    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree285Likes
Old 07-12-2016, 02:33 PM   #1381
Suspended
Trader Rating: 61 (100%+)
Originally Posted by fullsyzz View Post
Yokomo green rear spring....Yatabe 1050 green, or A1200 green?
Good question.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-12-2016, 02:47 PM   #1382
davidfast's Avatar
Trader Rating: 22 (100%+)
It's the non Yatebe spring. Green Yatabe is at a 2.7 rate.......
Thanks To:
Maclan Racing / JConcepts / Bubba's Bing / Xpert / R17 / Legit Lids / Bodies By Ed
davidfast is offline   Reply With Quote
Old 07-12-2016, 02:55 PM   #1383
Suspended
I want to say he said it was the YS-A1200
Old 07-12-2016, 03:41 PM   #1384
any thoughts on the B6 in 17.5 class minus the gear diff?
TJ9017 is offline   Reply With Quote
Old 07-12-2016, 04:05 PM   #1385
Here is a laugh, I test many times in AMain shopping cart what they really have in my wishlist to pull the trigger on an order of items. When trying to herd a bunch of small parts together and deciding when to order before waiting again.
Anyways pic below of B6 kits. 100 in the shopping cart and there is 61 in stock officially, LOL
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is online now   Reply With Quote
Old 07-12-2016, 04:40 PM   #1386
Can someone suggest a few pinions to start with
B6D
Reedy Sonic 540-M3 17.5
Outdoor dirt track
weedsnager is offline   Reply With Quote
Old 07-12-2016, 04:54 PM   #1387
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
B6D
Reedy Sonic 540-M3 21.5
Outdoor dirt track
21.5?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-12-2016, 05:10 PM   #1388
Originally Posted by Wildcat1971 View Post
21.5?
Changed it to 17.5
Old 07-12-2016, 05:19 PM   #1389
Same final drive as a b5m I think so how about 72/32???
dsms4ever is offline   Reply With Quote
Old 07-12-2016, 05:19 PM   #1390
Gear diff with 17.5 all the way.... Not even an issue..
Old 07-12-2016, 05:31 PM   #1391
suby723's Avatar
Trader Rating: 21 (100%+)
I ran a gear diff on my 17.5 b5m in the past on high bite sugar tracks BUT nothing is better then the Mip pucks period.
suby723 is offline   Reply With Quote
Old 07-12-2016, 06:10 PM   #1392
buckeye dan's Avatar
does anyone have both gear diff and ball diff and can weigh them?
Buckeye Dan
buckeye dan is offline   Reply With Quote
Old 07-12-2016, 06:13 PM   #1393
AE-Reedy
I don't know about B6 but on the B5 the ball diff and gear diff were basically the same.
Actually weighed B5 gear and ball diffs, gear diff 2g lighter than ball diff.
Sean Cochran is offline   Reply With Quote
Old 07-12-2016, 06:14 PM   #1394
RCBuddha's Avatar
Trader Rating: 33 (100%+)
http://www.redrc.net/2016/07/zzracin...um-screw-sets/
RCBuddha is offline   Reply With Quote
Old 07-12-2016, 06:32 PM   #1395
RCBuddha's Avatar
Thanks for updating the wiki Socket...I added the info to the first page
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
