    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree328Likes
Old 07-15-2016, 07:22 PM   #1561
BRSracing's Avatar
Trader Rating: 55 (100%+)
[QUOTE=abailey21;14603045]Just finished wiring mine. I'm by no means good but i've found I don't like the battery strap or the waterfall for clean wiring.
looks great, I don't like the battery strap either for low profile plugs.
BRSracing is offline   Reply With Quote
Old 07-15-2016, 07:40 PM   #1562
Shouldn't be long before a carbon fiber battery strap is available.
BruceR. is offline   Reply With Quote
Old 07-15-2016, 07:55 PM   #1563
Jmuck69's Avatar
Coming.....
https://instagram.com/p/BH5u-o2g1JL/
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 07-15-2016, 07:58 PM   #1564
RCBuddha's Avatar
Trader Rating: 35 (100%+)
bezerk r/c posted two prototypes on it's facebook page of their battery strap. I also added their carbon towers to the front page
RCBuddha is offline   Reply With Quote
Old 07-15-2016, 08:06 PM   #1565
rvrslt1's Avatar
Trader Rating: 25 (100%+)
Originally Posted by city.life View Post
My B6 with flat arms
Car looks sweet. Did you use the AE aluminum bell crank and bulk head?
rvrslt1 is offline   Reply With Quote
Old 07-15-2016, 08:30 PM   #1566
city.life's Avatar
Yes I did.
Everything is deanodized including the chassis plate.
city.life is offline   Reply With Quote
Old 07-15-2016, 08:40 PM   #1567
Phillip F's Avatar
Trader Rating: 15 (100%+)
So I was at the track last night and a B6 was running there (mid to high bite clay track). I talked to the driver and he said the car is pretty easy to drive compared to the B5M (I was having a hard time keeping up with him) .... very easy to manuever around traffic and fast in the corner. The only thing that he was complaining about that the car is so light at the rear that the rear was fish tailing a bit. He thinks he needs more wait to tame the rear end. What do you guys think and the solution to his problem?
Phillip F is offline   Reply With Quote
Old 07-15-2016, 08:42 PM   #1568
Phillip F's Avatar
what's the advantage to that with the stock battery strap?
Old 07-15-2016, 09:16 PM   #1569
Default B6 Hybrid
This is setup for my B6 Hybrid
I think the best options for setup unless your carpet only is:
Buy B6D + laydown gearbox it will give you lots of options.
I am not the best driver, but after 1 race night, 1 practise to setup i qualified 2nd fasted for the night and placed 3rd in final
I am almost a 1 second faster than my b5m lite.
I have listed my setup and some pics to show weight
I will update with video and more info soon
This setup is very easy to drive on our local track.
https://drive.google.com/file/d/0BxY...ew?usp=sharing
[YOUTUBE]https://www.youtube.com/watch?v=axrwImz0-jc[/YOUTUBE]
Team Associated B6 & B6D thread-img_7575.jpg   Team Associated B6 & B6D thread-img_7577.jpg   Team Associated B6 & B6D thread-img_7578.jpg   Team Associated B6 & B6D thread-img_7579.jpg
Dmitri Tech is offline   Reply With Quote
Old 07-15-2016, 09:39 PM   #1570
hey everyboddy
one of the guys at my track at speed rc in mooresville, nc was running the b6d. He put a laydown transmission in it didn't even try the stock tranny that came with the car. he said that is the ticket you need. he said with the b6d with laydown tranny he said he cornor faster, and he felt the car jumped better. The accleration of this car with the laydown tranny is amazing.
He also set the fastest lap time with this car at the track. he said opitional weights are not needed for this car to run on clay.
he ran a 7.5 motor in it, with out of box setup on clay track.
here is a link to the footage I recorded
https://youtu.be/kKlzd5ZVLzY
828Army is offline   Reply With Quote
Old 07-15-2016, 10:11 PM   #1571
This is my thoughts as well, i went B6 then got B6D front arms and shock tower. I think i like the gear diff.
But my gear diff out drives wobble, is this normal?
Originally Posted by 828Army View Post
hey everyboddy
Old 07-15-2016, 11:55 PM   #1572
JAE
Trader Rating: 28 (100%+)
i just saw a b6d with laydown transmission destroying it ON AN OUTDOOR TRACK with holeshots and ribbed fronts. I don't get it. He had the same traction as I did with my standup XRAY xb2 with 4 degrees toe. How?
JAE is offline   Reply With Quote
Old 07-16-2016, 12:13 AM   #1573
Phillip F's Avatar
I talked to Eric at the track and he actually said..the B6 is like half the Xray and the Yokomo. ... looks like the B6 is the car to have right now to go fast. I really think that it's so easy to drive a B6 if you have been running the B5 platform. It has loads of steering and super planted in the corners.
BTW... how do you measure your toe-in? The only toe-in gauge I know is made by RPM.
Old 07-16-2016, 12:52 AM   #1574
JAE
Toe in frequently set by pills in fr/rear hanger. B6 has way more droop than xb2.
Old 07-16-2016, 01:09 AM   #1575
AZJP's Avatar
Trader Rating: 20 (100%+)
He's talking about rear toe.
AZJP is offline   Reply With Quote
Currently Active Users Viewing This Thread: 8 (3 members and 5 guests)
djblues11, Stealthpilot, Still Bill
