    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree326Likes
Old 08-08-2016, 01:36 PM   #2401
Originally Posted by DerekB View Post
All the "D" references we could muster.
+ YouTube Video
No more Beer Mag? Welcome back I guess.
Tony Vega is offline   Reply With Quote
Old 08-08-2016, 06:23 PM   #2402
Yes basically I was asking if the pre trimmed b5 wings will fit on the b6
NCOHOG is offline   Reply With Quote
Old 08-08-2016, 06:31 PM   #2403
Old 08-08-2016, 07:11 PM   #2404
I just test-fit an old wing that I used on my b5m. The holes line up but you might have to do a little more trimming for the shocks.
Gearhead82 is offline   Reply With Quote
Old 08-08-2016, 09:05 PM   #2405
Phillip F's Avatar
Trader Rating: 15 (100%+)
I use B5M wings and just trim it for B6.... pretty easy .
Phillip F is offline   Reply With Quote
Old 08-09-2016, 12:26 AM   #2406
Originally Posted by Phillip F View Post
B6 performed well at practice today. Had the rear shocks in front at first ... rear was super loose. Moved the shocks at the rear and it drove better. B6 is very sensitive to track condition. If the track starts drying up , you can feel the rear getting looser in the corner. Compared to my B5Mlite, I can push the buggy harder in the corners... in the straights, it's the same with the B5Mlite. The fan worked like a charm. had to put 3 layers of 3m double sided tape underneath it to take away that weird noise due to vibration. Motor was running cool and darn fast. My brother drove the car and broke this puny rear hub insert... do they make an aluminum version of this?
I have broken the same piece, i know this is a bit late but does anyone know of an aluminum replacement?
Erolyobruh is offline   Reply With Quote
Old 08-09-2016, 01:03 AM   #2407
Suspended
Trader Rating: 61 (100%+)
Look at the wiki, search the thread.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 08-09-2016, 01:18 AM   #2408
Sorry, im really new to this forum, where can i find the wiki?
Old 08-09-2016, 01:46 AM   #2409
it's "pinned" to the top of every page; you have to expand it by selecting "click here to display the full wiki" to see all the goodness
shdwboxn is offline   Reply With Quote
Old 08-09-2016, 02:04 AM   #2410
Diggity's Avatar
Trader Rating: 29 (100%+)
Default New B6 parts from Diggity Designs
Diggity Designs has just released its "Performance Line" of aftermarket carbon fibre parts for the RC10B6 and B6D buggies. Steering arm set, battery straps and shock towers. Please visit the website for more information.
www.rcamerica.com - www.teamxray.com - www.powerpushbatteries.com - www.fantomracing.com - www.kimbrough-products.com - www.diggitydesigns.com
Diggity is offline   Reply With Quote
Old 08-09-2016, 05:03 AM   #2411
Those look real nice. Much better carbon than the kit stuff also
Sean B. is offline   Reply With Quote
Old 08-09-2016, 05:15 AM   #2412
The AE inscribed battery holder is sweet looking.
Schuie Driver is offline   Reply With Quote
Old 08-09-2016, 05:56 AM   #2413
Thats awesome, i can see that ae battery holder in my future
Old 08-09-2016, 06:05 AM   #2414
What is the difference in performance with your shock tower designs and the kits?
Old 08-09-2016, 06:38 AM   #2415
Get aluminum hubs. I broke those constantly on my b5m.
mx836 is offline   Reply With Quote
