    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree326Likes
Old 08-03-2016, 12:37 PM   #2296
Suspended
Trader Rating: 61 (100%+)
Originally Posted by Phillip F View Post
Question. What does a slipper eliminator do?
http://lmgtfy.com/?q=slipper+eliminator
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 08-03-2016, 01:13 PM   #2297
Trader Rating: 14 (100%+)
Originally Posted by rvrslt1 View Post
So I ran my B6D last night for the first time at OCRC last night. It was good but, know it can be much better. Current set up is
2-1x6 35wt White springs up front
2-1x7 30wt green springs in rear
Ride high 22mm front and rear
Lay down with brass C mount
AE D mount and AE front bulk head
17.5 with slipper eliminator.
Gearing 31/69
B5M Schelle rear hubs
Car really wanted to push in the turns on power. I was told to drop the front oil to 32.5 and gray spring and this would help.
Any other ideas? Thanks for all the help!
Try this one. It was super easy to drive at SDRC, grip was pretty good that day though.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875 vs Tekno EB410, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 08-03-2016, 01:39 PM   #2298
I've been out of racing for about 18 months. I have carpet and clay tracks near by and was thinking of buying the B6D and have the B6 parts on hand. Is it just best to buy both or consider the parts and swap out parts the night before?
daveb is offline   Reply With Quote
Old 08-03-2016, 01:45 PM   #2299
Phillip F's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Socket View Post
Interesting. .. So it's like a direct drive. I use those back when I was racing 1/8 on road... But those were used when there is a tin of traction. Foam tires... Sugar coated track..
Phillip F is online now   Reply With Quote
Old 08-03-2016, 02:14 PM   #2300
Jmuck69's Avatar
Only used in 17.5 racing. Use in mod and you will destroy idle gears.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 08-03-2016, 04:14 PM   #2301
AccessRacer's Avatar
Trader Rating: 20 (100%+)
What length sensor wire do I need for the b6d?
AccessRacer is offline   Reply With Quote
Old 08-03-2016, 05:14 PM   #2302
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
175mm and you will be safe. That's what most use.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-03-2016, 05:32 PM   #2303
Trader Rating: 16 (100%+)
I'd go with the B6D and get the laydown transmission conversion kit ($30) and a gear diff. Best of both worlds and easy to swap back and forth.
MX304 is offline   Reply With Quote
Old 08-03-2016, 06:56 PM   #2304
rvrslt1's Avatar
Trader Rating: 25 (100%+)
Put Wenger's setup on it and start from there. His stand up car was nothing short of perfect.
His set up has a 3 gear stand up. I did not try his set up due to not having the parts. Last night at OCRC both Losi and AE had all the best out. It was crazy to watch them drive. Spinner was running with new Jconcepts tires and Jason timeing his his laps and others watching. TLR had its heavy hitters out too. Funny thing is only TLR drivers will help out us normal folks. Jake from inside and even Mayfield looked at my car and gave ideas. I would just like to say TLR guys are MUCH more helpful. To be honest I don't even race. I just enjoy going to the track when I can. Some day I hope to try but until then I will just enjoy the hobby of RC! This site has been a big help with everyone one it so thank you.
rvrslt1 is offline   Reply With Quote
Old 08-03-2016, 07:20 PM   #2305
rvrslt1's Avatar
Thanks. Will give this a try.
What is the big deal with the long and short schock eyelet?
Old 08-03-2016, 08:08 PM   #2306
aeRayls's Avatar
Long on the front for outside hole only. Long in the rear is for shocks on back of the arm only.
aeRayls is offline   Reply With Quote
Old 08-03-2016, 08:36 PM   #2307
Cridd's Avatar
Default Servo
What did I do wrong on servo, simple but thought I would ask - throw hitting on cars right side of top plate. Using AE 25 tooth alum horn.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 08-03-2016, 08:44 PM   #2308
tsair's Avatar
You have to use the plastic spacers on the servo mount with the Savox, else the bottom screw pushes the servo up at an angle --
Alternatively, you could use shorter servo screws.
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 08-03-2016, 08:51 PM   #2309
Cridd's Avatar
Thanks. Appreciated.
Chris
B6D / T5M / SC5M
Old 08-03-2016, 09:30 PM   #2310
8g and 13g Aluminum Chassis weight plates are in stock at Tower. Limited quantities.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
shdwboxn
