    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree327Likes
Old 04-30-2016, 11:14 PM   #166
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Originally Posted by Finalist View Post
Any idea, guess or thoughts if the b6 will use the same c and d mounts as the b5m? I'm wondering how many upgrade parts from my b5 will work on the b6. B5 Schelle rear hubs, pucks, and ti axels look like they may fit on the b6.
As soon as the manuals are posted for the b6/6d; I will see what can cross over by comparing part #'s.
So far, shocks/slipper/ball diff seem to be the same.
RCBuddha is offline   Reply With Quote
Old 05-01-2016, 01:00 AM   #167
Can't wait to get my hands on this! B6D does not look like a bid departure from the B5M but sometimes change isn't easy to see and it is the little things that make the biggest impact! The one that interests me the most is the B6! Looks like a sweet ride!
Have a guy here that runs a B5M with the laydown tranny/high grip box on a Med to High bite track and he is pretty damn fast with it. It is a dirt track and the traction is somewhat on and off but lately he has this figured out pretty well and VERY Competitive with his B5M Laydown Tranny. So basically, i would venture to say that the B6 would probably do better than you think in a Med bite track if you take the time to play around with it!
Either way can't wait to get one!
Turtle Speed is offline   Reply With Quote
Old 05-01-2016, 02:11 AM   #168
pink_sleeve's Avatar
Trader Rating: 163 (99%+)
The C and D mounts on the B5M do not work with either B6. The only real crossover parts are the differential, slipper, driveshafts, and shocks.
pink_sleeve is offline   Reply With Quote
Old 05-01-2016, 04:42 AM   #169
celt's Avatar
Default which version?
Curious which version most in the States are pre-ordering, B6 or B6D?
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 05-01-2016, 05:13 AM   #170
elex300's Avatar
Trader Rating: 102 (100%+)
Both,lol
elex300 is offline   Reply With Quote
Old 05-01-2016, 05:16 AM   #171
Next to the B5 with that heinous body, this thing looks like the Mona Lisa....
Im gonna have to cop me one!
Obviously theyre built for specific conditions but it would be nice if the B6 had a gear cover so you could throw it in the dirt once in a while without worrying about tearing the gears up....
NickTheGreek is offline   Reply With Quote
Old 05-01-2016, 05:27 AM   #172
celt's Avatar
Default stunning performance
If you get a chance, watch the EOS videos, the chassis looks incredible - pre-ordered right after that.
Stan Garvin
Old 05-01-2016, 07:10 AM   #173
Davidka's Avatar
Trader Rating: 75 (100%+)
But, but... X-RAY!!
Old 05-01-2016, 07:18 AM   #174
celt's Avatar
Originally Posted by Davidka View Post
But, but... X-RAY!!
They uhh...kinda got spanked. I was impressed with a debut chassis doing so well against seasoned, tuned cars. Granted, the AE team is uber talented, the rest of the field are also awesome drivers.
I don't think AE could have expected that good of an outcome the first time out. Watch the videos, car looked stellar.
Stan Garvin
Old 05-01-2016, 08:09 AM   #175
Davidka's Avatar
I did. I'm not sure I can "see that fast".
Old 05-01-2016, 08:23 AM   #176
The car in the videos look very good. But as everyone here knows those are the best drivers in the world. How it translates to us mere mortals is the question. I pre-ordered one as well.
jneg is offline   Reply With Quote
Old 05-01-2016, 08:37 AM   #177
https://youtu.be/WTlkoPiWu3w
buckettim is offline   Reply With Quote
Old 05-01-2016, 09:15 AM   #178
I'm pre-ordering the B6. Who do you guys think will get it sooner, Amain or Tower?
I've had bad experiences with pre-ordering and one vendor seems to get more stock than another, then I'm waiting for weeks and weeks for my pre-order to come in.
Bomba is offline   Reply With Quote
Old 05-01-2016, 09:58 AM   #179
RCBuddha's Avatar
Tower seems to have a better coupon, at the moment but I think both should get it around the same time.
I think I see my kits in the red container
Old 05-01-2016, 10:17 AM   #180
.My bet is on Tower.
I pre-ordered the Factory Lite last year (Gotta Have it!, Gotta Have it!) and it was not a necessary thing. It never was out of stock, they get a ton of Associated kits on a new product launch.
I plan to buy both at same time for a big coupon code and ecash promo week probably in July
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Fanatic01
