    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree326Likes
Old 08-17-2016, 02:59 PM   #2671
Orion_2kTC's Avatar
Running mobile at work, can't search. Thanks, I'll read what was posted.
Orion_2kTC is offline   Reply With Quote
Old 08-17-2016, 03:37 PM   #2672
liljohn1064's Avatar
Trader Rating: 17 (100%+)
The B6 is my first buggy in 5 years. It is pretty much the stock setup. I did remove some anti squat, .5. I've also dropped in the Schelle B5 rear hubs as it helped with dropping the ride height. I'll swap them for the the new version when they come out if I feel the need. Right now I don't think it's needed. I like the way it corners, jumps and lands. I spend more time in the on road world, so it was relaxing to just go out and have some fun and worry more about setting up jumps and landings and not so much about passing or being passed. I'd recommend it to any beginner as it it stable to drive and very durable. It instills confidence after only a couple of laps. Keep the shiny side up going as efficiently as possible and you'll do well with this rig. The one upgrade I think it really needs is turnbuckles, so I have some Lunsford sets to swap in and picked up a couple odd sizes for tuning options. I'm not doing Ti for weight, but for the right length as I felt the kit units threaded too far into the ball cup. I'd recommend practicing until you can run with the big guns, then sweat the bling as all it is is just bling.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 08-17-2016, 04:34 PM   #2673
Has anybody seen setups posted anywhere from nats ?
Jason84 is offline   Reply With Quote
Old 08-17-2016, 05:32 PM   #2674
mellow's Avatar
Trader Rating: 19 (100%+)
Anybody know if the Avid springs will fit the shocks? I have pretty much the whole setup left over from when I had my B4.2..
"It'd be a lot cooler if you did."
mellow is offline   Reply With Quote
Old 08-17-2016, 05:34 PM   #2675
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
yes, I am using them
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 08-17-2016, 05:36 PM   #2676
mellow's Avatar
Thanks Wildcat..I actually just searched and saw your post. I take it most people don't run them because you can't get them anymore. Seems like you like them?
Old 08-17-2016, 05:37 PM   #2677
I like them for my track. running purple fronts and yellow rears
Old 08-17-2016, 05:44 PM   #2678
mellow's Avatar
Cool, thanks.
Also, what ever happened to Wild Che...?or am I allowed to say that? I've been away for awhile.
Old 08-17-2016, 06:01 PM   #2679
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Cool, thanks.
He no longer comes on here.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-17-2016, 07:46 PM   #2680
Recently got into 17.5 racing. I wanted to get a used b5m so that my investment was minimal, but it turns out I'm hooked. I will be upgrading to a b6 in the near future so I'm wondering how many parts are interchangeable? Should I rock out with the b5m as is until I upgrade or can I continue making it more competitive until I decide to spring for the b6?
MisterLeon is offline   Reply With Quote
Old 08-17-2016, 08:12 PM   #2681
mellow's Avatar
http://www.rcten.com/threads/b5-b6-p...ibility.20226/
Old 08-17-2016, 09:28 PM   #2682
RCBuddha's Avatar
Trader Rating: 35 (100%+)
http://www.redrc.net/2016/08/dirt-ra...ud-washer-set/
http://www.redrc.net/2016/08/t-works...with-locknuts/
RCBuddha is offline   Reply With Quote
Old 08-18-2016, 05:46 AM   #2683
not much at all crosses over, shocks, slipper and bearings.
Old 08-18-2016, 06:51 AM   #2684
celt's Avatar
Default that's a mistake right?
Tell me they didn't make one of the studs a left hand thread...
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 08-18-2016, 07:42 AM   #2685
jmcelroy42's Avatar
It looks to me like they just took a picture of one and mirrored it. All of the little imperfections look identical just mirrored.
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 8 (5 members and 3 guests)
Fundukian, JsK, ksellers, Phat-Boy, speed101
