    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree327Likes
Old 07-15-2016, 07:59 AM   #1531
Hmmm.
Gear diff build, had one in my B5m and it had additional o rings which fitted in the groove in the outdrives; the b6 only seems to have external o rings which sit around outdrives/in gear case.
If I'm being confusing check the B5m gear diff supplement on AE or PetitRC vs the B6 manual and you should see the ones that are missing?
So are they missing from box and manual? (Seems unlikely)
Or is this an updated build for gear diff?
andrewcoley is offline   Reply With Quote
Old 07-15-2016, 08:04 AM   #1532
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by michwolv View Post
does anywhere still have the B6D?
Hobbyaction has some
http://www.hobbyaction.net/collectio...-associated-b6
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-15-2016, 08:12 AM   #1533
Originally Posted by weedsnager View Post
What are the stock spring colors ?
It's White front and green rear
magnushedqvist is offline   Reply With Quote
Old 07-15-2016, 08:22 AM   #1534
rvrslt1's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Socket View Post
Bulkhead I can difinitively say yes to. Bell cranks and rack are a personal feel thing. I didn't like them on the B5M, but some loved them. They also add weight, so there's that effect as well.
Thanks. Maybe just try the bulkhead. I never did put an Aluminum rack on the B5M.
rvrslt1 is offline   Reply With Quote
Old 07-15-2016, 08:29 AM   #1535
Silverstonev8's Avatar
Originally Posted by andrewcoley View Post
Hmmm.
AE did the same thing when they went from the v1 to the v2 diffs in the Rc8b3 t3
Silverstonev8 is offline   Reply With Quote
Old 07-15-2016, 08:39 AM   #1536
Got the b6, impressed with the overall quality of the parts included. It seems to be the less common version of the cars. So I have finished most of the build, except wheels, tires, and electronics.
Did anybody with the b6 kit run into and issues with hardware not being correct in the manual vs what was actually necessary on the car at any given point. For example on page 10, step 5 it lists 6 3x16mm button head screws to hold the transmission together and at that point I had 8 3x14mm screws (I don't think any 3x16 screws were supplied in my kit at all). Also page 11 step 8 they list 2 3x8mm button heads to fasten the aluminum ball stud mount to the rear bulk head. These are at least 2mm short and do not begin to thread into plastic. Had to go searching for some 3x10s (one extra was provided in the extra hardware bag).
Also, totally my fault, but I accidentally put the plastic ball cups for the shock tops in the bottoms. At the point in the manual, where they tell you to put the bottom balls in you have to have opened the bag for the plastic balls, but not necessarily the metal balls that actually go there. So I put the wrong ones in and either destroyed or lost 3 out of the 4. Again totally my fault for not paying closer attention. I think these parts are all carry over from the b5/b5m so had I built one I would have been more familiar.
A manual addendum would be great.
Finally the new ball cups seem to be getting great reviews but i had one split down the seam line while hand-threading it on. I hope it's just a fluke. I was a little rougher with the rest to test them and they held up so far. Besides that I love the design & fit. Anyhow had to sub a traxxas rod end from my spares until I get a replacement.
Anybody else experience these things? How is everybody's builds going or if you're done how's your driving going?
Omerta6 is offline   Reply With Quote
Old 07-15-2016, 08:59 AM   #1537
tsair's Avatar
I had this issue too. I have a feeling you're supposed to use the M3x8's in the front of the top plate (page 7, step 5) and the M3x12's for page 11 step 8. That's my best guess, because the M3x12's are pretty darn long for the top plate, they threaded in FOREVER.
The manual also showed 8 M3x10 screws for the second half of page 11, step 8 to mount the tranny and water fall onto the chassis, but I only had 4 and there are only 6 holes for screws. I had to use M3x12 screws for the water fall.
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 07-15-2016, 09:20 AM   #1538
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
so the online manual has all of the update/known errors fixed?
RC*PHREAK is offline   Reply With Quote
Old 07-15-2016, 10:21 AM   #1539
Weird, I did not have any screw issue for the B6D. I followed the manual and measured each screw before putting them in. I was missing one screw, but they had one in the "spares" bag. but, I opened several bags and dumped them into a parts tray, then measured and grabbed the ones i needed. I didnt specifically follow the bag number closely.
Old 07-15-2016, 10:23 AM   #1540
I'm sure it has been discussed already. I want to add the Schelle rear hubs to my B6D. Any modifications that need to be made so they can fit properly?
TOBAMA is offline   Reply With Quote
Old 07-15-2016, 10:28 AM   #1541
aeRayls's Avatar
Nope, any B5 rear Hubs will work just fine. You will lose the ability to raise and lower the hinge height. This has become a very valuable tuning option already. Typically we've all been running the hubs +1 which had a good feeling ok med- high bite.
aeRayls is offline   Reply With Quote
Old 07-15-2016, 11:01 AM   #1542
wiggindude6969's Avatar
I noticed the front shocks have alot of travel? the kit came with the same length shafts... kit went together well. but i dont see many set up sheets? we run high bite clay.... anyone have a good set up sheet? I need to get some springs as well. recommendations?
F104v2 - RSD/TC6.1 - CRCXTi - AE B6
wiggindude6969 is offline   Reply With Quote
Old 07-15-2016, 11:06 AM   #1543
Jmuck69's Avatar
Best set-up is to go practice and develop your own set-up for how you drive. If you want something to reference, look at Rivkin's set-up from the JC Spring Race. For ClubRC which I have raced at, laydown transmission for sure, stiffer springs and thicker oil.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 07-15-2016, 11:07 AM   #1544
aeRayls's Avatar
On the front shocks use the long eyelets for the outside hole and the short for the middle or inside. Use 2 limiters inside and the exposed shaft length should start at 20.5mm.
Get grey and maybe blue front springs.
Old 07-15-2016, 11:11 AM   #1545
what about for the rear springs? they come in sets.. soft, med and hard i think
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
