    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree366Likes
Old 07-14-2016, 11:21 AM   #1501
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Originally Posted by tsair View Post
I don't think I need it... ideally, the link should be at 90 degrees from the bellcrank arm, am I right? It's already past 90 degrees without the 2mm ballstud washer.
That's just the first thing I noticed at the top/side views. Correct, link should be perpendicular to the bell cranks.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-14-2016, 12:40 PM   #1502
wildfire86's Avatar
I thought I read it here somewhere but I can't find it. Is the B6 top shaft the same as the B5M? And will an Exotek slipper eliminator work? Thanks!
Doug Hudson
Beachline Raceway / 386 Raceway
wildfire86 is offline   Reply With Quote
Old 07-14-2016, 12:55 PM   #1503
Pulled the trigger at Tower on the B6 just now. There is like 2 in stock left in Champaign, IL warehouse.
Funny watching it jump in and out of stock the last week. Like it trickles in or they find boxes fallen off the skids around the warehouse?
I'll race the B5M FL for the rest of the season on the real dirt outside.
If I buy the B6D it will lineup with the E-cash for sure for max discounts.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 07-14-2016, 01:15 PM   #1504
Jmuck69's Avatar
Trader Rating: 14 (100%+)
The two shafts are different. The B6/B6D shaft is longer but the exposed shaft outside the gearbox should be the same. The eliminator should fit.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 07-14-2016, 01:24 PM   #1505
JAE
Trader Rating: 28 (100%+)
Someone drive this thing and give us a play by play recap and comparison with the B5M. Thx!!
JAE
JAE is offline   Reply With Quote
Old 07-14-2016, 01:44 PM   #1506
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
new top shaft. my avid direct drive works fine, I assume your exotek eliminator will work.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-14-2016, 02:11 PM   #1507
Suspended
Trader Rating: 61 (100%+)
A buddy coming from yokomo said the B6D outdoors is cheating.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-14-2016, 03:31 PM   #1508
jspurgin's Avatar
Trader Rating: 200 (100%+)
Will the B5m body fit the new B6?
Tha mothaflippin Rhymenocerous..
Cause' there aint' no party like a Nana's tea party....
Southern Onroad F1 Champion.. F109
jspurgin is offline   Reply With Quote
Old 07-14-2016, 03:44 PM   #1509
I have compared the lines of the B6 and B5 body. They are a bit different and don't see the bodies being interchangeable.
flintTRDTC is offline   Reply With Quote
Old 07-14-2016, 03:50 PM   #1510
Super Moderator
No. The B6 is wider up front.
Old 07-14-2016, 03:51 PM   #1511
Originally Posted by Wildcat1971 View Post
turnbuckles were fine, I used a 3m tap on mine and bees wax. But, the 3mx10mm screws engaged my clutch on my driver before i was expecting it, and they just "feel" different.
I ran a tap thru my ballcups as well and now my turnbuckles are money! Usually I try to use the drill method to get them on, but the tap works much better
mgers75 is offline   Reply With Quote
Old 07-14-2016, 03:51 PM   #1512
Fabulous's Avatar
Trader Rating: 42 (100%+)
Any idea why angle ball cups? I know the kits don't use them.
22 4.0 - Mod
22 3.5 - Stock
22-4 2.0 - 13.5
8ight E 4.0
Fabulous is offline   Reply With Quote
Old 07-14-2016, 03:52 PM   #1513
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
The Wiki post, which is why we have it at the top of the forum, says..NO the B5 bodies will not fit.
Wiki posts, great in theory useless if people don't read them.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 07-14-2016, 04:29 PM   #1514
Yes they will fit! I saw one last night! You need to trim back the front wheel wells, and cut some of the tail off!
jbirdsfl is offline   Reply With Quote
Old 07-14-2016, 04:51 PM   #1515
F18engineguy's Avatar
Trader Rating: 216 (100%+)
Default Fan size
What size do you think this fan is? 30x30mm?
VA Beach
F18engineguy is offline   Reply With Quote
Currently Active Users Viewing This Thread: 8 (2 members and 6 guests)
2dialed, Screech
