    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree323Likes
Old 07-24-2016, 06:31 PM   #1921
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by Sean B. View Post
Is anyone running a D with a laydown on medium grip clay? Wondering if it's worth a try or just go with standard trany.
Medium grip is such a relative term. For $30, I definitely think the laydown is worth trying. The car just feels so balanced and has so much corner speed. If you truly have medium grip. I like this car so much. Easy to work on, corner speed for days.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-24-2016, 06:47 PM   #1922
Trader Rating: 14 (100%+)
Originally Posted by 40yoCaliRacer View Post
Is this because there is too much steering?
We club race tomorrow night at LRH, and I have the rear shocks set up on the front of the arm currently. Really won't have much time to practice with it before racing starts. Just running 17.5 Blinky, wonder if I should change them to the back. Don't have any weights either except for battery weights (for now). Before paint I was around 1485 grams last night I think with a small shorty in there.
Whats interesting about this is just last week Hartsen preferred the stand up tranny at OCRC. It seems like they are narrowing ups the pivot mounts as well. I went by this afternoon and another one of the fast kids had them in front as well.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875 vs Tekno EB410, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 07-25-2016, 05:18 AM   #1923
soniccj5's Avatar
Finished cutting out the body and adding stickers at the track.
Running laydown with 6.5 on clay. Needed to turn the timing down, cut back the end points on the radio and still had to be easy on the trigger.
The car corners amazing and I had plenty of grip on our track with Primes in the rear.
Now I just need some track time to get used to all that extra speed.
RC-10/ B4(+8mm)/
B5M FactoryLite|GTB3|Vulcan 17.5|MIP Pucks|Proline Primes|
B64D|510R|6.5 Vulcan
B6D|510R|7.5 Reedy
soniccj5 is offline   Reply With Quote
Old 07-25-2016, 06:47 AM   #1924
Finalist's Avatar
^that. A bunch of went laydown and are not looking back. The speed is too much fun and I don't feel it lacks anything. I have no desire to go back to stabd up.
Finalist is offline   Reply With Quote
Old 07-25-2016, 07:49 AM   #1925
Kind of interested on how Laydown works in the low grip area of a B5R
man1ac is offline   Reply With Quote
Old 07-25-2016, 09:37 AM   #1926
Pinkz's Avatar
is there going to be a stadium truck or short course truck based off this new platform?
It rubs the lotion on its skin or else it gets the hose again.....Yes, it will, Precious, won't it? It will get the hose! https://www.youtube.com/watch?v=cyn0DVSn96I
Pinkz is offline   Reply With Quote
Old 07-25-2016, 09:58 AM   #1927
Suspended
Trader Rating: 61 (100%+)
Why wouldn't there be? They've been following that method since their inception. The only question will be time frame when it's out.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-25-2016, 11:01 AM   #1928
city.life's Avatar
Electronics installed and ready to run
Team Associated B6 & B6D thread-dsc00420_1600.jpg   Team Associated B6 & B6D thread-dsc00410_1600.jpg   Team Associated B6 & B6D thread-dsc00419_1600.jpg
city.life is offline   Reply With Quote
Old 07-25-2016, 11:05 AM   #1929
Mason's Avatar
#CarNumbersAreComingBack
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is online now   Reply With Quote
Old 07-25-2016, 11:09 AM   #1930
Finalist's Avatar
Anyone know the weight difference between the MIP puck system (all aluminum kit, orange plastic pucks, al CVAs, etc) versus the stock steel stuff with pins? exact weight would be great, but I can't remember if it was 20-35grams lighter?
I'm trying to figure out which brass D mount I'll want - 12g or 25g.
Old 07-25-2016, 11:30 AM   #1931
Suspended
I'm reaching from the B5M days, 40g was the difference.
Old 07-25-2016, 11:41 AM   #1932
You can remember that far back?
Team Associated / Reedy / JConcepts / BoomRC
boucher is offline   Reply With Quote
Old 07-25-2016, 11:43 AM   #1933
Finalist's Avatar
40 grams - it was that much? I remember weighing mine, but the number is long gone from my brain. thanks
Old 07-25-2016, 11:43 AM   #1934
40........no. more like 25
Old 07-25-2016, 12:01 PM   #1935
Suspended
I'd recommend looking through the B5M thread.
My numbers may be skewed as I usually run drilled outdrives and Ti axles.
Currently Active Users Viewing This Thread: 7 (3 members and 4 guests)
bobf24, geekfam
