    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 07-09-2016, 02:56 PM   #1276
Jmuck69's Avatar
Originally Posted by F18engineguy View Post
Other than the shocks and motor platedoes the car come with any aluminum goodies, or is everything plastic?
Check out the B6/B6D page on AE. Gives specs and even pictures.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 07-09-2016, 03:10 PM   #1277
RCBuddha's Avatar
Trader Rating: 33 (100%+)
Originally Posted by 1spunspur View Post
Great advertising, RCBuddha. I'm assuming you work for A-E?
What are you trying to imply?
RCBuddha is offline   Reply With Quote
Old 07-09-2016, 03:37 PM   #1278
PolarRoller's Avatar
Will AE release some sort of factory team upgrade kit eventually? something that will have all of the shiny aluminum anodized stuff in one bag instead of me buying all the parts individually?
PolarRoller is offline   Reply With Quote
Old 07-09-2016, 04:10 PM   #1279
Suspended
Trader Rating: 61 (100%+)
Nope, he's just another guy who works to improve and help the community.
It's a thankless job.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-09-2016, 04:11 PM   #1280
Suspended
All the cheap skates waited for a factory team b5m and it never came. The kit out o the box is pretty damn well equipped, and also has a ton of alloy optional parts out of the box.
Old 07-09-2016, 04:45 PM   #1281
Thanks for all the good info, RCBuddah
Sean B. is offline   Reply With Quote
Old 07-09-2016, 05:16 PM   #1282
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
http://www.ask8ball.net/
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-09-2016, 05:19 PM   #1283
suby723's Avatar
Trader Rating: 21 (100%+)
Well there you have it... Lmao
suby723 is offline   Reply With Quote
Old 07-09-2016, 05:36 PM   #1284
Thanks for the info 8 ball. The Kit does look great out of the box. All the stuff that ain't included can come out of my kid's college fund. Heck, if hillary wins, you guys can all help pay for his schoolin'.
Old 07-09-2016, 06:09 PM   #1285
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
are idler gears the same between B5m/B6? stripping out my B5m and want to know if i should take my cut gears out.
RC*PHREAK is offline   Reply With Quote
Old 07-09-2016, 06:43 PM   #1286
Super Moderator
They are different.
Old 07-09-2016, 07:06 PM   #1287
RC*PHREAK's Avatar
ok. thanks matt!
Old 07-09-2016, 07:21 PM   #1288
Fabulous's Avatar
Trader Rating: 42 (100%+)
D mount, Steering Bell Crank and Link. What else is there in aluminum?
22 4.0 - Mod
22 3.5 - Stock
22-4 2.0 - 13.5
8ight E 4.0
Fabulous is offline   Reply With Quote
Old 07-09-2016, 08:15 PM   #1289
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Lol the magic 8 ball told me the same thing
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 07-09-2016, 10:09 PM   #1290
aeRayls's Avatar
You won't need the inserts, the kit comes with all of them you'll need!
aeRayls is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Dirtraycer
