Team Associated B6 & B6D thread >
Like Tree649Likes
    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Old 07-29-2016, 03:20 PM
  #2086
Originally Posted by Schuie Driver
Just called my LHS and lo and behold they had a B6D kit in stock so I guess after work I'll be picking up a new car
Thanks for posting! I ordered one from Tower but the ship date just got pushed out another couple weeks. I saw your location and called up the shop to make sure he had more than 1 in stock, then went and picked one up! He had the parts for the laydown conversion too.
Gearhead82 is offline
Old 07-29-2016, 03:30 PM
  #2087
Excellent! Yeah, I thought about the laydown, but I didn't end up getting it. I may end up regretting that decision.........
Schuie Driver is offline
Old 07-29-2016, 06:19 PM
  #2088
mick33b4's Avatar
Trader Rating: 14 (100%+)
Originally Posted by 40yoCaliRacer
This exact same thing happened last night at LRH. At one point, they didn't water for maybe 1.5 hours and it just dried out. Coming out of turns on throttle the car would just spin out. I had to adjust my driving. Once the watered it was great.
You can also remove a ball stud washer from the rear inner camber link. A higher rear roll center (lower inner link) will let you push harder on exit. You will also give up some traction on entry, but gain rotation.
mick33b4 is offline
Old 07-29-2016, 06:46 PM
  #2089
Trader Rating: 17 (100%+)
Originally Posted by Socket
The protek 4250 is the hot battery right now, and has been for a few months.
It can be overvolted to 4.35V per cell, and has magnificent IR's when charged at 70 amps.
This sounds awesome, but how do you get it to do that? In laymans terms, I'm no pro. Thanks!
MrLean is offline
Old 07-29-2016, 07:04 PM
  #2090
Trader Rating: 25 (100%+)
Please delete, double post from phone.
aalewis is offline
Old 07-29-2016, 07:37 PM
  #2091
awidz's Avatar
Trader Rating: 15 (100%+)
Originally Posted by boucher
Here's a cheap solution I found on fb that won't rely solely on double sided tape..
Use a longer screw on the "driver's side" of the C block, couple ball stud washers, a servo mount, and a nut.
Yep this was rivkins car, he and cav do this
awidz is offline
Old 07-29-2016, 07:40 PM
  #2092
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
rivkin's cars with a tekin motor?
Wildcat1971 is offline
Old 07-29-2016, 07:49 PM
  #2093
Suspended
Trader Rating: 61 (100%+)
Beat me to it.
Socket is offline
Old 07-29-2016, 11:41 PM
  #2094
Trader Rating: 43 (100%+)
Default Fan Mount B6
YES!!! solves my motor high temp. My gearing and timing is perfect for the track I race at and was getting 167 temps after a 5 minute run. This will lower it down a bit. Thank you BOUCHER !!
Phillip F is offline
Old 07-29-2016, 11:47 PM
  #2095
Originally Posted by Silverstonev8
I still have mine
that protech charger. love the automotive fuses lol... the memories!
shdwboxn is offline
Old 07-30-2016, 12:13 AM
  #2096
Pistol123's Avatar
Originally Posted by Phillip F
Okay. I ran my B6 tonight at the track and when the track dries out a bit. The rear just breaks loose and loses traction when I gun the buggy exiting a corner. What should I do?
I had similar running a dex210 on grass in mm3 , tried putting weight on the rear but it didn't sort it. In the end lengthening the rear camber links sorted. I'm not sure why but it appeared I was lifting the inside rest tyre on throttle. Night work similar on the b6.
Pistol123 is offline
Old 07-30-2016, 12:29 AM
  #2097
interesting...so you were running positive camber on your rear ?
Old 07-30-2016, 02:18 AM
  #2098
I looked around the best I could, but I could not find... I have the aluminum "D" mount in my B6D. Is there a chart that shows the different settings (with corresponding toe/anti-squat) of pill settings for the "D" mount like they have for the "C" mount". I realize that having both, the combinations are endless, but just wondering if there was an additional chart with the "D". Thanks!
dustneyes is offline
Old 07-30-2016, 02:37 AM
  #2099
AZJP's Avatar
Trader Rating: 21 (100%+)
Where do you get positive camber from that?
AZJP is offline
Old 07-30-2016, 03:33 AM
  #2100
Pistol123's Avatar
No -1' rear camber. I wondered if it was the roll centre raising too much, but with the longer top links the rear is bolted down and can now whack open the throttle. If I'm honest it now has a little too much rear grip mid corner, so a little more front grip/lead rear grip is the next thing to try.
