    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree327Likes
Old 08-31-2016, 12:24 PM   #2926
aeRayls's Avatar
Originally Posted by BIGSKI15 View Post
When adding the 25g weight, are you adding some weight to the front too to reduce the pendulum effect or does it remain somewhat balanced?
No, there's no pendulum effect where it's mounted.... to me.
aeRayls is offline   Reply With Quote
Old 08-31-2016, 04:32 PM   #2927
ray_munday's Avatar
Originally Posted by Jmuck69 View Post
Ran the setup minus the shock oil recommendation and it was DIALED. It was outdoors, medium traction. So much forward bite. I could have tweaked the anti-squat to get a little more initial side bite but was happy overall. Trying the laydown this weekend for the first time on a medium to high-bite indoor track.
Hi mate, glad to hear the setup is working for you!!
Originally Posted by aeRayls View Post
There's almost nothing to making the 25g brass mount work. It's a 10 second job. Just notch either the motor plate or the mount with a dremel and sanding drum. Simple and easy.
+1 Yep its not too hard to do. Hopefully we can get a small design change so it fits both the laydown and standup.
Agree with Adam - the heavier brass C weight sits just in front of the rear axle and doesn't add a noticeable pendulum effect (unless you are running on super high grip). Adding weight at the D block (behind the axle) does tend to have a more dramatic effect and I only use it when I really need more forward bite. Adding weight to the front takes away forward bite but sometimes a heavier car works better on certain surfaces. This is when I run the brass weight under the battery as that is the ideal place for added weight.
Team Associated Factory Driver: B6/B6D, B64D, SC5M
JConcepts Factory Driver: Tyres, Rims, Wings, Bodies & Accessories
Reedy Factory Driver: Blackbox 510R ESC, Sonic 3 BL motors, Lipo
KO Propo EX-1 KIY_____www.keilorrc.com.au
Check out my help thread: http://www.rctech.net/forum/10587838-post1.html
ray_munday is offline   Reply With Quote
Old 09-01-2016, 05:59 AM   #2928
I'm going to preface this by saying... I'm coming out of a nearly 20yr racing retirement. I need a hobby to break up the grind. Last time I raced... it was anoOriginal World's car. I've picked up and built a few AE kits to build (enjoy that as much as racing) for fun and played a little, but no racing.
Now I've picked up a B6 and B6D. It's great to see the tech advances with Wifi radios, brushless esc/motors and LiPos. By far the most confusing to me is the LiPo technology.
Question time... AE's site says "7.4V LiPo or 6.6V LiFe battery (saddle pack, shorty pack, or square pack)". Looking around the web, the manual, etc I've only seen shorty packs used. How would you mount a square or saddle pack? What would really be best form factor for some stock buggy racing? Recommendations on LiPo specs?
lmw94002 is offline   Reply With Quote
Old 09-01-2016, 06:17 AM   #2929
Trader Rating: 16 (100%+)
The B6D can fit a square pack, or shorty pack. The B6 can only use a shorty. For stock classes, a high quality shorty pack will be the way to go.
MX304 is offline   Reply With Quote
Old 09-01-2016, 06:52 AM   #2930
Trader Rating: 50 (100%+)
hey guys running basically box setup but need more initial turn in. Going into slow 180s the car just pushes wide. Running 3 Gear Mod on a low traction indoor hand packed. Any suggestions on what to start with.
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 09-01-2016, 06:59 AM   #2931
"Smiley"'s Avatar
Trader Rating: 166 (98%+)
Here is a sneak peek of something to be released soon from VRP. No more breaking shock towers. They will weigh within a gram or so of the stock carbon towers
Vision Racing Products | Team Associated | AKA | Tekin | Sanwa | VP Powermaster Fuel | RC Concepts Engines | MIP | Avid | Boom RC Graphics | Paint By: "Smiley"
Vision Racing Products (VRP)- www.visionracingproducts.com
"Smiley" is offline   Reply With Quote
Old 09-01-2016, 07:43 AM   #2932
AZJP's Avatar
Trader Rating: 20 (100%+)
100c if you want the most out of a stock motor, if you're not concerned with that any sub 100c will work. All batteries for 1/10 cars are going to be 2s 7.4. A shorty is what you want.
AZJP is offline   Reply With Quote
Old 09-01-2016, 07:59 AM   #2933
Nice! Plan to Anodize in Black and AE Blue? Actually Gun Metal anodize would look awesome.
Could they bend by any chance?
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 09-01-2016, 08:20 AM   #2934
"Smiley"'s Avatar
They will be available in silver, blue and black. I've been testing them for a while now, no issues. But, say if somehow you were able to bend it in a really bad wreck, you would still be able to finish your race vs. a carbon tower would snap.
Old 09-01-2016, 09:16 AM   #2935
Trader Rating: 140 (100%+)
So I Have had these cars for a while,,,I noticed when building the slots in the side pods, wanted to try touring car reinforced tape to tie the battery down.
Finally got the time to try it out, really like it , especially if you run battery all the way forward,
a small lower bump stop would be great if moving battery back.
RC RACING DESIGNS..
slick1 is offline   Reply With Quote
Old 09-01-2016, 09:54 AM   #2936
mellow's Avatar
Trader Rating: 19 (100%+)
What kind of aluminum are they made from?
"It'd be a lot cooler if you did."
mellow is offline   Reply With Quote
Old 09-01-2016, 10:12 AM   #2937
"Smiley"'s Avatar
American 7075. We design and cut them in house here at VRP. No china made stuff here. 100% american made.
sluther343 likes this.
Old 09-01-2016, 10:16 AM   #2938
mellow's Avatar
That's what I was hoping you would say
Old 09-01-2016, 12:29 PM   #2939
Default Ball cups
I bought an extra set of B6 ballcups and thought I'd put them on my T5M, I installed them and they're tight. The ball studs haven't changed but can't figure out why they're really tight. I might just leave the old reamed out ones on.
daveb is offline   Reply With Quote
Old 09-01-2016, 12:42 PM   #2940
Phillip F's Avatar
Trader Rating: 15 (100%+)
How much are they going for?
Phillip F is offline   Reply With Quote
Currently Active Users Viewing This Thread: 23 (2 members and 21 guests)
Fearo, Kelseyrc
