    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree327Likes
Old 07-21-2016, 06:35 AM   #1801
celt's Avatar
Originally Posted by egalsim View Post
Almost done, just need the esc and servo. Running Kyosho Velvet shocks on this.
Nicely done...
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 07-21-2016, 07:49 AM   #1802
Trader Rating: 140 (100%+)
So bad ars,, I want one
Ordering a body
Is this the mirage or viper body
RC RACING DESIGNS..
slick1 is offline   Reply With Quote
Old 07-21-2016, 08:41 AM   #1803
Hi guys, apologies if this has been covered already. I am considering a B6D as an all round car with the laydown transmission kit. Can anyone confirm if it is possible to run the rear shocks on the front of the rear wishbones, or is this only available when using the laydown gearbox? Thanks
stueys is offline   Reply With Quote
Old 07-21-2016, 08:42 AM   #1804
Suspended
Trader Rating: 61 (100%+)
You can put the shocks on the front of the arms with the laydown only. With the stand up, you're only able to run them on the rear. The laydown you can do both.
Please read page 1 and the wiki, this is covered.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-21-2016, 08:42 AM   #1805
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
you need the laydown gear box to mount the shocks on the front
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-21-2016, 08:46 AM   #1806
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Only when running the laydown gearbox.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-21-2016, 09:09 AM   #1807
Thanks guys, must have missed this bit in the Wiki!
Old 07-21-2016, 09:19 AM   #1808
BIGSKI15's Avatar
Trader Rating: 18 (100%+)
I had my first run with the car last night. Box stock i was consistently 2-3 tenths faster per lap than my b5m factory lite. I also went from 3mm on the rear tower to 1mm and it really freed up the car in turns. Really easy to drive and you can push the car hard. The only problem i had was i cracked a rear shock tower on a minor cart wheel. Luckily my tower hobbies order arrived on Monday so i had a spare.
B6D
B5M
Airtronics M12
BIGSKI15 is offline   Reply With Quote
Old 07-21-2016, 09:23 AM   #1809
Originally Posted by slick1 View Post
Do bad ars,, I want one
Ordering a body
It's the Protech.
https://www.amainhobbies.com/team-as...FYQkhgoddcIDyA
rcgerber is offline   Reply With Quote
Old 07-21-2016, 10:03 AM   #1810
Phillip F's Avatar
Trader Rating: 15 (100%+)
Default B6 build
What's the difference between installing the rear shocks infront/rear of the rear arms ?
Phillip F is offline   Reply With Quote
Old 07-21-2016, 10:07 AM   #1811
Suspended
Front of arms takes weight off the rear axle. Rear of arms puts more weight on the rear axle.
Old 07-21-2016, 10:11 AM   #1812
Suspended
Buddha, I edited the wiki, take that and just plug it into page 1 please!
Old 07-21-2016, 10:14 AM   #1813
Mason's Avatar
Weight bias and rotational inertia reduction.
also helps protect the shocks
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 07-21-2016, 10:31 AM   #1814
Finalist's Avatar
cracked my rear tower. Lot's of low flying flips. No big high speed into the wall type crashes.
I THINK once the wing is cracked it may start give and flex too much on a flip putting all the stress on the rear tower. Lucky for me I have a couple spares.
Finalist is offline   Reply With Quote
Old 07-21-2016, 10:45 AM   #1815
Question for the two recent rear tower breakage, did you sand the edges and seal with CA?
machfever is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
coaltrain
