    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree360Likes
Old 07-14-2016, 10:38 AM   #1486
B44
B44's Avatar
Originally Posted by Wildcat1971 View Post
Anyone else think this plastic feels different? stiffer?
to me softer, I could thread the turn buckles on with just my hands.
B44 is offline   Reply With Quote
Old 07-14-2016, 10:38 AM   #1487
Suspended
Trader Rating: 61 (100%+)
I think it's to provide clearance for larger spur gears.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-14-2016, 10:39 AM   #1488
tsair's Avatar
Is the servo supposed to angle up towards the front like this? I'm getting clearance issues with the linkage and the top plate:
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 07-14-2016, 10:44 AM   #1489
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
turnbuckles were fine, I used a 3m tap on mine and bees wax. But, the 3mx10mm screws engaged my clutch on my driver before i was expecting it, and they just "feel" different.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-14-2016, 10:46 AM   #1490
where is it hitting on the top plate. I used a different horn on mine, so hard to compare, but I did need to use the supplied servo spacers to more the servo forward.
Old 07-14-2016, 10:53 AM   #1491
tsair's Avatar
So with zero servo spacers and 0mm ballstud spacers, its hits the top chassis brace:
Razor RC blog:
Old 07-14-2016, 10:53 AM   #1492
RC*PHREAK's Avatar
Trader Rating: 120 (100%+)
using B5m servo mounts will move the servo up a bit too.
edit: is that ball cup on backwards? i know that won't address this issue though...
RC*PHREAK is offline   Reply With Quote
Old 07-14-2016, 10:56 AM   #1493
tsair's Avatar
I think I figured it out: I'm not using the servo spacer, and if you don't then the bottom servo mounting screws are too long and push in on the mount and angle the whole servo up as seen in the first pic.
Razor RC blog:
Old 07-14-2016, 10:57 AM   #1494
is it touching the top plate in that picture. hard to tell
Old 07-14-2016, 10:59 AM   #1495
is your servo tightened down? does not look like it. looks like the servo might be tilted backwards
Old 07-14-2016, 11:05 AM   #1496
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Where is the 2mm ballstud washer on your servo horn?
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-14-2016, 11:09 AM   #1497
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Are your screws tightened that mount the servo to the chassis fully screwed down? That might help level the servo out.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 07-14-2016, 11:11 AM   #1498
Jmuck69's Avatar
Originally Posted by MrLean View Post
The lower wing mount is cool, but can someone explain what the rear body mount is for?
It's for the B6 with rear tower in forward position. It provides a shelf for the rear of the body to rest on.
B6D | B64D
Old 07-14-2016, 11:14 AM   #1499
tsair's Avatar
I got it figured out, thanks guys. You have to use the plastic spacers. My servo is pretty far forward, so I removed them instead of the ballstud washer. To answer my original question, the servo should not be angled -- if it is, something is seriously wrong!
I don't think I need it... ideally, the link should be at 90 degrees from the bellcrank arm, am I right? It's already past 90 degrees without the 2mm ballstud washer.
Razor RC blog:
Old 07-14-2016, 11:21 AM   #1500
my holes would not line up without the spacers.
Currently Active Users Viewing This Thread: 9 (5 members and 4 guests)
2dialed, Aaron P, BIREL8, jct108, nesbot
