    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree309Likes
Old 07-11-2016, 11:52 AM   #1321
Originally Posted by weedsnager View Post
Thanks !! Just ordered !!
My b6d pre orderd from a main is being boxed with delivery 7-13-16.
hunsaker204 is offline   Reply With Quote
Old 07-11-2016, 12:02 PM   #1322
Suspended
Trader Rating: 61 (100%+)
Ordered mine last night, already shipped from Amain. Woot
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-11-2016, 12:25 PM   #1323
Do the standard buggy AE springs fit these new shocks?
This one?
http://site.petitrc.com/setup/associ...pringChart.pdf
Dmitri Tech is offline   Reply With Quote
Old 07-11-2016, 12:39 PM   #1324
Suspended
No. You'll need big bore springs.
I recommend Kyosho's or the Yokomo's.
Old 07-11-2016, 01:29 PM   #1325
Trader Rating: 15 (100%+)
Just wondering if the turnbuckles and front axles fit from the b5? I have some Lunsford one I would like to use.
dbracn is offline   Reply With Quote
Old 07-11-2016, 01:39 PM   #1326
HBRob's Avatar
Send a message via Skype™ to HBRob
In stock at OCRC - was just there.
**Privateer** - Getting Out 11/12/16
TLR 22 3.0 | TLR 22T 2.0 | TLR 22-4
Fantom Racing | Hobbywing | Futaba
#ocrcarmy
HBRob is offline   Reply With Quote
Old 07-11-2016, 01:40 PM   #1327
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Not according to Kody
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-11-2016, 01:54 PM   #1328
Turnbuckles will work. They're a millimeter or two different, but will work. The front axles are different.
boucher is offline   Reply With Quote
Old 07-11-2016, 02:49 PM   #1329
So Amain is sold out of RC10B6D....
michwolv is offline   Reply With Quote
Old 07-11-2016, 03:03 PM   #1330
richmtb01's Avatar
Just got my finished build video complete. Turned out pretty good with some RawSpeed wheels/tires and some access from Schelle:
https://www.youtube.com/watch?v=isZzOPQTVQg
AKA
The RCNetwork on YouTube
richmtb01 is offline   Reply With Quote
Old 07-11-2016, 03:37 PM   #1331
Suspended
"I used the JC body because it's lighter weight.....I went with the Proline wing because it's thicker and heavier duty"
Edit: You need to clock the motor forward.
Old 07-11-2016, 03:41 PM   #1332
liljohn1064's Avatar
Trader Rating: 17 (100%+)
The D version wasn't released. Tower is showing August.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 07-11-2016, 03:44 PM   #1333
Suspended
Yes it was. It was in stock this morning.
Old 07-11-2016, 03:44 PM   #1334
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
The D was released. The US just sold more D's. Tower has shipped preordered D's and I ordered one from amain this morning.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-11-2016, 04:02 PM   #1335
LAPartshouse showing 4 in stock.
http://www.losipartshouse.com/ASC90001-p/asc90012.htm
Mine shipped today so I am good
40yoCaliRacer is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
OGKRacing
