    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree327Likes
Old 08-12-2016, 11:57 AM   #2521
lbckevin's Avatar
Trader Rating: 91 (99%+)
Did you sauce your tires at OCRC. It is a must to get steering and traction.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 08-12-2016, 11:58 AM   #2522
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Originally Posted by BRSracing View Post
is there not a broadcast for the roar race?
There is, and will be..once the track fixes their internet. Nothing anyone can do if the track doesn't have internet.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 08-12-2016, 12:13 PM   #2523
BRSracing's Avatar
Trader Rating: 55 (100%+)
Live rc right? I did not know their internet was down, I was not complaining I am sure my day is better served doing something productive anyway
BRSracing is offline   Reply With Quote
Old 08-12-2016, 12:53 PM   #2524
Cuebulon's Avatar
To the people running the 17.5 ecopower motor what pinion are you guys running?
Cuebulon is offline   Reply With Quote
Old 08-12-2016, 02:16 PM   #2525
AccessRacer's Avatar
Trader Rating: 20 (100%+)
32 pinion 72 spur
AccessRacer is offline   Reply With Quote
Old 08-12-2016, 03:28 PM   #2526
Originally Posted by Socket View Post
Man I know you asked for an OCRC racer, and I'm not one.
But before I went 30g on the front (brass bulkhead...) I'd sure try the Alloy (9g) or the steel (escapes me the weight) front insert.
Is this in mod or 17.5?
Thanks for the input. Not to exclude anyone else from answering, but I thought OCRC guys might already know something I don't... I figured the at least one answer would be to try the weights, but since they are so hard to find...
This is for 17.5. Not ready for mod yet.
Thanks again.
stevewolfie159 is offline   Reply With Quote
Old 08-12-2016, 03:30 PM   #2527
Yes, saucing with SK pink or white. Honestly can't tell the difference between the 2.
Old 08-12-2016, 03:31 PM   #2528
Originally Posted by Matt Trimmings View Post
You're running this exactly:
And you don't have enough steering?
Yes. That setup exactly.
Old 08-12-2016, 05:05 PM   #2529
abailey21's Avatar
Trader Rating: 36 (100%+)
Originally Posted by AccessRacer View Post
32 pinion 72 spur
Same here, 32/72
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 08-12-2016, 06:25 PM   #2530
RC*PHREAK's Avatar
Trader Rating: 120 (100%+)
finally got my kit today. don't remember seeing it mentioned here, but if you're using B5 pucks, the smaller shims that are recommended and actually come in the MIP shim kit for converting a B5 puck system to a B6 don't fit. the shim has a slightly larger OD and will not go all the way through the hub carrier. i haven't yet gotten to building the rear shocks so i don't know if there will be an issue with the pucks not being seated far enough in the outdrives yet.
RC*PHREAK is offline   Reply With Quote
Old 08-12-2016, 06:57 PM   #2531
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I am only using the diff shims for the B6. no hub spacers use at all. no issues
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-12-2016, 07:10 PM   #2532
goehm's Avatar
Trader Rating: 44 (100%+)
Not true at all. It's called satellite. Sure a track's Internet makes it convenient, but at some point they need to figure out their own WAN transport solution.
--GO!
Come visit G's RC Raceway / Shippensburg, PA / www.GSRC.us
goehm is offline   Reply With Quote
Old 08-12-2016, 07:33 PM   #2533
Trader Rating: 50 (100%+)
Anyone else notice most of guys at the Nats are running plastic steering parts
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 08-12-2016, 07:40 PM   #2534
not possible. Socket said it is a must.....
Old 08-12-2016, 07:52 PM   #2535
LMAO I'm sorry, but you're suggesting that LiveRC build out a Satellite based private WAN to carry customer's video traffic? I can assure you that will never ever ever happen. Thanks for the laugh tho!
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
