    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree360Likes
Old 08-04-2016, 08:09 PM   #2326
RCBuddha's Avatar
Trader Rating: 35 (100%+)
http://www.redrc.net/2016/08/team-as...ttery-weights/
RCBuddha is offline   Reply With Quote
Old 08-04-2016, 10:37 PM   #2327
Originally Posted by RCBuddha View Post
ace hardware sells 2in x 12in strips of brass at varying thicknesses; just have to cut it to shortly length, youll get 2 plates with a little left over if you want to get creative placing the excess elsewhere. half the price for a few minutes of work.
http://www.acehardware.com/product/i...uctId=34827176
shdwboxn is offline   Reply With Quote
Old 08-05-2016, 03:47 AM   #2328
But that's ghetto.
Sean B. is offline   Reply With Quote
Old 08-05-2016, 04:34 AM   #2329
Trader Rating: 24 (100%+)
Other than the weight, these seem to be pretty much the same as the Reedy brass shorty weights they came out with a few months ago?
https://www.teamassociated.com/parts...ry_weight_set/
AMessy is online now   Reply With Quote
Old 08-05-2016, 05:43 AM   #2330
I don't know if more tailored to the B6/B6D in shape, but very likely just a custom weight at 26 and 43g vs the 19 and 39g those others Reedy brand has.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 08-05-2016, 05:47 AM   #2331
Nice Factory RC bits!
https://www.facebook.com/FactoryRcPr...62101423909171
Old 08-05-2016, 06:05 AM   #2332
goehm's Avatar
Trader Rating: 44 (100%+)
Looking at the steering plate in the last picture made me wonder about different methods to adjust ackerman. Is there any benefit to adjusting it at the wheel/spindle vs. on the steering rack?
--GO!
Come visit G's RC Raceway / Shippensburg, PA / www.GSRC.us
goehm is offline   Reply With Quote
Old 08-05-2016, 06:20 AM   #2333
DennisNyholm's Avatar
Originally Posted by Sean B. View Post
But that's ghetto.
I'd say it's smart.
DennisNyholm is offline   Reply With Quote
Old 08-05-2016, 07:49 AM   #2334
Originally Posted by Kraig View Post
You could try looking at the manual for the TC7. It talks about anti-squat and pro-squat and what they do.
Download Associated's tuning app for your phone. Search for RC cheat sheets. Breaks down almost every adjustment you could think of.
mx836 is offline   Reply With Quote
Old 08-05-2016, 04:12 PM   #2335
Can someone let me know how wide the cut gears are? Also are all of them the same width? Thanks!
NCOHOG is offline   Reply With Quote
Old 08-05-2016, 04:42 PM   #2336
Suspended
Trader Rating: 61 (100%+)
Who'se? I don't know of anyone besides myself who has made any.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 08-05-2016, 06:46 PM   #2337
Trader Rating: 140 (100%+)
making myself
cut gears,,, cut and drilled topshafts
RC RACING DESIGNS..
slick1 is offline   Reply With Quote
Old 08-05-2016, 08:22 PM   #2338
Suspended
Need to finish drilling that diff gear
Old 08-05-2016, 08:48 PM   #2339
Looking forward to running my B6D for the first time tomorrow. Swore I won't run 17.5 ever again because I refused to abide by the "Keep up with the Jone's" mentality of of stock racing. But I figured I'd try the B6D the try in stock class.
Bill
AE SC5M / Viper VTX10R & Maclan 10.5
Schumacher KD and KC / Maclan MMax Pro & MMR Team Edition 17.5
Schumacher KF2 / VTX 10R & MMR 17.5
Schumacher K2 / MMax Pro & MMR Team Edition 13.5 /// Airtronics MT-4
Riverbluff is offline   Reply With Quote
Old 08-05-2016, 08:58 PM   #2340
Originally Posted by slick1 View Post
making myself
Very nice. Can't wait till someone offers that to the general public.
flintTRDTC is offline   Reply With Quote
Currently Active Users Viewing This Thread: 9 (5 members and 4 guests)
2dialed, Aaron P, jct108, nesbot
