the advice the lovely Facebook guys gave me. Dont crash
It's hard not to crash when a sc truck just rams you from behind while clearing the quads.
Phillip F is offline   Reply With Quote
Old 09-02-2016, 09:14 AM   #2964
Phillip F's Avatar
I'm getting a set from Smiley.. Don't care if my car looks like a Tyco just as long its bullet proof and I can finish a race.
Old 09-02-2016, 09:17 AM   #2965
Phillip F's Avatar
Those multiple holes... Really close to each other... Really good for tuning but when someone hits you at the right angle... Those multiple holes will turn into one big hole.
Old 09-02-2016, 09:35 AM   #2966
Originally Posted by Speedychris22 View Post
Might be stupid but u installed the battery?
Yes, battery and everything else is in.
microjam is offline   Reply With Quote
Old 09-02-2016, 09:45 AM   #2967
JsK
JsK's Avatar
What offset spring cups did you use and are the shock rod ends all the way screwed on?
JsK is offline   Reply With Quote
Old 09-02-2016, 09:59 AM   #2968
5mm cups, as per stock set up. Not sure what you mean by rod ends, but if you mean the eyelets, I set the stroke at 27.5 like the manual says.
Old 09-02-2016, 10:00 AM   #2969
mellow's Avatar
Trader Rating: 20 (100%+)
All sorts of new goodies!
"It'd be a lot cooler if you did."
mellow is offline   Reply With Quote
Old 09-02-2016, 10:00 AM   #2970
mellow's Avatar
Long or short eyelets on the rear?
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
