    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree366Likes
Old 08-17-2016, 10:10 AM   #2656
celt's Avatar
Originally Posted by Socket View Post
I love the kashimas.
I know more than one person who doesn't like them
I also like the gold shafts over the chrome.
Kashimas w/ chrome shafts, standard/silver shock body with the Ti shafts.
Mixing the Kashimas w/ the color of the Ti shafts looks terrible.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 08-17-2016, 10:13 AM   #2657
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
I wasn't aware there was a proper color combination.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-17-2016, 10:45 AM   #2658
BRSracing's Avatar
Trader Rating: 55 (100%+)
BRSracing is offline   Reply With Quote
Old 08-17-2016, 12:15 PM   #2659
Trader Rating: 14 (100%+)
What we need now is a black DLC shock shaft
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875 vs Tekno EB410, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 08-17-2016, 01:01 PM   #2660
celt's Avatar
I shouldn't have to explain chassis fashion to SoCal guys
Stan Garvin
Old 08-17-2016, 01:59 PM   #2661
Super Moderator
Chassis fashion...cute
Old 08-17-2016, 02:03 PM   #2662
Phillip F's Avatar
Trader Rating: 17 (100%+)
Where can I get ceramic bearings for my B6 transmission only?
Phillip F is online now   Reply With Quote
Old 08-17-2016, 02:04 PM   #2663
Suspended
Trader Rating: 61 (100%+)
Schelle.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 08-17-2016, 02:17 PM   #2664
Trader Rating: 20 (100%+)
Avid
HotRodDiesels is offline   Reply With Quote
Old 08-17-2016, 02:20 PM   #2665
Suspended
The chrome shafts aren't worth the money. They show wear after a day of racing. Sure, at first they're a little smoother but developed wear super quick in my experience. They now sit in my box as backups incase I bend something.
Old 08-17-2016, 02:52 PM   #2666
Orion_2kTC's Avatar
Any advantage to using the FT aluminum bell cranks and steering rack?
Orion_2kTC is offline   Reply With Quote
Old 08-17-2016, 03:10 PM   #2667
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
the avid aura bearings are really good. they come as a transmission set.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-17-2016, 03:32 PM   #2668
Suspended
Do a search, please. We covered it a few pages back
Old 08-17-2016, 03:39 PM   #2669
mellow's Avatar
"It'd be a lot cooler if you did."
mellow is offline   Reply With Quote
Old 08-17-2016, 03:41 PM   #2670
BLKXJ96's Avatar
I ran them on mine and it seems to make the steering more rigid, where before on corners the inside wheel would always seem to chatter.
The only thing I didn't like was the two screws that come up from the bottom and hold the cross brace on don't really lock and if you go too tight they bind the steering. Yes.. I understand loctite is required, but I still didn't trust it for a day at the track. I ended up running slightly longer screws and using thin lock nuts to jam the screws after the were adjusted to where they wouldn't bind.
I used an aluminum horn as well because the FT bell cranks plowed into the kit plastic horn.
Jeff
RC10 Team Car, Gold Pan, RC10 B5m B5mCE, Sc5m, Rc8B3e, B6
BLKXJ96 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
Justin805
