    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree366Likes
Old 08-06-2016, 03:07 PM   #2356
Suspended
Trader Rating: 61 (100%+)
Originally Posted by Cuebulon View Post
Very cool. Any pointers on the stock setup itself for a small tight clay track with dust and groove?
Start with Wenger's setup.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 08-06-2016, 03:26 PM   #2357
abailey21's Avatar
Trader Rating: 36 (100%+)
Just ordered mine today. Sadly on back order.
Im running the ECO Power 17.5, Savox 1257, Smc 120 esc, and smc 4400 shorty pack. Any idea on what pinion I should run with this bad boy?
I'm running stock because I've never ran 10th and want to get a feel for the littler cars on a track. I do plan on going mod sometime in the future.
Since i had to purchase electronics batteries and the kit i had to budget some things, but I feel my choices will prevail.
I'm running 72/32 with that motor with the schelle spur and slipper lockout
abailey21 is offline   Reply With Quote
Old 08-06-2016, 06:04 PM   #2358
AccessRacer's Avatar
Trader Rating: 20 (100%+)
Me too, same motor, laydown transmission similar to coaches setups.
AccessRacer is online now   Reply With Quote
Old 08-06-2016, 06:58 PM   #2359
Cuebulon's Avatar
What are the benefits of having the lay down? Is it just simple better aerodynamics?
Cuebulon is offline   Reply With Quote
Old 08-06-2016, 08:09 PM   #2360
Much more corner speed because lower cg & more front end weight. Plus alot more factors.
Old 08-06-2016, 11:58 PM   #2361
Phillip F's Avatar
Trader Rating: 17 (100%+)
Is this better than the stock slipper clutch?
https://www.amainhobbies.com/team-as...c91175/p226949
Phillip F is offline   Reply With Quote
Old 08-07-2016, 12:13 AM   #2362
RC*PHREAK's Avatar
Trader Rating: 120 (100%+)
yes, but for another $10 or so, you could get the avid setup which is much better.
RC*PHREAK is offline   Reply With Quote
Old 08-07-2016, 12:56 AM   #2363
Phillip F's Avatar
you mean this one?
https://www.amainhobbies.com/avid-rc...20-stk/p241376
Old 08-07-2016, 03:04 AM   #2364
abailey21's Avatar
that one or if you're going to the track tomorrow pick up a schelle I know Eric has stock of them
K.C.C.O.
Old 08-07-2016, 07:38 AM   #2365
Phillip F's Avatar
Oh yeah... I mistakenly ordered a schelle spur for this type of clutch and it's been sitting in my parts box. Might as well get the schelle version.... Thanks.
Old 08-07-2016, 08:13 AM   #2366
Trader Rating: 54 (100%+)
Def support schelle since he's always on here posting good info.
Speedychris22 is offline   Reply With Quote
Old 08-07-2016, 03:34 PM   #2367
Is the Yokomo green spring softer or harder than the Associated green? What does that spring do for the car?
Schuie Driver is offline   Reply With Quote
Old 08-07-2016, 04:25 PM   #2368
TruggyStyle's Avatar
Hi Guys,
What is the best Servo Size for a B6? Is a regular Size to heavy? Or is it better to run a LP Servo?
I'm new to 1/10 Scale 2wd and I don't know what Servo Specs are needed. Is it hard to find an ESC with HV BEC?
TruggyStyle is offline   Reply With Quote
Old 08-07-2016, 05:06 PM   #2369
BIGSKI15's Avatar
Trader Rating: 18 (100%+)
AE green is 2.00
Yoko is 2.05
AE white is 2.10
B6D
B5M
Airtronics M12
BIGSKI15 is offline   Reply With Quote
Old 08-07-2016, 05:19 PM   #2370
Cuebulon's Avatar
Originally Posted by TruggyStyle View Post
Hi Guys,
Ive been told the protek 100ss is a good budgeted starting point. Obviously you can go with higher torque or speed from there. I ent with savox 1257
Currently Active Users Viewing This Thread: 5 (3 members and 2 guests)
Aaron P, bshack, Fearo
