    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree366Likes
Old 07-26-2016, 07:46 PM   #1981
TAW
Trader Rating: 18 (100%+)
Send a message via AIM to TAW
Originally Posted by nttdemented View Post
All this talk about springs. Anyone buy a B6 and ran it on high bite carpet with the stock setup and springs?
I'm about to take mine out for the first time this weekend.
Yes my son ran his box stock on our high bite carpet track and we had some issues. I couldn't get the ride height below 18mm os we had some tracking rolling. The car is very reactive and almost twitchy with the stock setup/springs.
I went to softer springs front and rear, also went from 2mm to 1mm spacer on the akerman and that settled it down a little.
TAW is offline   Reply With Quote
Old 07-26-2016, 08:08 PM   #1982
Phillip F's Avatar
Trader Rating: 17 (100%+)
so which Associated spring is close to the Kyosho Gold Fronts and Yokomo rear green?
I don't understand why people just gave up on the Associated springs when Associated also have a selection of soft shock springs.
Phillip F is offline   Reply With Quote
Old 07-26-2016, 08:26 PM   #1983
TAW
Im still running AE springs I think I went to blue in the front and white in the rear.
Old 07-26-2016, 08:27 PM   #1984
TAW
And for me if I go to the kyo springs it will be because they are shorter and I really need to get to 17mm ride height.
Old 07-26-2016, 08:51 PM   #1985
Trader Rating: 14 (100%+)
Originally Posted by rvrslt1 View Post
So on a B6D with lay down what is the best spring set up for clay (OCRC) track? If you have part numbers if different than AE please let me know. I have had my car built for over a week and have not had time to try it out.
White/Green seems to be the way to go if you are sticking with Associated and running the laydown. Coach isn't running the laydown.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875 vs Tekno EB410, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 07-26-2016, 09:06 PM   #1986
Suspended
Trader Rating: 61 (100%+)
Inconsistent rates. I had AE whites almost twice as stiff as their "rating". Then had greens softer than blacks.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-26-2016, 10:49 PM   #1987
Changing ackerman seems simple enough to do track-side. What about thoughts regarding the need (or lack thereof) for sway bars while running on carpet?
nttdemented is offline   Reply With Quote
Old 07-26-2016, 10:52 PM   #1988
goehm's Avatar
Trader Rating: 44 (100%+)
I noticed that that on average the greens were only .02 harder than the blacks. I measured two pairs of each type.
I thought I was crazy until I read your post.
--GO!
Come visit G's RC Raceway / Shippensburg, PA / www.GSRC.us
goehm is offline   Reply With Quote
Old 07-26-2016, 11:21 PM   #1989
Is there an easy way to measure spring rates?
Gearhead82 is offline   Reply With Quote
Old 07-27-2016, 05:09 AM   #1990
TAW
We ran the rear sway bar on the 5 car so once they start shipping we will run one for sure on the rear. May try the front as well.
Old 07-27-2016, 07:01 AM   #1991
tsair's Avatar
If you have a drill press and a scale you can measure lbs./in. pretty easily.
I had a Dremel stand that I got cheap from a friend that does the same thing --
http://razorrc.tumblr.com/post/14297.../spring-tester
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 07-27-2016, 07:05 AM   #1992
"Smiley"'s Avatar
Trader Rating: 166 (98%+)
When I ran mine for the first time (B6D w/laydown), I ran the kit white/green on our local indoor very high grip clay track. They felt really good. I will try other springs, but I'm almost positive i'll come back to the white/green. They have a really good balanced feel. I was also running the VRP 2x1.6 front and 2x1.7 rear with optional hard valves.
Vision Racing Products | Team Associated | AKA | Tekin | Sanwa | VP Powermaster Fuel | RC Concepts Engines | MIP | Avid | Boom RC Graphics | Paint By: "Smiley"
Vision Racing Products (VRP)- www.visionracingproducts.com
"Smiley" is offline   Reply With Quote
Old 07-27-2016, 07:21 AM   #1993
Integy makes a small tool for measuring spring rates. You install an empty shock and plunge to a depth. (Tip, you have to preload the spring in order to get an accurate spring rate)
Just a heads up, the spring rate doesn't change much over time. The spring load (height at a given load) can change and that is why you sometimes need to turn the collars down further to get the same ride height.
We have a good industrial tester here at work but there's no way I'm shelling out $20 for a single pair of Kyosho springs to measure. We use high temperature springs that cost a fraction of that. Even made in the US.
Fred_B is offline   Reply With Quote
Old 07-27-2016, 08:50 AM   #1994
RCBuddha's Avatar
Trader Rating: 35 (100%+)
http://www.redrc.net/2016/07/mip-b6-...-drive-system/
RCBuddha is offline   Reply With Quote
Old 07-27-2016, 08:52 AM   #1995
RCBuddha's Avatar
https://www.amainhobbies.com/gforce-...fc0132/p440239
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
fullsyzz
