    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree370Likes
Old 08-02-2016, 04:07 PM   #2251
"Smiley"'s Avatar
Trader Rating: 166 (98%+)
Originally Posted by Socket View Post
So you're telling me this is a flatter surface:
Than this:
I'll have whatever you're having. It's some strong stuff.
Wow, you don't get it. I'm talking about the surface you are currently mounting your esc and receiver to. On the actual chassis it self. It is "milled".
Vision Racing Products | Team Associated | AKA | Tekin | Sanwa | VP Powermaster Fuel | RC Concepts Engines | MIP | Avid | Boom RC Graphics | Paint By: "Smiley"
Vision Racing Products (VRP)- www.visionracingproducts.com
"Smiley" is offline   Reply With Quote
Old 08-02-2016, 04:08 PM   #2252
Suspended
Trader Rating: 61 (100%+)
My electronics are not mounted on the chassis, they're mounted to the AE plate I posted.
Don't assume...
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 08-02-2016, 04:11 PM   #2253
"Smiley"'s Avatar
Don't assume...
I'm talking in general...99% of people are currently mounting their electronics on the chassis surface. Do they not stick fine there? I do believe so. Our VRP weights look milled deeper than they are. You can run your finger across them and they are butter smooth. All you are seeing is the pattern left from being milled.
Old 08-02-2016, 04:13 PM   #2254
Suspended
I'm talking in general...99% of people are currently mounting their electronics on the chassis surface. Do thy not stick fine there? I do believe so. Our VRP weights look milled deeper than they are. You can run your finger across them and they are butter smooth. Ball you are seeing is the pattern left from being milled.
Cool. You kept saying "You" and were talking to me. That's what I was replying to.
Old 08-02-2016, 04:23 PM   #2255
BRSracing's Avatar
Trader Rating: 55 (100%+)
I just wish they would get the weights out to the majority of us......
BRSracing is offline   Reply With Quote
Old 08-02-2016, 04:52 PM   #2256
awidz's Avatar
Yeah no one has chasis weight or the darn sway bar kits I need to setup my b6 for carpet Offroad, comon associated
awidz is offline   Reply With Quote
Old 08-02-2016, 05:04 PM   #2257
Phillip F's Avatar
Trader Rating: 17 (100%+)
Just replace more aluminum parts so it's more weights. LoL
Phillip F is offline   Reply With Quote
Old 08-02-2016, 05:25 PM   #2258
I'm with Smiley here a bit. The chassis itself is not only milled markings but they hit the whole chassis with like a sand blast effect and then anodize. It is very slick for mounting anything. Trying a few different kinds of double sided tape and the ESC is still coming undone with the alcohol cleaning treatment.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 08-02-2016, 05:30 PM   #2259
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
I use 3m tape with zero issues. Don't even clean it prior....
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-02-2016, 05:32 PM   #2260
"Smiley"'s Avatar
In electric 1/8 and 1/10, I've found the gorilla brand clear double sided tape to work best. Super sticky, easy to remove.
Old 08-02-2016, 06:08 PM   #2261
Matt the 3M is the VHB clear gel looking stuff? Wildcat and Socket have given me their opinions on stuff.
I bought LePage (Canada Brand only I think) Indoor 35Kg stuff that is clear VHB stuff that was tacky to the touch and it did not work on the B5M on Saturday. I did get the Automotive foam based gray 3M body molding Super Strong stuff another one suggested. Still have to try it.
Old 08-02-2016, 06:11 PM   #2262
That Gorilla stuff is the first tape I've found that I liked. Smiley, I just ordered the AE plates, but I'm curious to see those VRP ones next time I'm over your way.
Team Associated / Reedy / JConcepts / BoomRC
boucher is offline   Reply With Quote
Old 08-02-2016, 06:32 PM   #2263
Super Moderator
Yeah. Comes in a roll, has a jelly type feel to it. I've used that and the heavier duty gray 3m roll with zero issues. I used to tape my pack in with the gray stuff.
Old 08-02-2016, 06:37 PM   #2264
"Smiley"'s Avatar
Sound good. We will have more B6 parts coming soon. Keep an eye out
Old 08-02-2016, 07:10 PM   #2265
abailey21's Avatar
Trader Rating: 36 (100%+)
Originally Posted by Phillip F View Post
Race on a Sunday afternoon.. It's pretty laid back and not a lot of sand baggers in the sporstman class. LOL
Scott was sandbagging lol
K.C.C.O.
abailey21 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 14 (9 members and 5 guests)
05PSD, aeRayls, Be6, frankf, hipster, jamsandolina, lexusbest, Ogleheat, raved007
