    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree370Likes
Old 07-14-2016, 05:03 PM   #1516
Trader Rating: 140 (100%+)
Originally Posted by jspurgin View Post
Will the B5m body fit the new B6?
yokomo body fits really good, had my old YZ2 body laying around, while painting new B6 body...
not sure what trimming you would need to do to fit stand up B6d trans...
RC RACING DESIGNS..
slick1 is offline   Reply With Quote
Old 07-14-2016, 06:55 PM   #1517
aeRayls's Avatar
Originally Posted by Fabulous View Post
Any idea why angle ball cups? I know the kits don't use them.
To put them on the 5 series cars/trucks.
aeRayls is online now   Reply With Quote
Old 07-14-2016, 08:57 PM   #1518
Trader Rating: 55 (100%+)
Will the hard front arms add steering?
Speedychris22 is offline   Reply With Quote
Old 07-14-2016, 09:10 PM   #1519
aeRayls's Avatar
Kinda, the car has a more responsive feel with hard arms front or rear.
Old 07-14-2016, 11:01 PM   #1520
F18engineguy's Avatar
Trader Rating: 216 (100%+)
Originally Posted by racer1812 View Post
The Wiki post, which is why we have it at the top of the forum, says..NO the B5 bodies will not fit.
Wiki posts, great in theory useless if people don't read them.
The Wiki is nice and reflects the passion of all those that have contributed to it. With that, you never know if and when someone may have figured out something new so there is no need to patronize people for their post.
VA Beach
F18engineguy is offline   Reply With Quote
Old 07-14-2016, 11:13 PM   #1521
what's the advantage to running a brass C mount vs. the stock alum piece?
Rinker is offline   Reply With Quote
Old 07-14-2016, 11:18 PM   #1522
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Additional weight further back. Can help in lower bite situations
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-15-2016, 04:40 AM   #1523
First impression of the car B6d compared to the b5m is that it feels more stable. Didn't get the chance to try a lot of changes but kit setup with 2deg antisquat and Green springs up front, battery full back and it was very easy to drive on our damp loose dirttrack.
magnushedqvist is offline   Reply With Quote
Old 07-15-2016, 04:42 AM   #1524
What are the stock spring colors ?
weedsnager is offline   Reply With Quote
Old 07-15-2016, 06:35 AM   #1525
Suspended
Trader Rating: 61 (100%+)
The manuals are in the wiki, a long with a stock setup sheet.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-15-2016, 07:45 AM   #1526
rvrslt1's Avatar
Trader Rating: 28 (100%+)
So is the AE aluminum bell crank, steering rack and bulk head a good idea to use? Only going to run 17.5? LHS has the parts and I plan to start build tonight and they are the first step. Thanks.
rvrslt1 is offline   Reply With Quote
Old 07-15-2016, 08:03 AM   #1527
Suspended
Bulkhead I can difinitively say yes to. Bell cranks and rack are a personal feel thing. I didn't like them on the B5M, but some loved them. They also add weight, so there's that effect as well.
Old 07-15-2016, 08:06 AM   #1528
I believe the wiki is in place to prevent the 50 pages of "will b5 wheels fit the b6?" As things are found , they get added to the wiki. I also believe the wiki was placed at the top of every page (which is a pain on mobile imo) because many are too lazy or "don't have the time" to read the thread. By being at the top, it's easy to reference. I don't think he was patronizing as much as he was pointing out the purpose. In my opinion of course. I've always found these threads to be a Bible on whatever car your wanting. By reading the entire thread, including the drama, one can get a really good feel for the car, commonly broken parts, setup issues and inspirational ideas, before actually buying it. This goes a long way towards having everything you need when you build it, as well as having a well prepared car for that maiden run at the track. Again, in my opinion of course.
Phantom56 is offline   Reply With Quote
Old 07-15-2016, 08:20 AM   #1529
Agree, Sometimes its best to check the first paige for info that has been mentioned before. Also I hate when people ask if a part is the same as in a b5, Why not just look up the manual for the b5 and b6 and compare to see if the part #'s are the same.
Old 07-15-2016, 08:38 AM   #1530
does anywhere still have the B6D?
michwolv is offline   Reply With Quote
Currently Active Users Viewing This Thread: 14 (9 members and 5 guests)
05PSD, aeRayls, Be6, frankf, hipster, jamsandolina, lexusbest, Ogleheat, raved007
