    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree366Likes
Old 08-26-2016, 01:24 PM   #2851
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Originally Posted by M2126 View Post
Planning to get a b6d. This is my first 10th scale 2wd buggy.
What are some basic must have upgrades to start? I'm planning to run stock class at ocrc. Anyone know how much weight savings the titanium screw set and the turnbuckles give?
Schelle Ti screw set will save about 15g, turnbuckles are somewhere in the 10-15g range I think. Uprgade wise I would get the aluminum D mount for more adjustments....that should be it.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-26-2016, 01:25 PM   #2852
jmcelroy42's Avatar
I put the AE Aluminum screws (for B5M) and AE Ti turnbuckles and MIP Pucks on mine and was right around 1450g.
EB48.4 - TEKIN RX8 & SMC 2100
EB410 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is online now   Reply With Quote
Old 08-26-2016, 01:26 PM   #2853
egalsim's Avatar
Trader Rating: 39 (100%+)
Upgrades? Tracktime. It's fine the way it is.
Associated RC10B6 / Kyosho Optima / Associated Tekno SC8e / Awesomatix A700exl / Serpent Cobra BE 2.1 Rally / Kyosho MP9 Tki3.5 Tekno V4 / Xray Xb4 2017 / Serpent SDX4
egalsim is offline   Reply With Quote
Old 08-26-2016, 01:32 PM   #2854
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
+1000000
I would say that is probably the best upgrade. way more tunability
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-26-2016, 01:37 PM   #2855
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Which is right around 49g. under legal weight..
(about 10 nickles worth)
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 08-26-2016, 01:50 PM   #2856
mellow's Avatar
Trader Rating: 20 (100%+)
Originally Posted by Wildcat1971 View Post
+1000000
The tunability this car has compared to the b4 makes my brain hurt. I'm still trying to wrap my head around all the different inserts for the c/d blocks.
"It'd be a lot cooler if you did."
mellow is offline   Reply With Quote
Old 08-26-2016, 02:03 PM   #2857
Trader Rating: 14 (100%+)
Ti turnbuckles are only about 8g by the way. Ill spend that $25 on tires. D block would gain you the most benefit. Only other thing i am really trying that i think will be noticeable is the long shocks in back and Scheme 31mm tower. Everything else is just perceived cool factor in my opinion
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875 vs Tekno EB410, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 08-26-2016, 02:34 PM   #2858
do you have the part numbers for the D block and the 31mm tower?
thanks
M2126 is offline   Reply With Quote
Old 08-26-2016, 02:39 PM   #2859
mellow's Avatar
D block:
https://www.amainhobbies.com/team-as...c91688/p507425
Tower:
https://www.amainhobbies.com/team-as...c91666/p512484
Pretty sure you'll need the longer 31mm shock bodies though.
Old 08-26-2016, 02:43 PM   #2860
thanks!
Old 08-26-2016, 02:47 PM   #2861
sorry, im pretty newb, do i need to get a new set of inserts for the extra tunability or do i use stock inserts?
Old 08-26-2016, 02:48 PM   #2862
mellow's Avatar
The kit comes with a set of inserts that you can use.
Old 08-26-2016, 02:51 PM   #2863
great thanks, one more Q - for the longer shocks in the back, do i get both long shock body (31mm) and shaft? or just long body and stock shaft is ok? thanks again
Old 08-26-2016, 02:54 PM   #2864
Super Moderator
Shaft is the same size for either setup.
Old 08-26-2016, 02:55 PM   #2865
mellow's Avatar
Shock shafts are the same.
As others have said though, if this is your first 2wd buggy, I'd recommend skipping the long tower and shock bodies for now, and put that money towards 1-2 sets of tires, and some spare arms.
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
Fearo, GasGod
