    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 07-12-2016, 06:39 PM   #1396
RCBuddha's Avatar
Trader Rating: 33 (100%+)
Coming soon from Rawspeed RC
RCBuddha is offline   Reply With Quote
Old 07-12-2016, 06:45 PM   #1397
Just picked up my pre-ordered B6d from the LHS. Started the front end before heading down to the local establishment for a refreshment. Going together great so far. These cars seem so minimalistic these days that they go together in no time.
mx836 is offline   Reply With Quote
Old 07-12-2016, 06:57 PM   #1398
Jmuck69's Avatar
Hate going down the cliche path but that's what I miss about the RC-10. There was a lot of hand fitting and fine tuning of parts to make better or smoother. Like to see someone get a 6 gear transmission to run smooth. This is a hobby and taking time to get it right was half the fun. I understand making parts better and fitament better but in a way it takes the fun out of it.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 07-12-2016, 07:03 PM   #1399
rvrslt1's Avatar
Trader Rating: 24 (100%+)
So I got my B6D today along with the lay down trans kit brass c mount and aluminum D mount. Plan to run 17.5 at OCRC. Will this work or do I stick with the stand up trans?
rvrslt1 is offline   Reply With Quote
Old 07-12-2016, 07:09 PM   #1400
abailey21's Avatar
Trader Rating: 36 (100%+)
I bought the B6 with the gear diff, never ran a gear diff before.
How far up do i fill the fluid? I believe it's up to the cross bars of the planetary gears right?
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 07-12-2016, 07:23 PM   #1401
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
I hated the 6 gear..... hated.....
Big_Show likes this.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-12-2016, 08:00 PM   #1402
aaahhh, I remember those days, tooth paste worked wonders as did a nail file!
actually, I don't miss those days ! not one bit!
ed
Edwin Pibal is offline   Reply With Quote
Old 07-12-2016, 08:26 PM   #1403
Trader Rating: 16 (100%+)
There was an easy way to make the 6 gear work. Swap in a stealth...
MX304 is offline   Reply With Quote
Old 07-12-2016, 08:30 PM   #1404
I ran the MIP first I think. It was released before the stealth if i recall. My ultima had a much more free transmission out of the box.
Old 07-12-2016, 08:37 PM   #1405
Trader Rating: 14 (100%+)
A&L Belt drive for me!
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 07-12-2016, 08:41 PM   #1406
Originally Posted by DG Designs View Post
Belt drive for me!
man, there was sooooo much you could do to a rc10. convert to 4wd, belt drive, chain drive, RPM wide arms setup and so on......and i bought just about all of it, lol
Old 07-12-2016, 09:35 PM   #1407
abailey21's Avatar
Is anyone running the B5CE Fox shocks in the rear? I know the bodies are longer but is anyone using limiters until the right size is released?
NVM, just read the wiki about the truck fronts used in the rear
K.C.C.O.
Old 07-12-2016, 09:50 PM   #1408
RCBuddha's Avatar
Interesting pics of Brian Kinwald's B6:
Old 07-13-2016, 01:04 AM   #1409
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
5.0?
RC*PHREAK is offline   Reply With Quote
Old 07-13-2016, 02:00 AM   #1410
Phillip F's Avatar
Trader Rating: 15 (100%+)
which ESC and power wires are those? It looks pretty flexible.
Phillip F is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
