    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree328Likes
Old 08-16-2016, 07:36 PM   #2641
rvrslt1's Avatar
Trader Rating: 25 (100%+)
From what I understand you can run shocks on front of arms with larger shock bodies and short eyelets.
Kurt will be posting a new set up sheet useing it.
rvrslt1 is offline   Reply With Quote
Old 08-16-2016, 07:40 PM   #2642
Trader Rating: 14 (100%+)
Great now i have to buy kashimas
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875 vs Tekno EB410, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 08-16-2016, 07:58 PM   #2643
rvrslt1's Avatar
25 bucks and change at LApartshouse.com. Have them on order.
Old 08-16-2016, 08:24 PM   #2644
Originally Posted by Wildcat1971 View Post
Reedy, Fantom, Trinity, Schuurspeed are all popular enough. More support from Reedy though. Fantom is nice if you want to custom option the motor
You can't beat the support from Schuur Speed. Ron Schuur has personally answered any question that I have had. That guy must never sleep, I've gotten responses from him very late into the night.
afm223 is offline   Reply With Quote
Old 08-16-2016, 11:48 PM   #2645
Originally Posted by Tmack View Post
Gents,
Newbie Question, how do you set and measure shock stroke?
Thanks in advance.
I use a set of digital calipers. You can get them for around $25
Bill
AE SC5M / Viper VTX10R & Maclan 10.5
Schumacher KD and KC / Maclan MMax Pro & MMR Team Edition 17.5
Schumacher KF2 / VTX 10R & MMR 17.5
Schumacher K2 / MMax Pro & MMR Team Edition 13.5 /// Airtronics MT-4
Riverbluff is offline   Reply With Quote
Old 08-17-2016, 05:45 AM   #2646
rimracker's Avatar
Originally Posted by Jmuck69 View Post
Initially the part you might want to consider is the aluminum D Block. Allows you to use the inserts and opens up more tuning possibilities.
Looking around for info on the D block. Specifically toe angles when changing the inserts in both the C and D. I get the one in the manual for the C, but the toe angle would change with the D if you move it out of the center, no?
rimracker is offline   Reply With Quote
Old 08-17-2016, 05:49 AM   #2647
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Everything moves either .5-1 increments depending on which pill you use and where its located. Center dot pill in the C/D mount is 3 toe and 1 anti squat. Use that as a reference point and adjust away.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-17-2016, 05:53 AM   #2648
rimracker's Avatar
Thanks, I guess what was throwing me off was on the set up sheets above the C and D mount it said 1 or .5 degree.
Old 08-17-2016, 06:00 AM   #2649
Super Moderator
You choose which pill you are using and then the placement of the hole within the C/D mount. It is very adjustable and confusing at first.
Old 08-17-2016, 06:06 AM   #2650
Postman brought my B6 to me yesterday. I started about 7pm and finished about 11pm.
Installed Bi Metal pucks on the gear diff and Exotek slipper eliminator right out of the box.
Couple things I noticed, I'll break em down into fitment and manual errors.
Fitment issues:
1) I studied and triple checked the orientation of the steering rack. I'm 95% sure I've got his right. Bag 1 Step 1 wants a 2mm spacer under the ballstud on the bell crank. I installed them and then ultimately removed them b/c I am not stoked with the amount of steering "throw" The ball stud/ball cup crashes into part 91667. If I compare the steering throw of my B5M FL to the B6 side by side, the B5M has got tons more. See the pic below. Maybe I'm doing something wrong, please advise.
2) Somebody else mentioned it here, but one of my turnbuckles isn't threaded correctly. It's on the LH threaded end, it looks threaded, but upon closer inspection, the threads have no pitch to them. They're sorta just ribs. No amount of turning (in either direction) will get the ball cup to screw on. I was fortunate to have a 48mm Factory Team Ti set in spare parts inventory for my B5M I "borrowed" to complete the build.
Manual errors:
Bag 5-8 step 1: shows no spacer under the ball stud. Yet in Bag 5-8 step 2 and step 3 one can clearly be seen in the rendering. There are also 2mm spacers included in these part bags. I installed them as shown in the Bag 5-8 step 2.
Bag 11-14 step 8: calls for 8 M3x10mm FHCS to mount the tranny and the chassis brace. The hardware kit includes 6 M3x10 FHCS for the tranny, and 2 M3x14 for the chassis brace (I think, they might have been M3-12s. At any rate, there were 2 that were definitely longer)
Any advice on the steering rack would be helpful. It looks like if you install the rack upside down vs what the manual wants it would buy me more clearance. I fear this however would have adverse affects on the steering geometry
edit "not enough posts to include a url to other site" so sorry no pic, which is kinda weak.
Consistent is used in the RC industry as much as Rowdy is used in the mountain bike industry. Truthfully, the only consistent thing is change.
BigChris in PA is offline   Reply With Quote
Old 08-17-2016, 06:15 AM   #2651
Super Moderator
Originally Posted by BigChris in PA View Post
Fitment issues:
pay close attention to the orientation of the rack. If its upside down or backwards then the ball stud could hit the bellcrank. With it properly there is no way with 2mm of spacing. You can email me a pic if you have other questions. Check your pm.
Old 08-17-2016, 06:25 AM   #2652
Super Moderator
Thanks for the pic. It is definitely on backwards. Pay close attention, the manual references which side goes forward and you can also see which side is up / down.
Old 08-17-2016, 07:12 AM   #2653
Thanks Matt, it was getting late last night and I musta had a brain fart. I'll check it again when I get home from work.
Old 08-17-2016, 08:24 AM   #2654
Orion_2kTC's Avatar
I'm surprised the new kit didn't come with them. I will have to as well, they came with the b5ce and were super smooth.
Orion_2kTC is offline   Reply With Quote
Old 08-17-2016, 08:26 AM   #2655
Suspended
Trader Rating: 61 (100%+)
I love the kashimas.
I know more than one person who doesn't like them
I also like the gold shafts over the chrome.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Currently Active Users Viewing This Thread: 6 (3 members and 3 guests)
djblues11, Stealthpilot, Still Bill
