    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree370Likes
Old 07-22-2016, 07:26 PM   #1876
Originally Posted by egalsim View Post
Almost done, just need the esc and servo. Running Kyosho Velvet shocks on this.
What wheels are those? Are they a direct fit?
MrLean is offline   Reply With Quote
Old 07-22-2016, 07:30 PM   #1877
egalsim's Avatar
Trader Rating: 39 (100%+)
Yes direct fit 12mm hex 2.2 wheels. From a Helion criterion 2wd buggy.
egalsim is offline   Reply With Quote
Old 07-22-2016, 08:35 PM   #1878
RCBuddha's Avatar
Trader Rating: 35 (100%+)
tempting....
http://www3.towerhobbies.com/cgi-bin...?&I=LXGFJW&P=7
RCBuddha is offline   Reply With Quote
Old 07-22-2016, 08:47 PM   #1879
abailey21's Avatar
Trader Rating: 36 (100%+)
Originally Posted by RCBuddha View Post
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 07-22-2016, 09:27 PM   #1880
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I will pass on any and all gold bling.....
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-22-2016, 09:38 PM   #1881
Phillip F's Avatar
Trader Rating: 17 (100%+)
Originally Posted by abailey21 View Post
Gear diff is working great on high bite indoor in SoCal. We're running slicks to give an idea of grip.
Most of us bought the B6 and the full arms are working better than flats too
what springs and shock oil are you guys using?
Phillip F is offline   Reply With Quote
Old 07-22-2016, 09:55 PM   #1882
Which track?
40yoCaliRacer is offline   Reply With Quote
Old 07-22-2016, 10:01 PM   #1883
abailey21's Avatar
Originally Posted by 40yoCaliRacer View Post
Which track?
SCVRC in Santa Clarita.
And for the guy above shocks in the rear, white springs up front and green tears with 30wt on all 4 corners
Old 07-22-2016, 10:25 PM   #1884
Phillip F's Avatar
sweet, Jake Mayo is running Kyosho and Yokomo springs with 30 wts
That is exactly my spring setup for my B5M. Do you have all pins and gears in the diff with the stock 4K or are you running Jake Mayo's setup too?
Old 07-22-2016, 10:28 PM   #1885
abailey21's Avatar
All the pins in the diff with 4k
K.C.C.O.
Old 07-23-2016, 02:36 AM   #1886
Finished my B6D build! Everything went great, no missing parts!
Used the Brass stuff and some weight do match it my B5M FL setup for our loose clay track.
Maybe interesting:
B5m FL:
F 550g
R 1046g
(34/66%) and overall of 1596g
B6D
F 566g
R 983g
(37/63%) and overall of 1549g
Both cars shared the same electronics on the scale (HW V3.1, Savox 1257TG, 4200 Shorty and HW Fleta ZX 7.5T)
The numbers let me think of quite a loose rear
man1ac is offline   Reply With Quote
Old 07-23-2016, 08:03 AM   #1887
RCBuddha's Avatar
http://www.liverc.com/news/new_produ..._3DGY_Designs/
Old 07-23-2016, 10:32 AM   #1888
Trader Rating: 94 (100%+)
Maybe interesting:
B5m FL:
F 550g
R 1046g
B6D
F 566g
R 983g
so far it is!
redracerd is offline   Reply With Quote
Old 07-23-2016, 12:10 PM   #1889
Trader Rating: 18 (100%+)
Has anyone had any issues with the steering system? I have the aluminium steering rack and set up up per the manual with a ko low profile servo. With the servo horn at the 90 Mark, the rack is off center to the left. I took it apart and rebuilt it bit no dice. Any ideas?
Chris Brown is offline   Reply With Quote
Old 07-23-2016, 12:16 PM   #1890
Suspended
Trader Rating: 61 (100%+)
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
