    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree360Likes
Old 07-28-2016, 09:47 AM   #2011
Suspended
Trader Rating: 61 (100%+)
I'm ready for some carpet!
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-28-2016, 09:58 AM   #2012
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
you going to run ball or gear diff on carpet?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-28-2016, 10:00 AM   #2013
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
He only has a ball diff
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-28-2016, 10:17 AM   #2014
Suspended
Ball diff. I have her cranked down pretty hard.
Old 07-28-2016, 10:31 AM   #2015
Trader Rating: 140 (100%+)
after seeing egalsim's rc10 body ,,, had to do it for myself
my colors,, and it actually got around the track well!! thought it would be more rollie in the corners,,,, good thing of high wing, i caught the pipe and it rolled right back to the wheels, kinda like a 1/12 pogo antenna, LOL
RC RACING DESIGNS..
slick1 is offline   Reply With Quote
Old 07-28-2016, 10:40 AM   #2016
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
For those who have experience, even just racing against experience, how are these comparing to say the Xray xb2 as far as performance and parts quality / wear goes?
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 07-28-2016, 10:45 AM   #2017
had xray and now have b6,,, both are great,,,
only difference is xray is like 6 screws to get diff out..
b6 is like 22 screws to get all the way to diff.. (laydown)
performance and durability are very comparable!!!!
RC RACING DESIGNS..
Old 07-28-2016, 10:49 AM   #2018
Suspended
Parts are literally 1/3 the cost, with what I think matching quality.
The car itself has more corner speed and more bite. I felt like I had the xray pretty good outdoors, but it required in my opinion a lot of work an deviation from OEM parts.
The B6D out of the box worked just as well, and with some tweaks really woke up.
The lack of a 3 gear laydown for high bite is a fail by xray. The lack of a alloy parts as OEM is also a fail.
The timeframe to get parts out for the xray is lacking.
Old 07-28-2016, 10:51 AM   #2019
Motorman007's Avatar
Trader Rating: 78 (100%+)
Socket have you wheeled a Kyohso RB6? If so could you give your insight on that too. And what you have seen RB6 wise in your Area. thank you
YOU WILL (ALWAYSWIN).....
Motorman007 is offline   Reply With Quote
Old 07-28-2016, 10:52 AM   #2020
Tech Legend
Cain's Avatar
Thanks for the info!
Side question, I see guys running some rims that have recesses for the hexes, using Jconcepts here that don't have that, what type in general seem to be the best that are Associated compatible?
Old 07-28-2016, 10:57 AM   #2021
egalsim's Avatar
Trader Rating: 39 (100%+)
Sweet!!!!
Associated RC10B6 / Kyosho Optima / Associated Tekno SC8e / Awesomatix A700exl / Serpent Cobra BE 2.1 Rally / Kyosho MP9 Tki3.5 Tekno V4 / Xray Xb4 2017 / Serpent SDX4
egalsim is offline   Reply With Quote
Old 07-28-2016, 11:15 AM   #2022
Suspended
The Kyosho about 2 years ago fell off hard here in AZ. They had a few sponsored drivers not do well by them, and no one has had a Kyo deal since. I know a guy who stuck by his for awhile and made it work, but I have not personally driven or owned one.
Doesn't mean I wouldn't buy a RB6.6 tomorrow! With my ADD when it comes to chassis, it wouldn't surprise anyone.
The internet racer in me thinks it looks cool, and I know Kyo quality is top notch. The only thing I worry about the Kyo is parts cost and availability. Of course, this is after I just spent $100 on Kyo springs.
Old 07-28-2016, 11:20 AM   #2023
Suspended
I still really like the way factory AE wheels fit. I usually buy wheels 10 sets at a time, and have stuck with OEM. They hold up great, as I generally acetone my wheels and reuse them. I can get 4-5 uses out of a set of wheels before I toss them.
I'm not a giant fan of JC products because of a few of the drivers they sponsor, but I have a set of their wheels and think they fit fine..the different white is annoying.
Then there's Rawspeed wheels. They're different than anything I've EVER ran, and remind me a TON of the Xray soft wheels. Tons of flex, which I like on outdoors and rough tracks, I think flex is a friend when it comes to chassis outdoors because it'll plant the car more.
Old 07-28-2016, 11:28 AM   #2024
For 2.2 I really like the Avid wheels. Light weight and a more flat faced look. For 2.4, I like the AKA wheels. Nice hex engagement on both and durability. The avid wheel is the most durable wheel I have ever owned.
Old 07-28-2016, 12:01 PM   #2025
suby723's Avatar
Trader Rating: 21 (100%+)
I race on carpet mostly and IMO the xb2 was an epic let down. Broke a RR hanger and typical of Xray they refused to acknowledge it was an issue until a ton of people where breaking them. The deal breaker for me was the lack of a 3 gear laydown and no gullwing arms. The car never had a lot of on power steering. Getting to the diff with only 6 screws was nice but not good enough of a reason to continue racing the car.
suby723 is offline   Reply With Quote
