    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree370Likes
Old 08-13-2016, 09:23 AM   #2551
BRSracing's Avatar
Trader Rating: 55 (100%+)
where is a good place to find pics of the nats? Usually live rc has a bunch up, but have not seen much.
BRSracing is offline   Reply With Quote
Old 08-13-2016, 09:25 AM   #2552
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
JConcepts Facebook page has a bunch taken by Thomas Tran of 2wdmod.com
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-13-2016, 12:09 PM   #2553
RC*PHREAK's Avatar
Trader Rating: 120 (100%+)
with the help of a pm from 2slo4u, i got the shim situation with the pucks sorted out. you have to:
other than the puck situation above, my build went well for the most part. stripped a titanium screw. the four screws that hold the rear shock tower on did not go in easily. i should have stopped, ran a steel screw through all the holes a few times and then try it. other than that, i think the AE titanium screws are fine. that was my fault that i stripped the one screw. pretty sure steel would have stripped too.
RC*PHREAK is offline   Reply With Quote
Old 08-13-2016, 12:52 PM   #2554
That probably needs a home in the wiki
40yoCaliRacer is offline   Reply With Quote
Old 08-13-2016, 01:02 PM   #2555
vito's Avatar
how is a b6 over the b 5 m drive like
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 08-13-2016, 03:19 PM   #2556
Cuebulon's Avatar
Originally Posted by abailey21 View Post
Same here, 32/72
Awesome guys. Thank you
Cuebulon is offline   Reply With Quote
Old 08-13-2016, 04:24 PM   #2557
goehm's Avatar
Trader Rating: 44 (100%+)
Originally Posted by stevewolfie159 View Post
Since you don't have a clue what you're talking about I'll just let it go. Non-satellite communication networks are superior for this service, period. So yes, it will rely on the customer's connection to the Internet.
Edit: Removed a reasonable response. You're right, I concede on all fronts. Non-satellite internet is superior even when its not available (which is why this sub-discussion started). End sub-thread.
--GO!
Come visit G's RC Raceway / Shippensburg, PA / www.GSRC.us
goehm is offline   Reply With Quote
Old 08-13-2016, 04:30 PM   #2558
Guys,
My search came up empty. Does the B6D kit come with the 4 gear stand up and gears?
My local track is super low grip clay.
Thanks for the help.
Bomba is offline   Reply With Quote
Old 08-13-2016, 04:35 PM   #2559
B6D comes with 3-gear, you have to buy the 4-gear separately or wait for the champion edition
MatthieuL is offline   Reply With Quote
Old 08-13-2016, 04:49 PM   #2560
goehm's Avatar
Originally Posted by Bomba View Post
Guys,
I run on low-medium type clay, and am running the 3 gear standup and I thought it had a lot of rear traction. I was previously running a SRX2 with the 4 gear for the most part and ended up preferring the 3 gear once someone made it available. My lap times decreased as well (it was just faster in the corners, and I felt like I really didn't give up any rear bite).
Not the same car of course, but hope that sort of experience might convey and help.
--GO!
Old 08-13-2016, 04:54 PM   #2561
Thanks,
Any idea on the part numbers for the extra idler gear, or is it the same as the other idler gear?
Old 08-13-2016, 04:55 PM   #2562
vito's Avatar
going to get one soon
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
Old 08-13-2016, 06:10 PM   #2563
Jmuck69's Avatar
Trader Rating: 14 (100%+)
What Champion Edition??
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 08-13-2016, 06:15 PM   #2564
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
He's either lost, confused, or both.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 08-13-2016, 07:54 PM   #2565
Originally Posted by Cuebulon View Post
To the people running the 17.5 ecopower motor what pinion are you guys running?
32/69 with about 40 of timing. I consistently get comments about how fast the motor is.
afm223 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
