    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree369Likes
Old 08-03-2016, 08:11 AM   #2281
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by Schuie Driver View Post
Can somebody point me to someplace I can try to learn about anti squat and roll centers? The B6D has a lot of adjustments in this area, but the manual doesn't really get into much detail about what changes you can expect by moving the pills in the C block. (Quite honestly the manual confuses the heck out of me here.)
You could try looking at the manual for the TC7. It talks about anti-squat and pro-squat and what they do.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 08-03-2016, 08:13 AM   #2282
The weight sets can be used to alter the weight bias front to rear, not just add weight to the car in general. These cars have evolved to a point where it doesn't just matter the total weight of a car, but where the weight is on the chassis. You can use the heavy brass C block and no plates up front, or use the weight plates with the stock C/D blocks and have the same (or close) total weight, but two completely different weight biases. They're just tuning aids to help you get the desired feel that you're looking for.
Team Associated / Reedy / JConcepts / BoomRC
boucher is offline   Reply With Quote
Old 08-03-2016, 08:19 AM   #2283
rvrslt1's Avatar
Trader Rating: 28 (100%+)
So I ran my B6D last night for the first time at OCRC last night. It was good but, know it can be much better. Current set up is
2-1x6 35wt White springs up front
2-1x7 30wt green springs in rear
Ride high 22mm front and rear
Lay down with brass C mount
AE D mount and AE front bulk head
17.5 with slipper eliminator.
Gearing 31/69
B5M Schelle rear hubs
Car really wanted to push in the turns on power. I was told to drop the front oil to 32.5 and gray spring and this would help.
Any other ideas? Thanks for all the help!
rvrslt1 is offline   Reply With Quote
Old 08-03-2016, 11:25 AM   #2284
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Reduce front droop and/or increase rear anti-squat.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 08-03-2016, 11:57 AM   #2285
Originally Posted by AssociatedRcFan View Post
Since the ae weights havn't caome out yet, I just saw these vrp weights posted on Inside Line Rc. They look neat. I like the idea of having 2 different looks where you can flip them.
The AE plates are out already. Ordered mine yesterday. The VRP plates will give you an option of companies to order from though. Looks like they offer them in 9g and 13g just like AE. Solid first post.
Old 08-03-2016, 12:46 PM   #2286
Suspended
Trader Rating: 61 (100%+)
Gearing 31/69
Put Wenger's setup on it and start from there. His stand up car was nothing short of perfect.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 08-03-2016, 12:56 PM   #2287
Originally Posted by boucher View Post
An aftermarket option for shock towers:
http://www.redrc.net/2016/08/x-facto...-shock-towers/
Link to XFactory listing the parts.
http://www.xfactorystore.com/Infinit...-p/xf-i120.htm
http://www.xfactorystore.com/Infinit...-p/xf-i121.htm
http://www.xfactorystore.com/Infinit...-p/xf-i122.htm
http://www.xfactorystore.com/Infinit...-p/xf-i123.htm
GonzoKY is offline   Reply With Quote
Old 08-03-2016, 01:02 PM   #2288
JAE
I saw factory settings had the caster block shim on the bottom of the caster blocks. Putting them on the top should give you tighter turning. Saw a bunch at ocrc doing this when the buggy was released.This is what i did with my xray xb2.
Gearing 31/69
JAE
JAE is offline   Reply With Quote
Old 08-03-2016, 01:23 PM   #2289
Phillip F's Avatar
Trader Rating: 17 (100%+)
Gearing 31/69
Question. What does a slipper eliminator do?
Phillip F is offline   Reply With Quote
Old 08-03-2016, 01:27 PM   #2290
awidz's Avatar
Where did you order your plates from, I have looked on associated sight, amain and tower none of them have them
awidz is offline   Reply With Quote
Old 08-03-2016, 01:27 PM   #2291
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Eliminate the slipper.
Lighter weight but drivetrain will take any impacts directly. Only really beneficial when grip is high.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-03-2016, 01:28 PM   #2292
Super Moderator
I believe he got them from eBay
Old 08-03-2016, 01:34 PM   #2293
awidz's Avatar
Just looked on ebay, nothing listed for Associated b6 steel chassis plates. Would love to find out where he got them since associated does not even have them in stock
Old 08-03-2016, 01:35 PM   #2294
Super Moderator
If he got them from eBay then they would no longer be on eBay....
Old 08-03-2016, 01:37 PM   #2295
Yeah I got mine off eBay. But I've heard AE will have them soon on their site.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
05PSD
